| Rookie |
 Rookie World Chat Champion
 Posted: 18:55 - 13 May 2006 Post subject: Spot the difference |
https://www.bikechatforums.com/files/0805_011.jpg
Spot the difference!
Aside from being horrifically dirty, and having a chunk out of the side of it, I found today that my old sprocket cover, which I finally got around to changing, was missing the spring present in the new (clean and shiney ) one.
What does it do? I haven't ridden the bike yet, I'm quite low on petrol. Again. The bike's always ridden well, and the clutch has been OK besides the slipping problem, and I'm sure the lack of this little spring can't be the cause of that. Though I wish it was.  |
| White Noise |
 White Noise Mr Dudwee
 Posted: 19:03 - 13 May 2006 Post subject: |
it looks like a spring to "pull" back the clutch cable to make sure that the clutch is fully engaged. not sure it would cause clutch slip but i'm not writing it off. i'm sure that kickstart could claify
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| Rookie |
 Posted: 19:06 - 13 May 2006 Post subject: |
Yeah, the mechanism of it seems to be that it will pull the wire further into the sprocket cover. I'm not quite sure on how the wires work when it's all shoved together, so I don't know how the missing spring is significant.
Just to clarify; in the old sprocket cover, the thing which the clutch cable hooked into moved freely either way. No resistance. |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| Guest |
 Guest Brolly Dolly
 Posted: 21:25 - 13 May 2006 Post subject: |
https://img.photobucket.com/albums/v471/fastfitter/Cat.jpg
Your clutch cable pulls upwards (left in the pic) and the worm drive moves out to push the clutch pushrod and operate the pressure plate against it's springs.
When you let go of the lever, the pressure plate will push the pushrod back and close the worm up again. The little spring is just an extra to make sure the worm returns to 'rest' and the slack in the cable is taken up, otherwise you'd get a floppy lever if the worm got stuck up with chain gunge or what-have-you. |
The last post was made 20 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
