what's the best way to..
Simple
PostPosted: 15:42 - 22 May 2006    Post subject: what's the best way to.. Reply with quote
not sure if this should go in the workshop section..
...... put my new tank pad on my gpz?
I know to clean the tank and make it dry/free from grease, but I always get lumps and bumps even when slowly peeling the backing off at an angle
anyone got a how to guide for numpties?
tips...?
not sure if this should go in the workshop section..I'm sure a mod will move it if it should
simple
Insta - FemFeral
veeeffarr
PostPosted: 16:05 - 22 May 2006    Post subject: Reply with quote
I just used petrol to clean the gunk off, let it dry.
Peeled backing off of tankpad at the bottom (About 1 inch of adhesive exposed.
Position and stick
Slowly peel backing paper up whilst smoothing newly exposed sections down.
Apparently you can use washing up liquid (on the tank before you put the pad on) to give you some maneuverability once you've stuck the pad on.
Method
PostPosted: 16:33 - 22 May 2006    Post subject: Reply with quote
Hun,
All you gota do is get a rag out, rub it over the tank, rip back the paper and slap it on.
Simple as that Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Method
PostPosted: 16:34 - 22 May 2006    Post subject: Reply with quote
Not a fan of your paintwork then? Rolling Eyes Laughing
veeeffarr
PostPosted: 16:39 - 22 May 2006    Post subject: Reply with quote
Well as long as you wipe it off and let it dry I don't see the problem.
Method
PostPosted: 16:41 - 22 May 2006    Post subject: Reply with quote
Your quite touchy at times aint ya? Wink
Was just saying, as every time i get petrol on my tank, it ends up fading the paintwork and taking the shiney finish off it.
Simple
PostPosted: 16:42 - 22 May 2006    Post subject: Reply with quote
Petrol is fine to use, as is a little diesel however I use white spirit usually.
I've applied them before but because this one is clear it will show all bubbles really badly.
it's going to look alot better than the black bale patching tape thats on there at the moment hehe
simple
Insta - FemFeral
Hex
Party Boy
PostPosted: 16:44 - 22 May 2006    Post subject: Reply with quote
Bit of soapy water solution in a spray bottle.
Wet the tank and apply the tank pad, then simply move it so its in the right place and squeegee the air bubbles out.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
phill.c
PostPosted: 16:58 - 22 May 2006    Post subject: Reply with quote
don't use petrol and don't use washing up liquid, it you want to stick it on then move it around for the positioning then spray water on it first but only a tiny amount, this is what you do for decals.
to get the gunk off use a cleaner and just scrub a dub dub for abit. if its really hard to get off, heat it with a hair dryer.
phill
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
extreme3d
PostPosted: 18:04 - 22 May 2006    Post subject: Reply with quote
As above, use a bit of mild soapy water, but also place a non permanent mark at the bottom and top centre of both the tank and pad to aid in lining it up. Also remove the seat and place the tank pad just below the seat line for additional protection like this:
https://i10.photobucket.com/albums/a129/extreme3d51/untitled.jpg
Simple
PostPosted: 19:12 - 22 May 2006    Post subject: Reply with quote
Okay, it's done, looks crap dispite cleaning the area with white spirit then wiping it with water and drying it.
using a hair dryer to heat it up and the tank and peeling the backing off stage by stage.
because it's clear it's show all the glue underneath Thumbs Down Sad
O well, it'll do it's not like its a brand new sports bike or anything /shrug.
Insta - FemFeral
McGee
O RLY?
PostPosted: 19:15 - 22 May 2006    Post subject: Reply with quote
Dont worry I got a clear one on my gsxr and after leaning on it a few times and the heat getting to it all that goes away Thumbs Up
Its pronounced Jixxer!
Simple
PostPosted: 19:19 - 22 May 2006    Post subject: Reply with quote
heat? this is England.. Confused
I'll just leave it, it goes well with my smashed belly pan and buckled radiator /shrug/
Insta - FemFeral
McGee
O RLY?
PostPosted: 19:21 - 22 May 2006    Post subject: Reply with quote
Laughing I love it Thumbs Up
ram_doom
PostPosted: 19:47 - 22 May 2006    Post subject: Reply with quote
Mcgee you are so in there! Wink My carbon tank protector thingy was squiff so I cut it to shape IN SITU Shocked with a stanley knife! and didnt scratch le paintwork Wink
TL1000s, KDX200
Golf_gti
PostPosted: 19:48 - 22 May 2006    Post subject: Reply with quote
i fitted mine within 5 miuntes off buying it!
i cleaned the tank placed it on, lined it up by looking stright down onto it and then went to the back of the bike looked at it, line dit up and moved all air bubbles out!!
its simple Simple lol!
cheers Thumbs Up Cool Razz
Wink-Dan-Razz
Early 2006 MY TZR 50 2004... was ready and i was free!!....well until my tank ran out lol!!
extreme3d
PostPosted: 19:51 - 22 May 2006    Post subject: Reply with quote
Mcgee's right, just in this country you will have to use artificial heat. Gently warm the marked areas up and the glue should soften enough for you to smooth the marks out.
Simple
PostPosted: 20:08 - 22 May 2006    Post subject: Reply with quote
yes but is yours clear?
if not bog off because its not simple, I am, it's not.
Have tried using hair drier to get the marks to go away, they large air bubbles they are where the glue has gone white.
Insta - FemFeral
The last post was made 20 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 105.4 Kb
