Helmet lining/padding and helmet sizes
TeX
PostPosted: 11:32 - 17 May 2006    Post subject: Helmet lining/padding and helmet sizes Reply with quote
hi, just wandering what the difference is between different sizes of helmet. Is the helmet exactly the same just with extra or less padding to fit the head?
The reason I ask is cause I want to buy a helmet. I've tried on an XL and it fits fine. However I cannot find one in the colour and size I want, but can find a Large size. So thinking of just buying the Large and replacing the padding with XL size padding. Would this just be the same as buying an XL helmet or is there something else different?
Bendy
Mrs Sensible
PostPosted: 11:42 - 17 May 2006    Post subject: Reply with quote
I would imagine the internal polystyrene structure is more to do with the size than the fabric padding, and that would be impossible to change.
Have you looked online? Since you know the size fits you, I'm sure somewhere would be able to order you the correct helmet.
dainesefreak
PostPosted: 11:47 - 17 May 2006    Post subject: Reply with quote
Some manufacturers tend to vary the shell size and shape between helmet size and model. You might be ok with only one size difference, the shell may be the same. Personally I'd keep trying them on and find one I like without having to alter it. Or as Bendy said, if you know that the helmet fits you properly then shop around for the colour you are after. It will probably be cheaper anyway and buying replacement pads can be expensive.
Steve H
Helmet's are different dimensions as a whole not purely in inner shell size.
They're made specifically to do a job and to amend the internal linings in anyway would damage the integrity of the helmet and its' protective properties would be affected.
Looks like you're gonna have to your adapt your clothing ensemble to match the helmet Confused
Oh and XL Shocked What have you got? A soddin' medicine ball for a head Wink
Mellow Yellow
TeX
PostPosted: 12:20 - 17 May 2006    Post subject: Reply with quote
guess I should mention that it's a fairly cheapo KBC helmet. I'm guessing they're less likely to change the size of the helmet (in or out) to keep costs down. I did try the large on and it wasn't too bad, bit tight on the cheeks and quite tight to get on (to get past the padding at the bottom) but around the top it felt the same as the XL. I've seen some padding for 10 quid which is quite cheap. Apparantly it's last years model and shops have stopped selling them, I'd be suprised if they sold out so what they do with them I don't know but they don't sell them anymore.
I do have a fairly big head but I did measure it and it's only like 58-59 which would put in the Med-Large category but I've tried large helmets and some of them I can't even get on let alone them being too tight. Anybody else have the same problem? maybe it's just the shape of my head, it's quite round but still the place you measure should be the widest part of the head.
dainesefreak
PostPosted: 12:32 - 17 May 2006    Post subject: Reply with quote
Have a look here;
https://www.harpersraceshop.co.uk/cat7_1.htm
https://www.bbbikeshop.co.uk/acatalog/KBC_HELMETS.html
https://www.hellmart.com/HelmetInfo/KBC/index.html
https://www.google.co.uk/search?hl=en&q=kbc+helmets&meta=
Ebay might be worth a look but I'd be looking at new new only. Lots of bike stores sell out going models on there. Thumbs Up
fuzz
PostPosted: 13:10 - 17 May 2006    Post subject: Reply with quote
Not so. Most manufacturers only have a few shell sizes and vary the amount of padding to fit different size heads. AGV and Arai are two manufacturers I know of that definately uses this method. There are also places that offer custom sizes, by taking a shell size that best fits your head, and altering the padding inside them for a perfect fit.
When I first tried on the TiTech, I picked up a large and couldn't even put it on. I tried the XL and it seemed just right. For some reason, I tried the L again and found it to be a much better fit. Try it a few times before you decide you need the bigger size, because I could have bought a helmet that didn't fit properly.
feef
Energiser Bunny
PostPosted: 15:07 - 17 May 2006    Post subject: Reply with quote
bear in mind the padding will compress in time. As long as the helmet isn't uncomfortably tight, I'd consider wearing the large and seeing how it goes.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
colin1
Captain Safety
PostPosted: 22:30 - 17 May 2006    Post subject: Reply with quote
if an outgoing model is half the price of a new one, that could be well worth getting in my opinion
The last post was made 20 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 64.2 Kb
