Brake shennigans/further work
Mister James
I want to believe!
PostPosted: 17:39 - 11 May 2006    Post subject: Brake shennigans/further work Reply with quote
Well, the last couple of times I rode my scooter, I noticed that I was getting a pretty unpleasant grinding noise when I used the front brake. As I've signed myself off sick this week, I thought I'd take the opportunity to change the brake pads and expand my woeful mechanical skills.
Do ya think these really needed changing?! (pic attached)
Still, it's passed a pleasant hour or so, and it was pretty surprising to find out that under all the crap, I actually had a gold Brembo piston assembly - very bling, would go nicely with my fake carbon fork coverings, if they weren't all covered in crap too!
Now that I feel a bit more confident fiddling around with things, could anyone suggest some other low-tech maintainence I could have a go at on the scoot? It's a YQ100, and has done a few thousand miles since it's last service. I only really use it for an emergency stand in for my main bike, so it's an ideal workshop project.
So, come on technical bods, what should I have a look at next, once I've cleaned off all the crud from the rest of the bike?
map
Mr Calendar
PostPosted: 17:44 - 11 May 2006    Post subject: Reply with quote
As a suggestion you could have a look at the rollers (in the centrifugal clutch).
Keeping a scoot at maximum for a length of time over a good few journeys tends to wear then smooth at one side (as they're in the same position against a moving surface). Quite easy to suss out once you get the cover off and you can marvel at the simplicity of the design Wink
PostPosted: 17:45 - 11 May 2006    Post subject: Reply with quote
Looking at those pads, maybe fitting a new disk will keep you amused Wink .
Otherwise, change plug, clean air filter, check tyres, bleed brakes.
Jamie.
PostPosted: 17:48 - 11 May 2006    Post subject: Reply with quote
The pad is supposed to have exactly what the name says "A pad" !!
Unless its just me, I cannot see any pad there Shocked
Mister James
I want to believe!
PostPosted: 17:52 - 11 May 2006    Post subject: Reply with quote
Got any links to a useful webpage or an exploded diagram of that sort of thing?
Definitely! I'll leave that until funds allow though, it's not very badly scratched, the rear brake is powerful enough that I've mostly been using that - although once the front pads have bedded in I'll probably look at pulling the drum apart and replacing that, how difficult will that be?
Shocked
Fair point! Wink
jonnay
PostPosted: 18:24 - 11 May 2006    Post subject: Reply with quote
In the variator actually mate, the clutch is at the wheel end of the transmission casing and doesnt contain the rollers Wink
I wrote a guide to changing rollers and the drive belt on a scooter (a yamaha so should be the same principles.. well, WILL be the same actually), and that's here
Enjoy Smile Thumbs Up
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
Mister James
I want to believe!
PostPosted: 18:48 - 11 May 2006    Post subject: Reply with quote
Very interesting Jonnay.
What role do the rollers play, and would there be any benefit in getting fancy ones?
My scooter is a Yamaha Aerox YQ100 - so I assume it's already fully de-restricted? Much I can do to nudge up the top speed, or would that need a re-bore?
veeeffarr
PostPosted: 20:31 - 11 May 2006    Post subject: Reply with quote
<genericanswer>
Pass test and get a bigger bike
</genericanswer>
Smile
Makaveli_Rydah
PostPosted: 21:02 - 11 May 2006    Post subject: Reply with quote
I ride a YQ100 mate - has a sporty pipe and 125 rebore - gave me about an extra 8mph on the top end but basically killed off any real bottom end torque.
Other things that you should maintain yourself are....
Rear pads - exhaust off , wheel off , change
Rollers - front pulley off , variator unscrewed , pop the old ones out - new ones in
Belt - again front pulley off , belt off , belt on
Clutch - bell off , change , bell on
Oil ( gear box ) - small screw on the base of tranny case , open spill , put screw back in , open the screw on the rear top of the tranny case , refill .
Brake fluid - simple really , reservoir on the top right
It's a pretty easy engine to poke around in , just don't get too ambitious . Wink
Bike History:- Vision / Phantom 100 / Aerox 100 / Runner VX125 / Honda VFR400 NC24 / Kwak ZX9R B3 / Honda CBR600 F / ZZR400 & K2 GSXR 750 / Suzuki VZ800
Mister James
I want to believe!
PostPosted: 21:23 - 11 May 2006    Post subject: Reply with quote
Toby R wrote:
<genericanswer>
</genericanswer>
Smile
LOL
Piss off!
Bet you get more minors than I did! (1)
I did nearly fall off my 'ped as I rode to Tesco's, realising that I'd actually put up a thread on 'HOW DO I MAEK MI SCOOTER GO FASTA THAN 75MPH!?!!1' - after 20 months of riding 600cc bikes!
veeeffarr
PostPosted: 23:49 - 11 May 2006    Post subject: Reply with quote
Throw it off a cliff
Yes, I am going to continue with newb ped boi jokes all thread dammit, even though you do look like you could probably kill and rape me single handedly
Mister James
I want to believe!
PostPosted: 01:03 - 12 May 2006    Post subject: Reply with quote
Trust me, there wouldn't be any raping involved - sorry to disappoint!
Is this the first thread in Workshop to involve rape?
veeeffarr
PostPosted: 01:28 - 12 May 2006    Post subject: Reply with quote
Nah, robby probably posted one on how to get the sidepanels off of a thai bride years ago.
The last post was made 20 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 84.19 Kb
