NSR 125 - Just had service...HELP -
Qc dragon
PostPosted: 20:16 - 25 May 2006    Post subject: NSR 125 - Just had service...HELP - Reply with quote
Sad Ive just taken My NSR 125 for a full service, the carb has all been reset and all the usual stuff has been done, its been fully de-restricted at the garrage and they have set the bike up accourrdingly, however I rode the bike home fine, when I got to my garage and dropped it into neutral.. it died and Now it wont start, what do I do?
alains
PostPosted: 20:23 - 25 May 2006    Post subject: Reply with quote
check fuel line and tap position . check also kill switch , never use it to stop the engine , it's only an emergency cut on ignition
Qc dragon
PostPosted: 20:47 - 25 May 2006    Post subject: Reply with quote
have done, and i dont use the kill switch, By died i mean the bike just well... died by its own accord
and the fuel is set to on, because I rode it to my garrage, (3miles from service)
alains
PostPosted: 20:55 - 25 May 2006    Post subject: Reply with quote
so take off your sparkplug . if it's wet it's ignition problem and dry it's a fuel line problem
NSR Mick
PostPosted: 21:24 - 25 May 2006    Post subject: Reply with quote
Its possible to have enough fuel in the pipe and carb to get you 3 miles.
robbie21mcn
PostPosted: 23:31 - 25 May 2006    Post subject: Reply with quote
would doubt it. check your getting a spark by cranking over the bike with the tip of the plug attached to the coil against the chassis but be very careful to insulate yourself from the plug by holding it with something wooden or plastic (salad tongs lol)otherwise you will get a bit of a jolt. chances are if your plugs wet just give it a heat with a lighter to get rid of the excess fuel. if it doesnt spark maybe your coils not working or maybe your plugs just plain beat!!!
fzr 600 its yellow but its no banana!!!!!!
Finglonga
PostPosted: 23:54 - 25 May 2006    Post subject: Reply with quote
If it is the garage that serviced it wants burning down.
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 50.83 Kb
