Commmander power!
killa
Won't Shut Up
PostPosted: 13:07 - 26 May 2006    Post subject: Commmander power! Reply with quote
Can some explain to me what a power commander is, and what it does?
Ta
Killa
Wave2k
G's Stalker
PostPosted: 13:14 - 26 May 2006    Post subject: Reply with quote
A powercommander is a unit which intercepts the cpu to alter and change the fuel settings.
Plug it into your laptop download a, say micron can and K&N air filter map and upload, should run a bit better and smoother, will add bhp and torque but it will hardly be noticable.
Ducati 1299 Panigale
2009 Corvette C6 z51
the grim reaper
A power commander 'piggy backs' the standard ECU on the bike and adds a fiddle factor to the fueling and ignition timing (depending on the PC purchased) to get the bike running as well as possible at all points in the rev range.
This fiddle factor is adjustable and means that you can remove the factory fitted flat spot for emissions testing and also set the fuelling up for a loud can and K&N filter (both of which will increase the air flow through the engine, you need the fuel to match the ariflow).
Grim
Itchy
PostPosted: 13:17 - 26 May 2006    Post subject: Reply with quote
what they said Thumbs Up
killa
Won't Shut Up
PostPosted: 13:35 - 26 May 2006    Post subject: Reply with quote
Thanks guys, knew the basics of it, jsut didnt know if it was any benifit.
Ta Wink Thumbs Up
Wave2k
G's Stalker
PostPosted: 14:30 - 26 May 2006    Post subject: Reply with quote
arnt ZX7Rs Carbed ?
The last post was made 20 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 50.25 Kb
