Time-Serts helicoil or any other tricks?
robertw95
PostPosted: 14:32 - 14 Jan 2017    Post subject: Time-Serts helicoil or any other tricks? Reply with quote
Ok so have an issue with a bodge done by previous owner here and I'm looking for a solution. The gear detent arm on my 636 has had the thread stripped and then been drilled and an attempt to tap out to m8 before putting an m6 bolt through again and sump removed and a nut placed on the other side. The bike worked fine in the few trackdays I used it before it wouldn't go into first without jumping back into neutral. Has anyone any suggestions on how I get this back down to an m6 thread? Cheers
07 Dt125r, sv650s k8, zx6rr 04
craigT19
Jolly Green Giant
PostPosted: 15:24 - 14 Jan 2017    Post subject: Reply with quote
Personally i like time-serts but you cant always use them due to material thickness, a helli coil will probably be fine too.
Current bike : - 2016 MT-10
ThatDippyTwat
PostPosted: 15:27 - 14 Jan 2017    Post subject: Reply with quote
https://www.youtube.com/watch?v=LpDduCVUy6w
robertw95
PostPosted: 15:41 - 14 Jan 2017    Post subject: Reply with quote
Time sert is my preferred choice the problem is im not sure of the size of hole required for an m6 insert the problem being its already been drilled to m8. I considered a riv nut Aswell I think that's what your talking about Craig and have ordered a few to see if it will work. Not a huge fan of helicoils especially not in this surcumstance
PostPosted: 18:01 - 14 Jan 2017    Post subject: Reply with quote
I do prefer timeserts, but unfortunately the drill size listed for that is .246" which is 6.24mm.
robertw95
PostPosted: 18:09 - 14 Jan 2017    Post subject: Reply with quote
Yeah that's the problem I thought I'd have... I Seen ones called big serts which they said is a thicker walled bushing to repair previously helicoiled holes which could possibly be an option
PostPosted: 18:23 - 14 Jan 2017    Post subject: Reply with quote
Or finish the M8 job?
Or keep the nut and bolt arrangement and fit a bronze bush in the hole?
ThatDippyTwat
PostPosted: 18:24 - 14 Jan 2017    Post subject: Reply with quote
The video above gives a decent overview and pullout test of each, big-serts included.
PostPosted: 18:35 - 14 Jan 2017    Post subject: Reply with quote
Ah; forgot about the big-serts. LMJGTFY - 7.36mm for m6.
But it says 8.38mm tap, so may be an option.
robertw95
PostPosted: 18:51 - 14 Jan 2017    Post subject: Reply with quote
The problem with going to m8 is the sleeve that fits over the m6 threads for the detent spring is for an m6 bolt. So if I read that right the drill size for big sert is 7mm but the tap is 8.35, im not sure how well the m8 hole has been tapped so not sure if there is enough metal to run the big sert tap through but it's an option.
Ed Case
PostPosted: 21:01 - 14 Jan 2017    Post subject: Reply with quote
In my old CB250RS I've a professionally fitted 'TimeSert' in the spark plug hole and I've done 3 'Helicoils' myself in the head, no problems with any. I've had several people slag-off 'Helicoils' but I've found they work well.
robertw95
PostPosted: 21:12 - 14 Jan 2017    Post subject: Reply with quote
Yeah a helicoil is decent enough in the right place but this is only for a crank case do 3/4mm ally and then it's into the oil pan so I wouldn't trust a helicoil in this instance
331X2
PostPosted: 22:15 - 14 Jan 2017    Post subject: Reply with quote
I've just received some E-Z LOK inserts to repair a previously hashed thread repair in an engine I'm rebuilding. The benefit of these is that they use standard taps on the outside of the insert so you haven't got to drop >£100 on a Big Sert kit, I paid £25 to the door for five M8 inserts which requires a 10.4mm drill bit and an M12x1.75 tap.
They came from here if you wanted to have a look, they also sell Time Sert and Big Sert kits for comparison. No link to seller etc...
robertw95
PostPosted: 01:10 - 15 Jan 2017    Post subject: Reply with quote
Those look spot on without spending the big bucks on a time sert. Thanks very much! Will let you know how I get on
PostPosted: 01:50 - 15 Jan 2017    Post subject: Reply with quote
<a-spooky-ghost.jpg>
tl;dw - Big-Sert by a "butt-ton", followed by Heli-Coil or recoil key-locking, then Time-Sert.
Pete.
PostPosted: 13:22 - 15 Jan 2017    Post subject: Reply with quote
Without seeing the offending object it's hard to say how I would approach this but from reading I think I would first have a look to see how much access there is through the sump, and if it's enough I would probably make a pull-stud similar to wheel nut studs, turn a shoulder on the base to locate in the now over-sized hole and the rest would be normal sized with a nyloc nut on top.
a.k.a 'Geri'
robertw95
PostPosted: 11:46 - 13 Feb 2017    Post subject: Reply with quote
So finally got round to fitting the ez lock insert yesterday, tapped out to m10x1.5 however once the insert was in it was a loose fit and could be spun by hand. I re fitted everything anyway and it seems to be working as should. I was thinking of taking off the sump and possibly aralditing the insert from there to make sure it can't unscrew itself but with the bolt inside now am I right in thinking that will keep it in place?
The last post was made 7 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.23 - MySQL Queries: 15 - Page Size: 90.23 Kb
