| byke95 |
 byke95 World Chat Champion
 Posted: 10:18 - 12 May 2006 Post subject: How can I stop handle bar vibrations? |
Hi,
I've recently converted my stock handle bars to Renthal Streetfighters (braced) on my Z750. If I'm honest it was for mostly cosmetic reasons i.e. I don't like the 'up and out there' standard mirrors and wanted to fit Motrax bar end mirrors, this would also allow me to reduce the 'sit up and beg' appearance.
Back to the point: I'm getting quite a bit of vibration down the left- hand side of the handle bar (at high revs) and I can't figure out why. Everything is tight and secure, this is the second Renthal conversion I've done and didn't have this problem before.
Anyone solved this problem before or can think of a solution? Why is it just the left-hand side, is the throttle body absorbing the vibrations on the right?
As mentioned, I did the conversion for cosmetic reasons so I am prepared to swap back to stock bars but would prefer to keep the Renthals on.
Many thanks,
Phil |
| veeeffarr |
 veeeffarr Super Spammer
| byke95 |
| veeeffarr |
| byke95 |
 Posted: 11:17 - 12 May 2006 Post subject: |
Thanks again Toby.
I'm well aware that care and effort (within a budget) was taken in setting up the bike in stock form. Although I'm fairly sure no-one checked that the stock mirrors showed anything other then the rider's elbows..
What I'm trying to find out is if anyone has had this problem before (and solved it) or can suggest some ways of reducing the vibrations I'm experiencing, prior to resorting to sticking the stock handlebars back on.
On the plus side, I have found some Renthal bar ends on ebay for under £10 so I'll give them a go if all else fails.  |
| the grim reaper |
 the grim reaper World Chat Champion
| byke95 |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 16:09 - 12 May 2006 Post subject: |
Put a couple of handfuls of birdshot inside the bars.  |
| byke95 |
 Posted: 17:15 - 12 May 2006 Post subject: |
| veeeffarr |
| byke95 |
| nrml76 |
 nrml76 Brolly Dolly
| MikeH |
 MikeH Brolly Dolly
| byke95 |
| MarJay |
 MarJay But it's British!
 Posted: 21:24 - 13 May 2006 Post subject: |
Its a resonance thaing.
You need to change the resonant frequency of your renthals.
A good way to do that might be to add weight. If the added weight makes the bars change resonant frequency to that of the engine vibes, then you'll make it worse.
It is possible, therefore, that removing the bar end weights may improve the problem. It may not.
What you want is a bike with a uniplanar engine mounting system... Like the Buell ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| byke95 |
 Posted: 21:43 - 13 May 2006 Post subject: |
 Posted: 21:57 - 13 May 2006 Post subject: |
You could also stick some rubber washers under the handlebar clamps if they are the bolt on type. Some bikes have the bars totally rubber mounted. I have one and you can move the bars a full inch backwards and forwards on the rubber blocks. A bit wierd but it goes round corners fine
Messing with the weights on the bar ends is favourite though. You could try wrapping some lead wire or something round the end of the bar to see what works. Even the weight of an extra nut can make the difference. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Zimbo |
 Zimbo World Chat Champion
| byke95 |
| nrml76 |
 nrml76 Brolly Dolly
The last post was made 20 years, 95 days ago. Instead of replying here, would creating a new thread be more useful? |
