numberplate drilling....
craigT19
Jolly Green Giant
PostPosted: 18:27 - 27 Jun 2004    Post subject: numberplate drilling.... Reply with quote
hi peeps
no do i drill my tarty new plate from the front...or from the back?
thx
Current bike : - 2016 MT-10
Sparks!
Sir Tart-a-lot
PostPosted: 18:33 - 27 Jun 2004    Post subject: Reply with quote
front I think as it will be untidy if its done the other way around..
I'm almost sure that's right anyway Confused
Claud 14.7 to 1
PostPosted: 18:35 - 27 Jun 2004    Post subject: Reply with quote
I do it from the front, no probs...
i usually start with a small drill piece they use larger ones to make the holes bigger...
Put a plank of wood underneath the plate, then when you go through the plate you only hit wood, and it helps it, not to break. it helps if you have the protective film on when you drill through. Gives a nice clean hole.
you can use the old plate as a template by taping them back-to-back. Drill throught the holes and you have perfect spacings. This is assuming they are the same size.
Thats about it. Just take your time and it'll be ok.
mrchips
Front, so the frays are facing the back and you have a clean hole at the front. Or go that step neater and put it on with adhesive pads.
swaffs
PostPosted: 18:39 - 27 Jun 2004    Post subject: Reply with quote
from the front.
put some masking tape over it first, helps to prevent cracking, and a scrap of wood underneath.
Or just stick it.
I ended up using 'no nails' Confused cause my sticky velcro pads started to fail after a ride to newcastle, and that's all we had access to at his house.
It certainly hasn't come off !!! god knows how i'm gonna get it off if it breaks.
True Blue
PostPosted: 18:47 - 27 Jun 2004    Post subject: Reply with quote
Either way, just make sure you drill very slowly to prevent cracking. I just drilled mine last week and went straight through it with a 6mm bit. I didn't use a pilot hole first.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
craigT19
Jolly Green Giant
PostPosted: 20:55 - 27 Jun 2004    Post subject: Reply with quote
thx guys Razz
tis just i have a tarty new number plate and i dont want to kill it Razz
Roo
PostPosted: 21:55 - 27 Jun 2004    Post subject: Reply with quote
Noooo do it from the back otherwise the yellow backing might be pulled away from the plastic.
The untidy bits'll be covered by the screws anyway.but if your really particular then file the untidy bits.
Poking death in the eye with a pointy stick then running away
Claud 14.7 to 1
PostPosted: 22:21 - 27 Jun 2004    Post subject: Reply with quote
Dont listen to roo. Do it from the front with the wood behind it. It will be fine, the backing wont peel off.
i work part time halfords and i do them all the time.
Roo
PostPosted: 22:26 - 27 Jun 2004    Post subject: Reply with quote
Hate to pull rank or sound like a twat but I worked in a bike dealership for years we always did them from the back. I doesn't really make that much difference theirs just less chance of it ballsing up your shiny new plate. Plus you can mark your drill holes more clearly on the back of the plate. Thumbs Up
Flip
PostPosted: 22:31 - 27 Jun 2004    Post subject: Reply with quote
Did mine from the back with no probs. Marked the holes easy enough. Pilot hole first. Laughing Thumbs Up
cliff
Doctor Sicknote
PostPosted: 22:33 - 27 Jun 2004    Post subject: Reply with quote
We do them from the front on wood at work. Thumbs Up
But we don't do numberplates anymore after a spot of trouble with the dvla.
Sweet reggae music.
Claud 14.7 to 1
PostPosted: 22:44 - 27 Jun 2004    Post subject: Reply with quote
Laughing we are making it sound like its tough or something. Its a piece of piss, and if you mess it up, you'll either be very very very unluckey, or completely cak handed.
Personally i'd do it from the front, i have no reason to believe why it will mess up, as ive never messed one up.
All that has to be said, has said already been said in this post.
Safe.
Davo
Davo To The Rescue!
PostPosted: 22:58 - 27 Jun 2004    Post subject: Reply with quote
Don't do what i did and used an .22 air rifle... made a nice hole but pellet ricocheted. (cracked the plate as well)
dandit
PostPosted: 23:01 - 27 Jun 2004    Post subject: Reply with quote
use superglue or velcro from halfords then you can take it off when on long blasts Twisted Evil
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
Claud 14.7 to 1
PostPosted: 07:45 - 28 Jun 2004    Post subject: Reply with quote
halfords do some great number plate adhesive pads, 3 in a pack, you use them equally spaced along the plate. come in 1mm or 6mm thicknesses. Never had anyone complain, about plates falling off.
Superglue will makle a mess, velcro wont stick well...
why would you want to do that?
craigT19
Jolly Green Giant
PostPosted: 11:11 - 28 Jun 2004    Post subject: Reply with quote
Laughing of thx
priller
PostPosted: 11:42 - 28 Jun 2004    Post subject: Reply with quote
I've done loads of plates and always done them from the back.
Claud 14.7 to 1
PostPosted: 15:30 - 28 Jun 2004    Post subject: Reply with quote
*Sigh*, this dispute will never end... Smile
Demonic69
The Pink Rhino
PostPosted: 19:08 - 28 Jun 2004    Post subject: Reply with quote
Don't buy the shitty Halfords things. You can get a roll of plate tape for mucho less.
And drilling from behind is always best Very Happy
craigT19
Jolly Green Giant
PostPosted: 09:21 - 29 Jun 2004    Post subject: Reply with quote
well my local garage have just said do it from the front!?!?!?!?
im confused
VFR400UK
PostPosted: 09:27 - 29 Jun 2004    Post subject: Reply with quote
i allways drill them from the front. this stops any unidyness showing on the front of the plate as and cracks or mangled bits of plastic are on the back
Claud 14.7 to 1
PostPosted: 09:35 - 29 Jun 2004    Post subject: Reply with quote
im confused
Comon, its not rocket science. You are putting two holes in a piece of perspex...All the advice has been given, use it...
Mr Pants!
I Karma
PostPosted: 10:02 - 29 Jun 2004    Post subject: Reply with quote
But which advice to use!
I must admit I have always gone from the front. But Roo is right that you have to be careful of not lifting the yellow off the back. You will end up with those horrible dirty black marks appearing round the drill holes.
I think if you press it hard on to an old piece of wood you should be okay. If not, spend another £6 and buy another one! Cool Then take it from behind! Cool
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
Bendy
Mrs Sensible
PostPosted: 10:52 - 29 Jun 2004    Post subject: Reply with quote
Do one hole front to back and one back to front in the name of research.
The last post was made 21 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 123.75 Kb
