sickpup |
sickpup Old Timer
chris-red |
sickpup |
sickpup Old Timer
chris-red |
sickpup |
sickpup Old Timer
Posted: 18:13 - 01 Oct 2014 Post subject: |
Very kind of you to help sir, probably at it next Monday so will let you know.
No pics so far today but decided I will just rebuild the slave cylinders as per Teffers suggestion.
Now these slave cylinders have a very different set up to a motorcycle caliper in that instead of seals around the piston they are at the ends of the pistons and the pistons are opposed like a boxer engine, both push out from the same fluid supply in opposing directions.
As long as you can get one piston out you can remove the seals for both pistons and then knock the opposing one out with a punch.
This is how the slave cylinder looks while mounted to the backplate on the axle.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0654-1.jpg
As you can see the pistons are opposed with a single inlet around the back next to the bleed nipple. |
Bru |
Bru Trackday Trickster
sickpup |
sickpup Old Timer
Llama-Farmer |
Llama-Farmer World Chat Champion
Posted: 19:46 - 01 Oct 2014 Post subject: |
Eurgh, drum brakes and slave cylinders still give me nightmares.
Gonna watch this thread with interest ____________________ Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R |
Wonko The Sane |
Wonko The Sane World Chat Champion
sickpup |
sickpup Old Timer
map |
map Mr Calendar
sickpup |
sickpup Old Timer
Aff |
Aff World Chat Champion
sickpup |
sickpup Old Timer
Posted: 09:16 - 04 Oct 2014 Post subject: |
Not a real update, just had some bits arrive.
New under wing mudshields for both sides, steering box cover, a seal for between the vent panel and windscreen and some flap discs.
Hopefully I will get to do some more work this week as I have 6 days off, just have to make sure I don't eat too much at pork rib night.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/DSCF0659.jpg
Need to decide what finish I want on the mudshields and steering box cover. I'm thinking hot metal spray, powder coat and then underseal just so they last another 40 years. |
stevo as b4 |
pdg |
pdg World Chat Champion
Posted: 19:04 - 04 Oct 2014 Post subject: |
If a lightweight has a V8, it's a retrofit...
As far as I know (which isn't very far ) they all had the 2.25 petrol.
As for the term 'lightweight', they weigh more than a standard civvy series 3. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
sickpup |
sickpup Old Timer
Posted: 21:10 - 04 Oct 2014 Post subject: |
V8's were never to my knowledge a standard fit in the lightweight, it wouldn't surprise me if the factory tried it at some point but none that I know of were put into production. All of the ones you see in public are retro fits.
The standard engine was the 2286 petrol but the Dutch did have LHD 2286 Diesels that were a bit of a failure, have a read here for details of them. |
sickpup |
sickpup Old Timer
pdg |
sickpup |
sickpup Old Timer
sickpup |
sickpup Old Timer
sickpup |
sickpup Old Timer
Shaft |
Shaft World Chat Champion
sickpup |
sickpup Old Timer
Posted: 20:39 - 09 Oct 2014 Post subject: |
Just emailed them, thank you. |
sickpup |
sickpup Old Timer
The last post was made 9 years, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
