Hi, heres a question for you...
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3  Next
Big Pete
PostPosted: 12:11 - 27 Jul 2004    Post subject: Reply with quote
I will pontificate on engine fundamentals at lunch, when I have time to write a long ( and probably slightly patronising) post on the subject. The short version - 2 stroke or 4 stroke there is no other way with pistons. Technically, 2 strokes are more efficient. More later folks. Very Happy
Trust me, I`m an engineer
GarageOfPower.co.uk
Bendy
Mrs Sensible
PostPosted: 12:16 - 27 Jul 2004    Post subject: Reply with quote
Triple word score for 'pontificate'. Thumbs Up
Big Pete
PostPosted: 13:02 - 27 Jul 2004    Post subject: Reply with quote
Bendy - I thank you lol.
right, engine fundamentals part one
piston engines only
engine efficiency is all about compression ratios and upper and lower temperature limits. Trust me on this one as its a pain to explain without going into the gas laws and drawing graphs.
If you to inject a self oxidising fuel in a piston engine at tdc on exhaust (having closed the ex valve first obviously) you will not get a very powerful engine.
This is because the bang is NOT what drives the engine. Heat (and the resultant expansion of the air in the cylinder) is what drives the piston down. If you put a pixie with a box of matches in the cylinder (and insulated it so it wouldn`t lose heat), as the the pixie lit the matches (raising the air temperature in the cylinder) the increasing pressure would force the piston down. If you shove explosives (and very little air) into the cylinder, the only gas available to expand and do useful work is that generated by the decomposition of the explosive (which is not much compared to a cylinder full which is then compressed at tdc).
2-strokes have the potential to be more efficient because they can do this twice as fast as 4-strokes.
If you want a really powerful, high efficiency engine you use a forced induction 2 stroke diesel ( which is at least as complex as a 4 stroke engine). Most really big engines (bulldozers, ships, generators etc) are this type. these engines have an exhaust valve in the head and inlet ports at the bottom of the cylinder. At bdc, the high pressure clean air is blown in the ports, forcing the waste gasses out the open valve. after the valve closes the piston starts to rise, compressing the air. At tdc fuel is injected in the normal manner, whereupon it burns, raising the temperature and pressure and forcing the piston back down. Repeat add infinitum.
As an aside, the blowers originally used on drag cars ("jimmy" blowers) were the scavenge pumps used on GMC 6-series bulldozer engines, which are of the type just described.
Here endeth the lesson, more another time if anybody is interested.
GarageOfPower.co.uk
dibbster
PostPosted: 13:28 - 27 Jul 2004    Post subject: Reply with quote
What are the advantages of the rotary engine as used by Norton?
Are their any bike companies that still use it?
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Superabusa This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
TheGreatMilen...
PostPosted: 13:38 - 27 Jul 2004    Post subject: Reply with quote
cant be arsed to read the replys was the answer Norton ??? that wasnt that long ago was it like 93 or some such ?????
Big Pete
PostPosted: 13:40 - 27 Jul 2004    Post subject: Reply with quote
Rotary engines suffer badly because the combustion chambers are long and thin, which means there is lots of surface area to absorb heat (remember- heat is what makes it happen) so they run hot and waste energy. It also limits the compression ratio.
The road bikes also had to burn the oily, hot air that was used to cool the rotors, hot air is less dense, so less power and the oil pormotes detonation. There are also lots of problems with rotor sealing and lubrication. The upside is that they can be cheap, simple and light which is why they are used in things like target drones where some of the dissadvantages are not such an issue.
GarageOfPower.co.uk
Shade_BW
I'm better than you
PostPosted: 13:42 - 27 Jul 2004    Post subject: Reply with quote
Hi grav!!
Sadie
PostPosted: 13:48 - 27 Jul 2004    Post subject: Reply with quote
Shade_BW wrote:
Hi grav!!
Which one is Grav? Confused
With experience comes age.
Shade_BW
I'm better than you
PostPosted: 15:26 - 27 Jul 2004    Post subject: Reply with quote
The one that looks like w@nkel
Mr Pants!
I Karma
PostPosted: 15:37 - 27 Jul 2004    Post subject: Reply with quote
Mr W@nkle, I do recall those days, although I am only 34 years of old age. I know of all sorts of classic bikes as my uncle is one of the biggest dealers in them.
I will have to ask him about the Norton Rotary days...... Very Happy
He still chuckles at my plastic rocket, I my bike will never end up a classic as it would have probably disintegrated by then.....
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
PostPosted: 20:38 - 27 Jul 2004    Post subject: Reply with quote
I do remember the Norton Rotaries, and remember seeing them race at the GP at Donington as a special one off (certainly raised a few cheers).
An engines capacity is measured as its swept volume, and it is just as easy to measure that for a rotary as for a normal piston engine. The problem is that a rotary engine has, effectively, 3 chambers sweeping the same volume at the same time so you can argue away about the effective volume when compared to a piston engine. For example if you say that a 2 stroke can have half the capacity of a 4 stroke as double the number of strokes are useful, then you could treat the rotary as having a capacity of a 4 stroke engine of 6 times the capacity.
From memory by the international rules the 588cc Norton was actually an 1176 (double the swept voume), but the UK rules were fudged to allow them to race.
Demonic69
The Pink Rhino
PostPosted: 21:59 - 27 Jul 2004    Post subject: Reply with quote
Anything a bit more challenging W@nkel?
And Norton were onto a winner with the F1, if only they'd mass produced it a little earlier they'd still be a major player on the pocket-rocket scene.
And are you really the Wankel who created the Rotary engine used in the RX7? Or just like the name?
W@nkel
PostPosted: 22:48 - 27 Jul 2004    Post subject: Phew, you lot have been busy! Reply with quote
dibbster wrote:
What are the advantages of the rotary engine as used by Norton? Are their any bike companies that still use it?
When BSA/Norton/Triumph evaluated the Wankel in 1969 it was considered to be the engine of the future having good power to size/weight ratio and very low vibration compared to a piston engine. Since then the Japanese have developed bike piston engines so much that these advantages have been cancelled out. Only Mazda use a Wankel now (RX8 car). The Wankel performs very well as a hydrogen fuelled engine and this may be its future.
Superabusa wrote:
On the subject of the Norton BSB bikes, didn't they have a different engine from the road bikes? If I remember correctly they even rotated in the opposite direction!
Hello Grandpa, no the road bike engines and race engines were the same. There was an air cooled (Interpol & Classic), watercooled (Commander) and 'reverse spin' watercooled (F1 & F1 'Sport' road bike race replicas). They were all twin rotor 588cc.
The Norton aero engine is still made in Germany.
Yes, the ACU said 588cc x1.7 makes it a 1000cc 'Twin', yep, that will do. Dunno where they got x1.7 from! Laughing
Demonic69 wrote:
are you really the Wankel who created the Rotary engine?
I bleedin hope not!!! Dr Felix Wankel is dead!! LOL
Click here for my Norton Wankel motorcycles web page
Dr Nick
PostPosted: 22:50 - 27 Jul 2004    Post subject: Reply with quote
DaFrostyOne wrote:
2 stroke motors mix the air and fuel together to form the mixture,
Oh i thought that was the carburettor Confused Razz .
is that it
jayluvmito
PostPosted: 22:59 - 27 Jul 2004    Post subject: Reply with quote
damn, i never seen them norton f1's before....
detect the sarcasim ther..... Rolling Eyes
one day...
PostPosted: 23:09 - 27 Jul 2004    Post subject: Reply with quote
The F1 was a barely deveoped limited production bike with hideously dirty exhaust emisions (couldn't be sold in Germany because of this).
All rotaries have a very poor combustion chamber shape.
PostPosted: 23:15 - 27 Jul 2004    Post subject: Re: Phew, you lot have been busy! Reply with quote
Except for a dramatically different system for the lubrication, using a pipe going to the exhaust to draw it through (and making it hideously dirty).
W@nkel
PostPosted: 23:19 - 27 Jul 2004    Post subject: Reply with quote
Big Pete wrote:
If you want a really powerful, high efficiency engine you use a forced induction 2 stroke diesel. Most really big engines (bulldozers, ships, generators etc) are this type.
And some of the Yank Trucks - The 2 Stroke style total loss system monograde oil we use in the Nortons is Shell Rotella DD+40, DD='Detroit Diesel'.
So Prof Pete, why are smaller 2 stroke diesels not widely used then?
Ava_Banana
PostPosted: 23:21 - 27 Jul 2004    Post subject: Reply with quote
At 37 I must confess I had no real interest in bikes until a few years ago, but now am very interested.
From a technical point of view I have always been interested in the Wankel engine (well, rotary engines). It constantly amazes me how "theoretically" inefficient the process of "converting reciprocal to rotary energy/force" is.
Mazda certainly do well with them. Very Happy
PostPosted: 23:27 - 27 Jul 2004    Post subject: Reply with quote
I haven't clicked on the link or looked at the rest of the thread but I can tell you that it was Norton, with a 1355 (or 599 depending on who you are) cc Wankel engined bike.
They make a heck of a noise! Twisted Evil
Right, now I can read the rest of the thread! Smile
W@nkel
PostPosted: 23:29 - 27 Jul 2004    Post subject: Reply with quote
TV Interviewer to Steve Spray; "Some of the other riders were complaining about oil mist coming from your exhaust", Steves response; "Well, they were so far behind me, how did they know".
Class!! Very Happy
PostPosted: 23:55 - 27 Jul 2004    Post subject: Reply with quote
Right read the thread, very interesting. However I have to ask why there is so much aggression form Superabusa... he who is without fault etc etc.
Superabusa wrote:
know you ain't going to agree with me on this Rot@ry but I couldn't give a flying fuck. I'm an aircraft engineer & I have covered Wankel engines in my training many moons ago, Norton's in fact! Also I'm older than you so screw the patronising bit mate.
Nowt patronising about THAT is there? Laughing Oh and I'm sure your bike IS considerably faster than mine. Laughing
I also have to ask why (in the interests of fairness) why W@nkel assumed that we wouldn't know what a Norton F1 was?
Yeah so a lot of us are young pocket rocket riders, but we have also got between us a wealth of biking knowledge! I for one am extermely interested in all aspects of engineering, and so I have a strong interest in this thread. I am only 24 but I have heard of the norton rotaries, and I know what a wankel engine is.
I also happen to have something of a soft spot for the more modern of British bikes! Laughing
Anyway, continue the Engineering discussion- but can we leave the bitching in F&FW for a bit please? Very Happy
I could very well bore everyone else rigid with tales of the most modern motorcycle factory in the world, but I've already done that this week! Laughing
W@nkel
PostPosted: 00:12 - 28 Jul 2004    Post subject: Reply with quote
MarJay wrote:
I also have to ask why (in the interests of fairness) why W@nkel assumed that we wouldn't know what a Norton F1 was? Yeah so a lot of us are young pocket rocket riders, but we have also got between us a wealth of biking knowledge!
Erm, dont think i assumed you wouldnt know what an F1 road bike is, just figured that a fair percentage of you wouldnt remember the race successes. Actually, im impressed with the level of knowledge on here.
Superabusas ok... Karma, fuk Karma.. LOL Laughing
W@nkel
PostPosted: 00:30 - 28 Jul 2004    Post subject: Reply with quote
Lets see if i can put a photo on here... Norton F1 'Sport'
Note the 'Overweight fuckin jellymold that even the police found hard to ride' in the background.
The last post was made 20 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.3 - MySQL Queries: 13 - Page Size: 138.62 Kb
