Author |
veeeffarr |
 veeeffarr Super Spammer
Back to top |
ecclestone |
 ecclestone L Plate Warrior
Back to top |
Kickstart |
 Kickstart The Oracle
Back to top |
veeeffarr |
Back to top |
Guest |
 Guest Brolly Dolly
Back to top |
jam125 |
 jam125 Borekit Bruiser
 Posted: 23:56 - 22 May 2006 Post subject: |
if its like mine the front sproket can twist a bit on the shaft and cause a clunk.
There are 3 bolts on the sproket cover one in hole that you will need a socket and extention to get at, one at the top of the cover and one just above the gear lever which is a pig to get out in a cramped shed. i dont know if it will be exactly the same beacase i have the cheapo hongdoo  |
Back to top |
WavyGravy |
 WavyGravy Scooby Slapper
Back to top |
veeeffarr |
Back to top |
veeeffarr |
 Posted: 20:14 - 23 May 2006 Post subject: |
Back to top |
WavyGravy |
Back to top |
Kickstart |
Back to top |
veeeffarr |
 Posted: 22:26 - 23 May 2006 Post subject: |
Kickstart wrote: | Hi
Counts that clip out.
Can you take another picture of the sprocket, with a more direct view point? Difficult to see, but it looks like the teeth are hooked in that picture. If so rotating the wheel backwards would give a click.
Beyond that I would be tempted to give the bike an oil change, and check the oil that comes out carefully.
Keith |
Hi Keith,
Sorry, they're not hooked, it's just the way the picture has come out.
Do you think the break in the gasket is a lot to worry about? I managed to assemble it again in one piece.
The retainer is there.
I have a bottle of GPS here ready for the oilchange.
My oil dipstick has little chips of plastic out of it, don't know what to make of this as I am very careful with it (Take it out, wipe filler port, rest on kitchen towel, put in engine, check, and put back).
It sounds like the click it coming 'within' the engine.
I didnt remove the kickstart when I took the exhaust off, no need to.
Toby |
Back to top |
veeeffarr |
Back to top |
WavyGravy |
 Posted: 23:49 - 23 May 2006 Post subject: |
I'm still leaning towards something to do with the kickstart,
i'd check your oil and your mesh filter as kickstart suggested, those dipstick bits must have gone somewhere.
when you spin the wheel have you tried putting your finger against the centre of the spindle and felt it 'bump' when the click happens (ignition off and keys out while you try this) .... or grab the kickstart and do the same thing, feel the bump?
Wouldnt worry too much about the gasket, its not to keep oil in but to keep water out, as long as theres no gap you'll be ok, if there is a gap be inventive.
Has the engine been split before you got it? (tell tale signs are the bolts that hold crankcases together)
I wouldnt worry about splitting the engine yourself other than for learning exercise, you can pick up second hand engines for less than the price a honda dealer will charge you for a few worn cogs if thats what it turns out to be, i still think its got something to do with the kickstart, especially if the engines been split in the past, theyre a real git when reassembling because the return spring pulls the assembly over to one side while youre trying to line up the gears and fit the 2 halves together, the slightest movement and something goes where it shouldnt ____________________ 1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off" |
Back to top |
WavyGravy |
Back to top |
veeeffarr |
 Posted: 23:53 - 23 May 2006 Post subject: |
WavyGravy wrote: | I'm still leaning towards something to do with the kickstart,
I wouldnt worry about splitting the engine yourself other than for learning exercise, you can pick up second hand engines for less than the price a honda dealer will charge you for a few worn cogs if thats what it turns out to be, i still think its got something to do with the kickstart, especially if the engines been split in the past, theyre a real git when reassembling because the return spring pulls the assembly over to one side while youre trying to line up the gears and fit the 2 halves together, the slightest movement and something goes where it shouldnt |
Only problem in me splitting the engine is that I need to ride every day.
The main thing that is worrying me is that I'm not picking up any skills from working with the bike, I'm just making a ham fisted hash of things.
If I apply these skills to a bigger bike, it's not going to last very long. |
Back to top |
veeeffarr |
Back to top |
WavyGravy |
 Posted: 00:28 - 24 May 2006 Post subject: |
its just a process of elimination, as its happening with the engine off and in neutral its not a problem with the top half or with the crank. the fronthalf is connected to the back half via the clutch, assuming the kickstart is fully disengaging the clutch can be discounted because the noise is there in neutral.
That just leaves the gearshaft/layshaft assembly or something has fallen into the oil filler. unless hondas build quality has gone down the swannee i'd swear those gearboxes are the least stressed parts of the engine - unless someones been reading about clutchless shifting on a forum not a million miles from here j/k
when you get a chance tomorrow mark one of the teeth on the final drive and see if the noise happens at the same place each time the things rotated, the shafts inside the engine spin at different rates, if it clunks in the same place it means the problems probably on that drive shaft ____________________ 1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
Back to top |
veeeffarr |
 Posted: 00:32 - 24 May 2006 Post subject: |
WavyGravy wrote: | its just a process of elimination, as its happening with the engine off and in neutral its not a problem with the top half or with the crank. the fronthalf is connected to the back half via the clutch, assuming the kickstart is fully disengaging the clutch can be discounted because the noise is there in neutral.
when you get a chance tomorrow mark one of the teeth on the final drive and see if the noise happens at the same place each time the things rotated, the shafts inside the engine spin at different rates, if it clunks in the same place it means the problems probably on that drive shaft |
Great idea,
Thanks!
Also,
In order to take the cases off, I had to use a massive amount of force on an 8mm spanner (thank god for halfords pro, didn't even bend)
They then came off with a crack, is this normal? There didn't seem to be any damage.
I did them up again with spanner until they resisted a tiny bit, then a quarter turn (Nice and tight, but not too tight)
Should this be ok?
Thanks
T |
Back to top |
veeeffarr |
 Posted: 10:12 - 24 May 2006 Post subject: |
I can't hear it when the bike is in gear, this might be because the engines quite loud tho But I'm pretty sure it doesn't make noise  |
Back to top |
jam125 |
Back to top |
Vin |
 Vin World Chat Champion
Back to top |
veeeffarr |
Back to top |
The last post was made 19 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
