peugeot speedfight will not run
jpsl2
PostPosted: 20:37 - 05 May 2006    Post subject: peugeot speedfight will not run Reply with quote
Hi my name is joe and i have bought 2 speedfights from https://www.universal-salvage.com/ and ive got 1 perfect and sold and the other 1 has just been a night mare i cant get it to run at all, the lights work etc
it some times spark or runs for 10 seconds if im lucky any help on this would be greatly appreciated
Makaveli_Rydah
PostPosted: 22:21 - 05 May 2006    Post subject: Reply with quote
Need more details as to what's happening when you try to start it ...
You say sometimes it sparks ?
Change the plug and HT lead
On the kickstart is there much resistance / compression ?
Does the elctric start work ? if not pick up a starter motor - loads on ebay
Checked the fuses and starter relay ?
If the lights are on it doesn't really sound like an electrical problem but check anyway - i just had mine break down and blow fuses because on of the wires on the headlight had come loose - was lying against the frame and shorting it out when i tried to start
Bike History:- Vision / Phantom 100 / Aerox 100 / Runner VX125 / Honda VFR400 NC24 / Kwak ZX9R B3 / Honda CBR600 F / ZZR400 & K2 GSXR 750 / Suzuki VZ800
jpsl2
PostPosted: 01:40 - 06 May 2006    Post subject: Reply with quote
hi its had a new plug the ht seems fine compression is good it kicks fine and starter turns fine too but some times it will spark if i turn it on and off with the starter and brake held on if that makes any sens Laughing
critical_technique
PostPosted: 18:24 - 06 May 2006    Post subject: Reply with quote
charge the battery.
Makaveli_Rydah
PostPosted: 18:40 - 06 May 2006    Post subject: Reply with quote
Lack of fuel ? Blocked jet ? Air leak in the intake / manifold ? Clean the air filter or replce it ?
Could be a load of things to be honest you just need to eliminate the obvious stuff first
zorgman
PostPosted: 23:01 - 12 May 2006    Post subject: Reply with quote
did you get the ign keys with the scoot, a red and black.
how many flases with the red and how many with the black
The last post was made 20 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 46.29 Kb
