Nsr 125 going slow
aratous
PostPosted: 13:27 - 25 May 2006    Post subject: Nsr 125 going slow Reply with quote
I bought my Nsr 125r a few months ago and de-restricted it, new exhaust and took the plate out that was between the carb and reeds. i also put a new o-ring chain on it, however it will still only do 70 - 75 it revs to bout 9 - 10k in 5th then when i change to 6th it just seems to have no power and wont get anymore speed and just slowly slows down so i have to change back to 5th. Anyone got any ideas why it has no power?
code guru
PostPosted: 15:01 - 25 May 2006    Post subject: Reply with quote
did u re jet the carb? 135 jet for a std de restricted pipe or 138 for sports pipe, 42 idel jet and 65 power jet
maxpower125
PostPosted: 15:31 - 25 May 2006    Post subject: Reply with quote
i uo have tht bike,eckoned it did 80. but with he chin actlly oin the top yoke anfdenoughtime hit, 93 o the way to the isle ofskye.try race tuckfull ace tuck no alf asred tucksandi did in fifh at 11500rpm Mr. Green
code guru
PostPosted: 15:42 - 25 May 2006    Post subject: Reply with quote
wtf?
i cant read wot u wrote
alains
PostPosted: 15:57 - 25 May 2006    Post subject: Reply with quote
surely you've got a french import which is restricted on electronics , write me your serial number (the label between the yokes) and i ,will tell you (begins by ZDCJC22..... the letter following 22 is probably a B or a E )
aratous
PostPosted: 23:14 - 25 May 2006    Post subject: Reply with quote
No i havnt dont that i just took the plate out that was between the carb and the reeds.
I will also get the serial number tomorow and let you know alains.
Finglonga
PostPosted: 23:57 - 25 May 2006    Post subject: Reply with quote
Said it before and i'l say it slow......."SEEEKIE EEENGLEEESH"..FFS Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
aratous
PostPosted: 11:56 - 26 May 2006    Post subject: Reply with quote
It is ZDCJC22 C.
alains
PostPosted: 12:05 - 26 May 2006    Post subject: Reply with quote
ok , that's a UK specs . so you've got a problem because you should hit 100 mph . when last de-coking has been done on this bike ? how long since rings or piston change ? which mileage on the clock ?
i suggest first of all that you go to your next honda garage and have a compression test (it will take 5 mn to test) . then de-restricting is a whole package , you need upjetting ,carbon reeds and race sparkplug . i wait for your answers
aratous
PostPosted: 13:17 - 26 May 2006    Post subject: Reply with quote
what is "de-coking" ? i havnt changed the piston and rings since the bike was new i think, i boutght the bike with 8000 miles and its done 11 now.
Im putting race reeds in it tomorow, ive put an o-ring chain on it. havnt got a new sparky yet and i havnt upjetted it cause i dont know how to do that.
So it might jsut need new piston and rings and upjetting then?
alains
PostPosted: 13:25 - 26 May 2006    Post subject: Reply with quote
de-coking means de-carbonizing . 2 strokes engine needs to be clean every 7500 miles (12000 kms) . the chain has nothing to do with the engine . upjetting is necessary when you de-restrict your engine . on the pict are the jets to change . main 138 , slow 42 , power 65 , https://www.dellorto.co.uk (carb 28PHBH/FD)
tribal_tiger
PostPosted: 13:30 - 26 May 2006    Post subject: Reply with quote
Don't be mean! There could be a good reason he types like that such as:
He's like Joey Deacon.
That's it, that's the only reason I can think of
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
Finglonga
PostPosted: 18:16 - 26 May 2006    Post subject: Reply with quote
Mr. Green Mr. Green Mr. Green I havn't heard that name for years...feckin tea all over my keyboard now. Mr. Green Mr. Green Mr. Green
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 76.41 Kb
