Getting into Biking: Mechanical knowledge?
Unreal
PostPosted: 22:57 - 16 May 2006    Post subject: Getting into Biking: Mechanical knowledge? Reply with quote
I'm totally new to the world of biking, and I'm wondering how much mechanical/technical knowledge is required to be adequate. How much compared to say, owning a car? I wouldn't be looking at biking necessarily as a hobby, more as a means of transport, but I'd probably get into it as I go along.
Thanks!
PostPosted: 23:00 - 16 May 2006    Post subject: Re: Getting into Biking: Mechanical knowledge? Reply with quote
You can get along just following the basics in the owners manual and taking the rest to a garage.
Though if you've got the will, there's plenty of easy things to learn and build from there.
PostPosted: 23:15 - 16 May 2006    Post subject: Reply with quote
At a minimum I would say you need to be able to:
Check the oil level and top it up.
Top up the coolant and brake fluid if necessary.
Adjust the chain tension.
Check the tyre pressures.
If it is a 2-stroke, remove, clean and replace the sparkplug.
SilvaRizla
PostPosted: 23:23 - 16 May 2006    Post subject: Reply with quote
^^^^^^^^ He forgot to mention all of which are a piece of p*ss
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
Unreal
PostPosted: 23:51 - 16 May 2006    Post subject: Reply with quote
Fair enough then, thanks a lot guys!
dainesefreak
PostPosted: 11:38 - 17 May 2006    Post subject: Reply with quote
Know how to fill up with petrol and whether your bike has a reserve tap and how to use it. Wink
Jamie.
PostPosted: 14:07 - 17 May 2006    Post subject: Reply with quote
Get a haynes manual and your set Laughing
FreshAL
Sir Crashalot
PostPosted: 14:39 - 17 May 2006    Post subject: Reply with quote
You'll get taught the very basics if you do DAS.
Simple mechanical knowledge like Stinky mentioned is now part of the test.
The last post was made 20 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 54.4 Kb
