front indicators for the NSR
Blunet600
PostPosted: 18:29 - 12 May 2006    Post subject: front indicators for the NSR Reply with quote
ok they work, but they are not very bright at all, and i think it damn important for the indicators on a bike to be working. is there anyway i can increase the brightness without having to buy a new relay system? coz i had the trouble of the bulbs being to strong and not working, so i put the old ones in the front and the new ones in the back, so the back indicators are nice and bright, the front not soo mcuh, at night they are good (obviosuly,) but day time not so. any ideas? cheers.
code guru
PostPosted: 20:01 - 12 May 2006    Post subject: Reply with quote
y not buy a new relay? i got some nice arrow carbon fiber look ones and they look sick but need 2 buy a relay 1st. cant be that much and i dont whant 2 put 10w bulbs as ppl wont be able 2 c if they r on so u might as well buy a new relay
alains
PostPosted: 21:06 - 12 May 2006    Post subject: Reply with quote
yes but if you increase the bulb power , you take off the same amount of power for charging the battery , i do not recommand that
if you have 21W bulbs (generally Ba9s halogen) inside the lights buy 10W bulbs in Ba9s here https://www.norbsa02.freeuk.com/goffybulbs.htm
code guru
PostPosted: 21:57 - 12 May 2006    Post subject: Reply with quote
ok well mine r 23w so i might as well buy 4 10w then
alains
PostPosted: 22:07 - 12 May 2006    Post subject: Reply with quote
yes, just take the diameter of the bulb metallic part if it's 9mm Ba9s type if 15 it's Ba15s , so buy the same in 10W 12Volts
Blunet600
PostPosted: 12:11 - 13 May 2006    Post subject: Reply with quote
what are the bulbs that come with the nsr as standard then? because they are what i ahve in the front.
will i need to get some ba9s 10w then?
alains
PostPosted: 12:19 - 13 May 2006    Post subject: Reply with quote
the standart bulbs from honda are Ba15s in 10W 12V . if your new socket is in 9 diameter you need 10W 12V in Ba9s
The last post was made 19 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 50.88 Kb
