Mental?
killa
Won't Shut Up
PostPosted: 09:37 - 25 May 2006    Post subject: Mental? Reply with quote
The VFR is still in my lock up, she wont run, I’ve had her looked at by a mechanic but he reckons the electrical problem is well over his head.
The other guy who was meant to pick it up called me to say his missus had a miscarriage, so work is not on the cards, which is fair enough.
My insurance is still running, they think the bike is still worth £2500....
Thinking
dainesefreak
PostPosted: 09:39 - 25 May 2006    Post subject: Reply with quote
One problem. You'd screw your NCB and probably not be able to insure the ZX7R come renewal time.
the grim reaper
PostPosted: 10:04 - 25 May 2006    Post subject: Reply with quote
Electrical problems are often over mechanics heads, the electrical part of my mechanics course was so poor that I ended up teaching part of it (I'm a leccy engineer).
The problem these days with mechanics (especially car ones) is that all they do for electrical problems is to plug in a diagnostic box and then replace the part it tells them to replace. Often the problem is solvable.
Grim
Jack_Cheese
PostPosted: 10:07 - 25 May 2006    Post subject: Reply with quote
get the pannels off it, head to the scrappy and get a new loom and CDI.
Failing that, i'd recomend napalm, or a nice mixture of propan1,2,3triol and nitrous acid, depending on incendiary/explosive qualities desired.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Walloper
PostPosted: 10:16 - 25 May 2006    Post subject: Reply with quote
Grim
I beg to differ Sir.
Electrical problems are SOMETIMES over SOME mechanics heads. Laughing
If there is no spark then the ECM is faulty.
Only need to ensure it is getting a 12V supply and good grounding.
If supply etc. is OK then the ECU has a problem.
Which would be over some electrician's heads too Laughing
Harold_Shand
PostPosted: 10:35 - 25 May 2006    Post subject: Reply with quote
You could leave it outside your house unlocked.
You don't get your hands dirty.
They won't know it's a non runner until they've smashed the ignition barrel, dropped it etc...
feef
Energiser Bunny
PostPosted: 10:40 - 25 May 2006    Post subject: Reply with quote
Jack
even easier, is polystyrene dissolved in petrol, with a dash of benzine. almost exact same properties as napalm Very Happy
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Klause
PostPosted: 10:43 - 25 May 2006    Post subject: Reply with quote
Grim
There could be loads more problems. If you havn't got a spark you need to check your spark plug, plug cap resistance, HT lead, primary and secondary windings in the coils... loads of stuff before you blame it on the ECM/ECU.
Your one of those people that replaces and expensive black box when it was a faulty plug cap or something! Razz
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Walloper
PostPosted: 10:49 - 25 May 2006    Post subject: Reply with quote
Shocked
You over generalize.
Of course before forking out for an ECU you'd have done that.....
But if a mechanic doesn't know how to do that then he is not a friken mechanic is he? Laughing
Klause
PostPosted: 10:54 - 25 May 2006    Post subject: Reply with quote
I believe you.
colin1
Captain Safety
PostPosted: 11:01 - 25 May 2006    Post subject: Reply with quote
im glad i dont have a honda 400, they all seem to get electrical problems
how about just replacing the wiring loom 2 on ebay at about a tenner each ?
https://search.ebay.co.uk/search/search.dll?from=R40&satitle=vfr400+wiring+loom
feef
Energiser Bunny
PostPosted: 11:06 - 25 May 2006    Post subject: Reply with quote
I'll swap you for a Running FZR400.
cosmetically needs a tidy, but it runs Very Happy
a
Walloper
PostPosted: 11:09 - 25 May 2006    Post subject: Reply with quote
a
Pictures pleeeze Laughing
the grim reaper
PostPosted: 13:54 - 25 May 2006    Post subject: Reply with quote
Walloper wrote:
Shocked
You'd be surprised. I've stopped a mechanic in a main dealer from attaching a battery negative terminal first before now, he was just about to attache the positive when I pointed out that he was about to send a nice voltage spike through the bike's electrics.
I have also seen bodges like you would not believe on alarms and heated grips. The Varadero I (briefly) owned a while back needed the whole lighting circuit rewiring because of heated grips fitted by a Honda mechanic.
I was generalising when I said that electrical problems are often over mechanics heads but there are a scary number of mechanics out there who don't have a clue when it comes to the sparky stuff.
Grim
Method
PostPosted: 14:31 - 25 May 2006    Post subject: Reply with quote
Nah your completely right.
I worked at VW for a year, and during that year i was offered the chance to become their "Electrical Expert" on premises because none of the others had the faintest idea, apart from the Master Tech who was too important to do stuff on normal cars Wink
Your completely right about the computer too, most will throw that on and if that doesnt come up with a problem, its a quick check for blatent wires hanging down around the rough area and then its "Nah cant fix it, we need more investigation time, get the master tech on it"... was pathetic realy. I knew more than them and i had just started...
I mean im no expert on electrics, but i would suggest getting the pannels off and taking a quick look. You know what an engine needs to run, check you have a spark first, then just trace it back, use a V/M if you need.
The worst thats gona happen is that you end up in the same position your at now, but with the knowlege its not something you can fix. Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The last post was made 20 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 92.03 Kb
