| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 23:53 - 11 May 2006 Post subject: Derestricted cagiva won't pass 70mph |
Hi, i've got a cagiva planet 125, and it won't pass 70mph. I've already posted on 125ccsportsbikes, but alas there are no results. The gearing is stock, and the engine is reaching maximum revs in 6th gear, but it just isn't pulling the top speed it should. The only thing i can think of is that my clutch is thoroughly shagged, as it's the only place i can think of such a differential between engine speed and rear wheel speed happeneing.
How far should i be able to release the clutch lever before it bites? Mine only bites about a centimetre before the end of it's travel.
Cheers
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| craigs23 |
 craigs23 Mr Muscle
| Jack_Cheese |
 Posted: 00:13 - 12 May 2006 Post subject: |
It bites well in the lower gears, but when i poen the throttle in 5th and 6th, the power and change in revs just don't seem to get transmitted to the road. I'm totally stumped!
| no_shad |
 no_shad Trackday Trickster
| Jack_Cheese |
 Posted: 00:26 - 12 May 2006 Post subject: |
There's a bit of free play in the clutch lever, and i can tell by the engine noise that it's revving out in 6th. I get it well up into the powerband in 5th, then up into 6th and it keeps revving, but not pulling.
The clutch moves about 7-8 mm back with no resistance, then a bit more and it releases the clutch. It doesn't feel right to me. Does it sound right to you?
| no_shad |
 Posted: 11:42 - 12 May 2006 Post subject: |
You may just need to adjust the clutch, try moving the biting point closer to the bar.
Pull the rubber cover back and screw the adjuster in towards the lever a bit to feed the clutch some slack.
If it's already tight against the lever then you'll need to adjust it at the other end on the engine.
https://img84.imageshack.us/img84/8240/clutch4ti.jpg |
| Jack_Cheese |
 Posted: 12:32 - 12 May 2006 Post subject: |
Sprockets are fine and the chain is new. The old front sprocket bolt was being held on by the sprocket cover, though which is why my old chain got so screwed so quickly. I'll have a go at adjusting the clutch if millenium don't pick it up on the MOT.
Cheers for your help guys!
| Jack_Cheese |
 Posted: 17:27 - 12 May 2006 Post subject: |
Well, it failed it's MOT today.
front tyre low
no rear reflector
brake pads and disc contaminated thanks to
bust oil seal in right fork
and the rear wheel bearings are shagged.
Got quoted £300 to set it right by MMC, but i'll get the work done at fazakerly garage for £150ish, and the front tyre at MMC because fazakerly can't do tyres apparently...
I think the rear wheel bearings may have been the problem, causing the clutch to slip at speed.
| cagiva gezzer |
| Jack_Cheese |
 Posted: 20:02 - 12 May 2006 Post subject: |
14t front 43t rear sprockets which translates to 95mph.
| peterfisher |
 peterfisher Derestricted Danger
 Posted: 20:26 - 12 May 2006 Post subject: |
First time i've heared of worn rear wheel bearings causing a clutch to slip  |
| Jack_Cheese |
 Posted: 21:01 - 12 May 2006 Post subject: |
If there's increased resistance, and the clutch is improperly adjusted, it becomes the main source of a differential between engine and rear wheel speed. Power doesn't make the rear wheel turn faster, the rear wheel speed is always proportional to the engine speed. The proportion changes depending on what gear your in, and is fixed in each gear. For the proportion to be out, there must be slip.
 Posted: 21:06 - 12 May 2006 Post subject: |
Wheel bearings will not cause clutch slip. Cost will be around £5 per bearing, with 2~4 bearings needing replacing depending on the bike (most bikes have one each side and one in the sprocket carrier, some bikes have 2 bearings on one side).
Not sure about the reflector. Have a feeling (maybe totally wrong) that the Planet rear light has the reflector built in.
Pads are cheap and easy to do. Disk just needs cleaning up with brake cleaner.
That just leaves the front tyre and the fork seal. Not sure on cost of a seal from Cagiva (Marzocchi seals for the Bimota are dirt cheap) and it might be a touch tricky to fit to a USD fork. However take the fork out and into a bike shop and most places will fit the new seal for you for a nominal amount.
| Jack_Cheese |
 Posted: 22:26 - 12 May 2006 Post subject: |
The only way i have for supporting the bike when the forks are off would be axle stands on the engine mounts, which i don't really want to do. The fork seals are £80 including fitting (2 hours labour) the bads are fairly new ebcHH sintered items, last time i decontaminated them using a pressure washer and lemon juice, and it worked a treat (obviously removed them first). I just decontaminated the disc with half a lemon and some sandpaper.
I've learned that my bike may be an import, the light is "kicking up on the offside" as the MOT put it, but the V5 says it was declared new at the time of first registration.
RE: the gearing table, i checked the gearing, and it should do 30 in first gear. I just revved it 'till it wanted to go BANG! and it hit 30 in first.
| scampypants |
 scampypants Renault 5 Driver
The last post was made 20 years, 142 days ago. Instead of replying here, would creating a new thread be more useful? |
