| True Blue |
 True Blue World Chat Champion
 Posted: 22:19 - 10 May 2006 Post subject: Sv low on power |
I have an SV here and it seems to me to be low on power. I struggle to get it over 80 mph (on my private road ) It ticks over and runs fine, but I seem to be getting a lot of back pressure if I unscrew the oil filler cap off. Any ideas why I would be getting so much pressure from it and would this cause the bike to be down on power?
Ritchie ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| loply |
 loply World Chat Champion
 Posted: 22:45 - 10 May 2006 Post subject: |
Too much oil?
This might cause the crank the be completely submerged, which saps a fair bit of power. No idea if it would sap enough to reduce top speed that much though. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| True Blue |
 Posted: 22:47 - 10 May 2006 Post subject: |
Oil is right on the max level, but I shouldn't think it was too much. I'll try and take a wee video to show how much pressure I'm getting out of it. ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| instigator |
 instigator Super Spammer
 Posted: 22:50 - 10 May 2006 Post subject: |
Most likely don't know whats going wrong with it Ritchie but as a question that might aid otehrs:
How much has it been used since October? And when did it develop the problem? I.e. How many miles have you done since?
I can't say I had a power problem when I had it. And it's not done THAT many miles has it? |
| True Blue |
| instigator |
 Posted: 23:34 - 10 May 2006 Post subject: |
Undone it just there.
A little bit of back pressure, perhaps more than I'm used to but nothing to suggest there is anything wrong.
EDIT : Just watched avi...hmm, I didn't know you were supposed to run the engine with the oil filler cap off. I'll try tomorrow though and let you know. It's too late just now, bikes too noisy.  |
| colin1 |
 colin1 Captain Safety
| sickpup |
 sickpup Old Timer
| instigator |
| True Blue |
| sickpup |
 sickpup Old Timer
| True Blue |
| G |
 G The Voice of Reason
| sickpup |
 sickpup Old Timer
| True Blue |
 Posted: 12:37 - 11 May 2006 Post subject: |
I'm fairly sure it's running on both cylinders. They sparkplugs are new. Haven't checked the valve clearances yet, Looks like an arse of a job, especially if I have to adjust them.  ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| G |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:15 - 11 May 2006 Post subject: |
The SV is a V twin, and on one of these the crankcase volume varies far more than on an inline 4 (that I presume you are used to). On a 4 the crankcase volume is pretty constant (2 pistons going up at the same time, 2 going down). With a proper V twin both pistons are at TDC only 90 degrees apart (and the same for btc), so crankcases volume will vary by probably 1000cc on an SV with one turn of the crank. Worth checking the crankcase breather hose is clear.
| True Blue |
| instigator |
 Posted: 13:30 - 11 May 2006 Post subject: |
How many miles has it done ritchie? I can't seem to remember. Think I got it at 7800 and I done what 4000 so the valve clearances wouldn't need done for anotehr couple of thousand by the Suzuki service manual, would they not?  |
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 13:41 - 11 May 2006 Post subject: |
I'd also check the crankcase breather hose, make sure it's not kinked or trapped on it's way to the airbox. Also check the airbox in case, as I've seen before, a friendly mechanic has left a rag in there
If that is clear then the back pressure could be normal and you're probably looking at a fuelling or electrical problem.
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| True Blue |
| the grim reaper |
| True Blue |
 Posted: 14:02 - 11 May 2006 Post subject: |
Yeah, not too much oil, just a smearing really. The bike seema to be running ok other than the lack of power. It almost feels as if it's restricted. ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| the grim reaper |
 Posted: 14:08 - 11 May 2006 Post subject: |
OK, is that a general lack of power or a sudden tailing off at 80mph? If I was you, I;d go and get a dyno run done, that'll tell you fuelling and horsepower, so you'll get an idea of why the bike is doing what it's doing. £35 quid for a pretty good indicator of how healthy the bike is, good deal if you ask me.
| True Blue |
 Posted: 14:11 - 11 May 2006 Post subject: |
Just a general lack of power really, I was thinking of a dyno run actually. Greg, where was it you got your bike dynoed before? ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
The last post was made 20 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
