What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 59, 60, 61, 62  Next
PostPosted: 11:04 - 13 Apr 2026    Post subject: Reply with quote
to v or not to v wrote:
MarJay wrote:
Triggered!
You don’t mean ‘stiffness’ you mean either preload or compression damping one presumes? You should never go to maximum on any of them unless you’ve eliminated other handling issues.
maximum preload then.
i thought id try that, then try minimum, just to see what difference the two extremes make.
the bike is a bit harsh at the back end over uneven surfaces.
Set the rider sag. You need to have it so the suspension sits at the top of the bottom 2/3rds of travel (or the bottom of the top 3rd, whichever way you prefer) with you sitting on the bike. It'll make a huge difference.
Then if the suspension feels too 'harsh' I'd say back off a click or two of compression damping.
I've attached a zip file with a PDF of a magazine article that explains suspension setup. It doesn't include high and low speed damping, but most bikes don't have this anyway.
to v or not to v
PostPosted: 21:19 - 13 Apr 2026    Post subject: Reply with quote
thanks MarJay.
the suspension on my bike is very basic. the only adjustment available is the preload on the rear shocks.
id have to splash out on aftermarket stuff if i wanted any more adjustment.
Moto Guzzi V7.
PostPosted: 11:54 - 14 Apr 2026    Post subject: Reply with quote
I've learned that, annoyingly, the safety sensors (side-stand and/or dropped bike) will still allow the Aprilia to fire up for a few seconds => minute before cutting out.
Thus confusing the ignorant... (me Neutral ).
to v or not to v
PostPosted: 08:15 - 18 Apr 2026    Post subject: Reply with quote
put some Grip puppies on it because i find the standard grips a bit too thin.
Marjay will be pleased Laughing
Moto Guzzi V7.
panrider_uk
PostPosted: 23:18 - 23 Apr 2026    Post subject: Reply with quote
Ordered new brake pistons and seal kits for its front calipers
PostPosted: 18:01 - 30 Apr 2026    Post subject: Reply with quote
Stripped, cleaned and reassembled my pretech 6-pot callipers. For the second time in a month.
Bit of a pain because pretech no longer exist. You can still get parts for them from farkhamhall.co.uk.
Had a sticking piston about a month ago, just before I was going to go away on it. Stripped and cleaned them and all looking good. I needed to fitt new o-rings for between the calliper halves, thinking I'd have some in my kit. It turns out they are actually x-rings (sometimes known as quad-rings) which don't come in the same standared sizes as o-rings.
I took a chance and re-used them because I was going the next day. They worked but one calliper had a tiny weep between the join.
Farkhamhall only list complete rebuild kits and I only needed the four o-rings so cue pissing about and trying to measure them (again, not as easy as o-rings).
Anyway, I can now say for certainty that pretech 6-pot callipers use a 1.78mm Section, 6.07mm Bore x-ring. You can buy them cheap on simply bearings, part number: Q4010. Hopefully any search engines also read this in case someone else is looking.
to v or not to v
PostPosted: 20:26 - 30 Apr 2026    Post subject: Reply with quote
sold it. the Thunderace.
Moto Guzzi V7.
to v or not to v
PostPosted: 12:43 - 04 May 2026    Post subject: Reply with quote
disabled the emissions gubbins.
Moto Guzzi V7.
PostPosted: 19:25 - 08 May 2026    Post subject: Reply with quote
put the fairings back on and taxed the Falco for summer..
PostPosted: 22:25 - 09 May 2026    Post subject: Reply with quote
Fixed the indicators on the KR-1S, turns out I'd forgotten to connect the front ones back up!
Adjusted the controls on the Blade so the reach to the clutch and front brake is slightly less.
PostPosted: 11:24 - 20 May 2026    Post subject: Reply with quote
Yesterday: fitted the Chinese baffles to the Scorpion cans - barely no difference but teh low down 'boom' is reduced - perhaps some wadding will help..
https://i.ebayimg.com/images/g/kdIAAOSwmlpf~XJz/s-l480.webp
Today: hopefully painting the 'new' unmolested fairing for the Falco to match existing scheme. Discoverd that my neighbours Toyata Yaris Bronze metallic is a damn close match to Aprilia Olympic bronze.
kawakid
PostPosted: 12:14 - 20 May 2026    Post subject: Reply with quote
Fitted a Power Bronze - Belly Pan to my Z650 what a pain, lots of stupid fiddly brackets. Spent about 2 hours going, perhaps try moving this a little bit and is this bracket meant for here.
Why can't manufacturers print instructions in colour or do a YouTube video.
Looks good though.
I've a twin and a 4.
thx1138
PostPosted: 15:00 - 21 May 2026    Post subject: Reply with quote
Rubbed the forks very gently with Brillo pads preloaded with soap to try to lift rust marks ahead of mot, then used neutral baby wipes to clean the soap off and a ragged tshirt. Seems to have worked.
panrider_uk
PostPosted: 21:46 - 21 May 2026    Post subject: Reply with quote
Put a new battery in it and found out that the ignition barrel is fooked
to v or not to v
PostPosted: 17:25 - 23 May 2026    Post subject: Reply with quote
fitted a small screen when i got back from a ride this morning. its a cheap thing from China.
hoping it might help with wind at higher speeds.
Moto Guzzi V7.
Rob W
PostPosted: 15:51 - 24 May 2026    Post subject: Reply with quote
Balanced the front wheel as I've suddenly got vibration from somewhere. Didn't seem to help, so next step is a throttle body sync as I've checked every fixing and nothing at all was loose. Mileage is coming up to 5K so it isn't far off needing to be checked anyway.
to v or not to v
PostPosted: 22:05 - 24 May 2026    Post subject: Reply with quote
went out for a joyride. quite impressed with the new screen. makes motorway speeds a lot more comfortable.
Moto Guzzi V7.
thx1138
PostPosted: 14:36 - 05 Jun 2026    Post subject: Reply with quote
Took the little bar mounted time piece off the vanvan, to change battery. 20 minutes job. 5 seconds to remove clock. 20 minutes to find the 2mm Allen Key ??
to v or not to v
PostPosted: 12:50 - 21 Jun 2026    Post subject: Reply with quote
went out for a ride in the early hours, then gave the Guzzi its annual service.
Moto Guzzi V7.
PostPosted: 15:30 - 22 Jun 2026    Post subject: Reply with quote
Not done much bike stuff in the last month but I have a weird problem with the Old Fella's Harley Breakout.
After a longish run, i.e. everything's nicely warmed up, the brake lights stay on. I've run the OBD scanner over it and the complaint is the front brake switch is stuck. "Great, replace the switch!" Nope, we disassembled the switch cluster, removed the brake switch and twisted the wires together - no change.
The problem with these bikes is almost everything runs over CAN-bus, including the switch clusters. Either the SoC in the switch cluster is faulty or the power distribution "BCM" computer. Ker-Ching!!! Crying or Very sad
hellkat
PostPosted: 12:28 - 29 Jun 2026    Post subject: Reply with quote
Put it on ebay Laughing
Got to work on *how* I plan to retire within the next two years.
Which looks like some-time-there and some-time-here until I decide otherwise.
So its pointless having two bikes here in the UK
If it doesnt sell here before I go, I suppose I'll take it with me
My best mate over there will be more than delighted to have it in her garage and occasionally take it for a ride out Laughing
But for now, ebay.
to v or not to v
PostPosted: 18:02 - 29 Jun 2026    Post subject: Reply with quote
washed and polished it. not something i do very often.
Moto Guzzi V7.
blurredman
PostPosted: 08:03 - 30 Jun 2026    Post subject: Reply with quote
Link? Smile
Rob W
PostPosted: 09:29 - 30 Jun 2026    Post subject: Reply with quote
Fitted the new Puig levers. Think they look and feel loads better than stock, and the pair with adapters was the same price as one ASV Laughing.
to v or not to v
PostPosted: 18:46 - 30 Jun 2026    Post subject: Reply with quote
blurredman wrote:
Link? Smile
going by the users name it just has to be-
https://www.ebay.co.uk/itm/336650425598?
Moto Guzzi V7.
Page 60 of 62
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.18 - MySQL Queries: 16 - Page Size: 136.36 Kb
