What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 54, 55, 56, 57, 58, 59  Next
Robby
Dirty Old Man
PostPosted: 06:11 - 23 May 2025    Post subject: Reply with quote
to v or not to v wrote:
what are you thinking of replacing it with?
A Zero SR or SR/F. I've wanted to go electric for a while, and they have depreciated hard enough to be an option.
to v or not to v
PostPosted: 09:56 - 23 May 2025    Post subject: Reply with quote
im guessing you dont ride for long periods then? their range would be to limited for me.
Moto Guzzi V7.
blurredman
PostPosted: 11:14 - 23 May 2025    Post subject: Reply with quote
I wonder if the tyre noise would get on my nerves. Thinking
Robby
Dirty Old Man
PostPosted: 13:47 - 24 May 2025    Post subject: Reply with quote
Nope, I barely ride at all since I moved to mostly working from home. Occasional weekend/evening blasts, I rarely go more than 50 miles.
I've had an electric car for 4 years. I like electric. I'm also bored of changing gear and don't want a scooter.
PostPosted: 15:42 - 24 May 2025    Post subject: Reply with quote
Much the same here. If it weren't for the odd commute into the heart of the City electric would be fine, as it is I've downsized to the Husky.
Surely it make a lot of sense to push electric motorbikes a lot more given they're nowhere near as reliant on dedicated charging systems as cars Thinking But no, hulking great SUVs everywhere Sad
blurredman
PostPosted: 09:04 - 25 May 2025    Post subject: Reply with quote
Do what Prince did Laughing
virus
PostPosted: 10:34 - 25 May 2025    Post subject: Reply with quote
today (well thursday) I sucessfully snapped the driveshaft in 2. Pulled it out and confirmed its bollocksed yesterday, today Im trying to research who can make a driveshaft for me with splines on both ends but one end is about 2x diameter the other.
That or I put the original diff and shaft back in but the gearing is outright rediculous on that, i.e. first gear is pretty much only for burnouts.
own: 81 xs1100g...
PostPosted: 18:27 - 31 May 2025    Post subject: Reply with quote
Had a tinker with the Old Fella's Triumph. A few weeks ago it was running nicely, now it's doing a combustion pig impression Sad
Spark plugs wet, relatively clean and with the correct gap. Spark is pretty weak though. Coils are relatively new, correct ohmage for both sides. From a process of elimination can only put it down to the old Lucas AB11 "ignition amplifier". It's the original 40+ year old part so we're going to try the "Rex's Rita Rebuild" board, see if that sorts it.
With a multimeter: voltage across the coils ~11V. With the Lucas unit disconnected ~12.6V (the battery voltage) Thinking
PostPosted: 18:24 - 06 Jun 2025    Post subject: Reply with quote
Fitted the rebuilt Lucas unit. First kick the bike half coughed, second kick it started Very Happy
blurredman
PostPosted: 07:34 - 12 Jun 2025    Post subject: Reply with quote
Indicators stopped working.. Opened the relay and filed the points and all is well again.
https://i.ibb.co/0jV0W0St/indicator-relay.jpg
Brava210
PostPosted: 09:00 - 22 Jun 2025    Post subject: Reply with quote
MoT on the Clutchless Honda 300
Passed
Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE"
to v or not to v
PostPosted: 17:38 - 22 Jun 2025    Post subject: Reply with quote
went out for a couple of hours ride first thing, then changed the oil. engine, gearbox and shaft.
Moto Guzzi V7.
to v or not to v
PostPosted: 21:30 - 25 Jun 2025    Post subject: Reply with quote
checked and adjusted the valves. something that should have been done at the dealers 400 miles ago and clearly wasnt.
every valve was tight.
Moto Guzzi V7.
Robby
Dirty Old Man
PostPosted: 06:57 - 27 Jun 2025    Post subject: Reply with quote
Assuming this is the Guzzi, mine needed adjusting twice in the first 1000 miles and then just stayed in spec. The engines seem to start off quite tight and need running it, like in the olden days.
to v or not to v
PostPosted: 09:30 - 27 Jun 2025    Post subject: Reply with quote
yep it was on the Guzzi.
they make it so easy to do that its actually enjoyable.
Moto Guzzi V7.
BanditsHigh
Worse than a woman
PostPosted: 14:27 - 02 Jul 2025    Post subject: Reply with quote
Getting it ready for MOT, done all the little bits but major bits are front brakes are very spongy (wil try bleeding for now) and the right fork is leaking.
Got my old set of forks and was going to rebuild with new oil seals/dust seals ... can't get the feckers apart, the oil seal is jammed solid ... so had to use another spare fork to hopefully get it through the MOT.
Oh, and while putting the bike up onto axle stands to take the front end off, the feckin thing slipped off the first stand and started rolling backwards, had taken the calipers off and left it in neutral so couldn't stop it.
Cue the terrified realisation I was about to drop the bike, first of all it started falling away from me, got that back and then it fell towards me, all the while will still rolling backwards.
Due to the heart issues I have I have very little strength these days, how I actually managed to keep it upright I'll never know, but I did Very Happy
to v or not to v
PostPosted: 17:46 - 02 Jul 2025    Post subject: Reply with quote
get a vacuum pump. makes bleeding a piece of cake.
https://www.ebay.co.uk/itm/388654006478?
Moto Guzzi V7.
BanditsHigh
Worse than a woman
PostPosted: 08:22 - 03 Jul 2025    Post subject: Reply with quote
get a vacuum pump. makes bleeding a piece of cake. https://www.ebay.co.uk/itm/388654006478?
I have a silicone tube, blocked at one end with a split about an inch from the end, other end fits over the bleed nipple ... pumping the lever will cause the split to open and therefore expels air/fluid and it seals up again after the lever is released.
I'll have a look at the vacuum pump, but it's sticking pistions due to crap behind the dust seals most likely, I need to strip them down and give them a good clean.
hellkat
PostPosted: 13:49 - 10 Jul 2025    Post subject: Reply with quote
Gave the two Yamahas (in pieces) in my shed to the man who emptied it out for me on the weekend. I think there might hae been more than 4 wheels but I don't really care, it all had to GTFO
Goodbye Yamahas, you were part of a very happy time in my life, but its time to go go go ... Arrow.
hellkat
clearing shite out
PostPosted: 16:18 - 10 Jul 2025    Post subject: Reply with quote
You gave away 'my' Tenere!! Shocked
hellkat
PostPosted: 22:32 - 10 Jul 2025    Post subject: Reply with quote
Rolling Eyes
Oh dear, did I give you first refusal?
Sorry about that if so.
I really did have a bee in my bonnet about starting to clear all the shite out of my life.
PostPosted: 10:06 - 11 Jul 2025    Post subject: Reply with quote
hellkat wrote:
Rolling Eyes
Nah not really.. Wink I knew you had one stashed but not sure I've go the time for another refurb. - as long as it's gone to a good home.
BanditsHigh
Worse than a woman
PostPosted: 10:26 - 12 Jul 2025    Post subject: Reply with quote
Went from my first run in a long time yesterday, rode from Hamilton through to Anstruther ... mainly to meet up with a friend I've not seen for around 35 years and also to try the supposed best fish supper in Scotland.
Fish supper was ok, nothing great and only one fish, in fact my local chippy is as good if not better and has two fishes Thumbs Up
Anyway, all went well until I was set to reurn home ... zero magic smoke ... no phone signal so I couldn't read my policy and find the breakdown number ... luckily one of the local places had wifi ... so breakdown turned up an hour later and got me home just after midnight.
Replaced the main main fuse holder/starter solenoid this morning with a spare I had and back on the road again Very Happy Thumbs Up
PostPosted: 16:27 - 12 Jul 2025    Post subject: Reply with quote
Basic maintenance on all my vehicles. Coolant, wiper fluid, oil levels... the GT is a funny beast and the oil plays hide and seek. It may look empty but run it on the centre stand and hey presto it's there, like that magic glass you had as a kid Smile
to v or not to v
PostPosted: 10:44 - 13 Jul 2025    Post subject: Reply with quote
washed and polished the Guzzi.
Moto Guzzi V7.
Page 55 of 59
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 133.47 Kb
