| greatmoorred |
 greatmoorred Nearly there...
| mr.z |
 mr.z World Chat Champion
 Posted: 17:01 - 20 May 2006 Post subject: |
(Guessing)
one will be a breather tube? probably going to the airbox maybe?
one will defenately be going to the carbs (this wil be the gusher)
one will be a vaccum tube
if your fuel tap is switched to off and the vaccum tube isn't being.. vaccumed. then no ful should come out (at least not allot)
best bet is take each off carefully, bend the tube in half so it will prevent any sudden pishing of fuel, do it one by one, if one is pishing then put it back on and rethink...
make sure you have somewhere to put the tank without damageing the tap or risking it falling over
It really isn't hard, get some help, if your really worried get some propper hose cut off clips (most car places sell them), or big strong bullclips and some rag. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| greatmoorred |
 Posted: 17:23 - 20 May 2006 Post subject: |
Ah, if only it had an OFF postion !!
Im going to risk it, it only got about 5 litres in...... |
| doggone |
 doggone World Chat Champion
| Rookie |
 Rookie World Chat Champion
| edd |
 edd Nearly there...
 Posted: 01:12 - 21 May 2006 Post subject: |
youll have a vacuum fuel tap, so it will be "prime, reserve, on" right?
turn it to either on or reserve and no fuel will flow. Unbolt the tank, lift it as far as it will go and unclip the 2 pipes going to your fuel tap, there should be a thin one (vacuum hose) and a fat one (fuel hose) a little bit of petrol will piss out probably, if youre concerned put a rag under it. ____________________ Bluespark Automotive - Diesel Tuning for Performance and Economy |
The last post was made 20 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
