DERESTRICTING
simsimma
PostPosted: 09:58 - 17 May 2008    Post subject: DERESTRICTING Reply with quote
ive taken the intake restrictot off my nsr 125 like it sez on this site an now wen i start it it just revs its arse off can ne1 help pls
alains
PostPosted: 10:09 - 17 May 2008    Post subject: Reply with quote
would you please write a good english , i cannot understand where is your problem
the worst day fishing is better than the best day working
simsimma
PostPosted: 10:15 - 17 May 2008    Post subject: Reply with quote
I ve bin on a web site called nsr125.com about de-restricted and it said take off the intake restrictor off i ve done that and now when i start it it just revs to the point i have to turn the engien off
Faraz
PostPosted: 13:06 - 17 May 2008    Post subject: Reply with quote
Lower the idle?
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
Ichy
PostPosted: 13:09 - 17 May 2008    Post subject: Reply with quote
Check the throttle cable is routed ok, sounds like its stuck open.
simsimma
PostPosted: 13:15 - 17 May 2008    Post subject: DERESTRICTING Reply with quote
will check cable now thanks mate
simsimma
PostPosted: 13:22 - 17 May 2008    Post subject: Reply with quote
no its not the cable
simsimma
PostPosted: 13:25 - 17 May 2008    Post subject: Reply with quote
whats an idle
Finglonga
PostPosted: 13:46 - 17 May 2008    Post subject: Reply with quote
simsimma wrote:
whats an idle
If your asking that you shouldn't be messing with your engine, you have put something back together wrong or have an airleak somewhere in the system.
Go over it again and when you fix it leave it well alone.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 13:55 - 17 May 2008    Post subject: Reply with quote
Sounds like you have removed the carb, and put the throttle slider in the wrong way around?
Explain exactly what you have done, in english (remember,your not writing a text) and someone will be able to tell you where you have went wrong.
DRZ-400sm
Thom
PostPosted: 14:06 - 17 May 2008    Post subject: Reply with quote
Right, im not great with nsr's (just ask my own!) but i'v egained some experience. now as far as im aware there is a plate in between the carb and the engine, it should have a relatively small hole in comparison to that of the carb rubbers. remove this. next you need to change your CDI to a derstricted unit as well as remove the baffle from your exhaust.
after this you will need to upjet your carb to compensate for the drestriction/extra air/fuel being allowed into the engine.
Personally, i reckon your probabaly on 'L' Plates anyway so shouldnt derestrict it... but im also guessing you have absolutely no idea what so ever so do what you like Thumbs Up
The idle is the large screw on the rhs of the carb needs turning in to increase idle, out to decrease butr i wouldnt do that when the engines cold, or not jetted correctly.
And I don't think you can put the carb slide in the wrong way round, it has a locating slot, but dont quote me on that!
Alains practically told me everything i know about the NSR after buying a very dodgy example so he's your man if you can type in half-decent english!
Thom
PostPosted: 14:07 - 17 May 2008    Post subject: Reply with quote
Just thinking, you havent removed the reed block have you?
PostPosted: 14:10 - 17 May 2008    Post subject: Reply with quote
In my experience you can,but obviously it doesnt fit right,which causes the bike to rev flat out.
Made this mistake on my chinese 125 and my mates xlr125...not sure about on the nsr though,i was just guessing.
DRZ-400sm
Faraz
PostPosted: 14:12 - 17 May 2008    Post subject: Reply with quote
simsimma wrote:
whats an idle
Shocked
'56 Yamaha MT-01
simsimma
PostPosted: 17:41 - 17 May 2008    Post subject: Reply with quote
thanks everyone for all your coments desieded to put intake restrictor back on and runs fine but 0-60 in about 10secs is slow init?
Thom
PostPosted: 18:06 - 17 May 2008    Post subject: Reply with quote
not when your on a 125 restricted to 13bhp...
simsimma
PostPosted: 18:59 - 17 May 2008    Post subject: Reply with quote
It sounded so easy on nsr.com drill welds in down pipe snapped 2 drill bits and gave up remove restrictor plate and then your done now how easys that ha ha no i have not removed reed block or cleaned air box i've put a little k&n on it
Thom
PostPosted: 20:09 - 17 May 2008    Post subject: Reply with quote
Wey heres your problem, you dont have a clue!
K and N filter, you'll need to upjet your carb to take into account the less restricted air flow.
You Tried to allow more air/fuel into the engine by removing the intake restrictor, the carb would need upjetting to compensate for this, but with the K and N i can almost gurantee you were running lean if you didnt upjet which basically means you have too much air: fuel in your mixture.
By half heartidly derestricting the bike, and then fitting the filter, you'll have messed up your jetting, return the bike to as close to standard as you can and get a mechanic to sort it.
TL666
PostPosted: 20:39 - 17 May 2008    Post subject: Reply with quote
Leave it alone sunshine. You'll regret messing with it when you blow your engine. Pass your test and buy a more powerful bike.
Louise
PostPosted: 20:44 - 17 May 2008    Post subject: Reply with quote
I have a question on this,
when the NSR125 starts it revs quite alot....
Now, were looking to sell this within a month, where is the idle screw Laughing
Also, it dose help if you speak proper english - nothing worse then chav talk.
Sorry, dont mean to offend but it makes life alot easyer and your more likly to get more replys Wink
Louise
PostPosted: 20:47 - 17 May 2008    Post subject: Reply with quote
K&N CONES DO NOT WORK ON REED VALE STROKERS WITHOUT SPACERS AND LOTS OF DEVELOPMENT!!!!!!
DOESN'T ANYONE F@@KING LISTEN??????
YOU'LL HAVE RUINED THE POWER DELIVERY AND MADE IT LIKELY TO HOLE PISTONS.
FFS I GIVE UP.
Why do you need to shout, do you not think people will read your post.
PLEASE DO NOT SHOUT, ok Laughing please, because it gives me a head ach, and i get annoyed when I get one of them Crying or Very sad
Pete.
PostPosted: 20:56 - 17 May 2008    Post subject: Reply with quote
The idle adjuster is usually a screw on the side of the carburettor with a spring on it. It works by stopping the slide from falling down by the fact that the slide has a sloping notch in it for adjustments.
You can fit the slide in backwards on most small carbs, but it will only slide down until the notch for the idle screw hits the locating pin, which should locate in the slot the other side of the slide.
a.k.a 'Geri'
simsimma This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Ichy
PostPosted: 21:54 - 17 May 2008    Post subject: Reply with quote
Relax, its good that you gave it a go, trouble is that its never as easy as it sounds.
There is a guy on here by the name of Alains. He knows EVERYTHING about nsr's. The thing is that the guy is French so he needs you to explain everything in good English, he can't translate slang or txt talk.
If he replies to any of your posts then follow his instructions. Do that and the bike will fly.
The last post was made 18 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.2 - MySQL Queries: 13 - Page Size: 127.79 Kb
