Loosening exhaust
craigs23
Mr Muscle
PostPosted: 18:24 - 12 May 2006    Post subject: Loosening exhaust Reply with quote
Any recomendations to stop this niggling problem?
My exhaust studs seem to work themselves loose - no where near so that the downpipes/collars are free, but enough to cause a little uneveness on idle and a slightly rorty noise - bike is ever so slightly more vibey once they've slackened off too.
It's not much, a quarter of a turn if that, but is noticeable.
Anything I could try - spring washers? Is there a heat proof Locktite available? A don't really fancy lockwiring it...
Klause
PostPosted: 18:28 - 12 May 2006    Post subject: Reply with quote
Exhaust studs or exhaust nuts?
If it's the studs coming loose you need to put two nuts on the studs and lock them together and then tighten the stud as much as you can, then unlock the two nuts.
Either way just try locktite.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
craigs23
Mr Muscle
PostPosted: 18:33 - 12 May 2006    Post subject: Reply with quote
Sorry - nuts - the end nutty screwy bits.
Klause
PostPosted: 02:44 - 13 May 2006    Post subject: Reply with quote
My ducati nuts are locking ones. Not the nylon ones, don't think they would last long! Mine have a tiny bit of metal in the end which digs into the thread a little.
The last post was made 20 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 39.06 Kb
