Cleaning Downpipes?
veeeffarr
PostPosted: 12:08 - 24 May 2006    Post subject: Cleaning Downpipes? Reply with quote
Hi,
I have loads of dark brown crapola on my downpipes, which needs cleaning... Anyone got any suggestions? It's a stock CG125 so I believe it's chrome plated mild steel.
Thanks,
T
Bendy
Mrs Sensible
PostPosted: 12:23 - 24 May 2006    Post subject: Reply with quote
Why does it need cleaning?
JeffT
I find autosol on warm downpipes is the best way.
Brings my dull brown downpipes back to their original shiney niceness!
Sephiroth
I asked this a while ago (still haven't got around to it) and a few people replied.
One was to get fine wet 'n' dry and go for gold on it, another was autosol, I think.
veeeffarr
PostPosted: 12:25 - 24 May 2006    Post subject: Reply with quote
Because I may be selling it Wink
Sephiroth
PostPosted: 12:31 - 24 May 2006    Post subject: Reply with quote
Why? Razz
Sephiroth
PostPosted: 12:32 - 24 May 2006    Post subject: Reply with quote
Why? Razz
veeeffarr
To pay for a GS500E and my DAS Wink
Sephiroth
PostPosted: 12:36 - 24 May 2006    Post subject: Reply with quote
Good boy Mr. Green.
Nath
PostPosted: 12:43 - 24 May 2006    Post subject: Reply with quote
Wet and dry, on a chrome pipe? Rolling Eyes
Hard livin', hard luck.
veeeffarr
PostPosted: 12:51 - 24 May 2006    Post subject: Reply with quote
That's what I thought, it's only a thing plating isn't it?
I've used autosol on it before and it's been fine (On the end can) but there's a LARGE buildup of shit on the pipes.
Sephiroth
PostPosted: 12:54 - 24 May 2006    Post subject: Reply with quote
I was told Rolling Eyes.
Giev it a go, I couldn't find any Autosol down Halfords Sad.
veeeffarr
PostPosted: 12:57 - 24 May 2006    Post subject: Reply with quote
Hein Gericke do it for a coupla quid a ch00b
Nath
PostPosted: 13:03 - 24 May 2006    Post subject: Reply with quote
Even the most fine wet and dry will tarnish and scratch your chrome. If the the exhaust pipe is really mucky then clean it as you would any other part of the bike, if the dirt doesn't want to shift then a green scourer pad thing should do it (don't go overboard though as it will scratch the chrome).
When it is clean, it is up to you whether or not you want to polish it (with autosol).
Rookie
PostPosted: 13:07 - 24 May 2006    Post subject: Reply with quote
craigs23 recommended the wet 'n' dry method, and we all know he has the best looking downpipes on here. I'm going to try it, but I've found Autosol and a drill with a buffing pad has worked OK, though it takes ages.
Bendy
Mrs Sensible
PostPosted: 13:09 - 24 May 2006    Post subject: Reply with quote
Toby, Toby, Toby, we all know what's going to happen. Firstly, a trip to Halfords to buy Autosol will end in the purchase of a comprehensive set of polishing mops and a drill with which to power them. You'll remove the downpipes in order to do a better job and there'll be some kind of gasket/exhaust stud/wobbly fitting clamp thing disaster which will see a dozen tear-stained posts before another hundred quid is haemorraged from your bank account in order to repair it.
Lets sleeping dogs lie and mucky downpipes remain that way.
Simple
PostPosted: 13:20 - 24 May 2006    Post subject: Reply with quote
I angle grind mine back to bare metal removing all rust, then prime and spray twice before putting back on the bike.
However mine were never chromed,
A try some autosol on them applied using an old shirt or similar (reducing cost) avoid buttons and zips Razz
B if the tarnishing has eaten into the chrome, then you're not going to win, you can either remove the chrome with a £15 angle grinder from a car boot ( I would) and spray the exhaust with exhaust paint £6 a can, and the primer £4 a can.
C or you could contact a breaker, I think for that amount (£25) you could get an exhaust form a CG?
D or... save your money and do your test, sell the bike and get a bike with stainless pipes Laughing
Simple
Insta - FemFeral
veeeffarr
PostPosted: 13:22 - 24 May 2006    Post subject: Reply with quote
I've had autosol for ages.
Gaskets, collet and cylinder head clamp are on order from Dave Silver Smile
veeeffarr
PostPosted: 13:24 - 24 May 2006    Post subject: Reply with quote
Only parts I've bought for my bike so far are a battery and chain and sprockets, so that's unfounded Smile
craigs23
Mr Muscle
PostPosted: 14:15 - 24 May 2006    Post subject: Reply with quote
Chrome plating is a different kettle of fish in comparison to bare metal.
What kind of degredation are you referring to? Has the chrome come away, or just become disfigured with surface rust? Localised polishing might work, but I'm not sure whether Autosol would be man enough to shift serious rusting.
ZRX61
Victor Meldrew
PostPosted: 16:53 - 24 May 2006    Post subject: Reply with quote
Good fucking grief, this is certainly the place for advice on how to fuck up the finish. Rolling Eyes
Take the pipe off, spray it with oven cleaner, rinse & repeat.
veeeffarr
PostPosted: 17:06 - 24 May 2006    Post subject: Reply with quote
Ta,
I'll see if I've got some in.
T
PS: Essential to remove the pipe or not? I'll just mask off vulerable places with tape/newspaper as my crush washer is still on order.
zaknafien
PostPosted: 17:56 - 24 May 2006    Post subject: Reply with quote
Shifty Doh! Brick Wall Crying or Very sad
02 Firestorm.
nick.h
PostPosted: 18:19 - 24 May 2006    Post subject: Reply with quote
I will be attempting my downpipes tommorrow, when the pipes come off, to service the bike.
I have prepared in getting some autosol (from halfords!), works well from the little bit i did earlier..
Pictures shall be posted, if its any good.
Nick
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
veeeffarr
PostPosted: 20:57 - 24 May 2006    Post subject: Reply with quote
Mine's currently sat in the garden, covered in oven cleaner.
Doesn't seem to be an exhaust gasket in there
https://s66.photobucket.com/albums/h277/th0r0n/NoGasket.jpg
Can
https://s66.photobucket.com/albums/h277/th0r0n/Can.jpg
Pipe
https://s66.photobucket.com/albums/h277/th0r0n/Pipe.jpg
The last post was made 20 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.18 - MySQL Queries: 15 - Page Size: 126.2 Kb
