Respeck to the Fuzz
EDBANGER
PostPosted: 19:16 - 13 May 2006    Post subject: Respeck to the Fuzz Reply with quote
& thats not the boys in blue but BCF's very own Fuzz. Helped me balance my carbs today. The cat threw us a few curve balls but we bodged our way around them with a few handy plastic thingymabobs. Runs nice and smooth now!! The man really does know what he's doing Thumbs Up Bloody typical when it came to going for a ride it pissed down with rain Sad
Also mucho thanks to Fuzz's mum who provided a damn fine ham salad sanga.
We shall only mention the forgetting to turn the fuel tap back on very quietly down here Very Happy
If you can't spot the sucker in your first half hour at the table, you are the sucker.
colin1
Captain Safety
PostPosted: 19:21 - 13 May 2006    Post subject: Reply with quote
Thumbs Up to fuzz
i have heard of balancing carbs, im guessing you make sure each piston is getting the same amount of fuel.
So does the bike feel better after its been done ?
Rookie
PostPosted: 19:22 - 13 May 2006    Post subject: Reply with quote
Oo! Carb balancing!
Fuzz, don't want to trek over here and help me, do you? Wink
Ed, do you find it makes pulling away better? I have a feeling mine need doing because of a nasty problem of the power completely dropping off intermittently when I pull off, causing me to stall.
How hard was it then?
EDBANGER
Well they wern't too far out in the first place but it does seem smoother now & ticks over a little nicer. But saying that, that could be my imagination. Confused
phantomtek
Lil Joe Tek
PostPosted: 19:36 - 13 May 2006    Post subject: Reply with quote
Does anyone in the Leeds area want to do mine? Very Happy
Well played fuzz old chap, very kind of you. Thumbs Up Mr. Green
EDBANGER
PostPosted: 20:14 - 13 May 2006    Post subject: Reply with quote
Rookie wrote:
Oo! Carb balancing!
To be fair it wasn't that hard at all, take the tank off, remove the airbox, attach vacuum guage to the four hoses that run either side of the carbs, twiddle screws whilst the bike runs until all guages read the same. Taaaa daaaaaaaaa no problem.
Pulling away seems to be the same, but then again it wasn't a problem in the first place.
fuzz
PostPosted: 22:10 - 13 May 2006    Post subject: Reply with quote
Glad it's working well for you. I actually helped someone! Surprised There's a first for everything I suppose.
I'd never worked on an IL4 before, so it was a learning experience for me aswell. So much easier to work on than the SV in that respect.
TOM M
PostPosted: 22:20 - 13 May 2006    Post subject: Reply with quote
Dont suppose you fancy doing a zxr4??? Razz
Now owner of a 1200 Bandit
Hooky
PostPosted: 23:14 - 13 May 2006    Post subject: Reply with quote
Any chance you could pop down to Bournemouth and try to balance the wife Exclamation Exclamation Rolling Eyes (shes running rough and lacking in low down power) Silence Hand
fuzz
PostPosted: 11:54 - 14 May 2006    Post subject: Reply with quote
I think that's how it works. Because it's a CV carb, the slide works on pressure, rather than by the throttle on a slide carb. As the throttle is turned, it opens the butterfly valve allowing more air to pass through the venturi. This creates a difference in pressure in the vacuum chamber and the slide rises. If a pair of carbs are not balanced, the butterfly valve opens more on one than the other, creating differening pressures above the slides and allows more fuel to flow into it than the other.
I'm sure Keith will be along soon to correct me Mr. Green
fuzz
PostPosted: 10:40 - 15 May 2006    Post subject: Reply with quote
Just a thought actually. When we were balancing the carbs, the rev needle was doing some odd things. It would sit at idle speed, drop to zero, and then smoothly go up to about 8k, then repeat. Any ideas what this was? It stopped doing it once everything was put back properly.
Have you noticed it happen since?
Adam_P
PostPosted: 11:38 - 15 May 2006    Post subject: Reply with quote
What are these 'carb' things you speak of?
Pfft, fuel infection, its the way forward.... Laughing Wink
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
The last post was made 20 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 74.67 Kb
