Cossack Voskhod 175 rebuild
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4  Next
moggie
PostPosted: 13:27 - 10 Jan 2013    Post subject: Reply with quote
Made alot of progress on the bike this week.
I ordered new tyres & tubes over new year from Wheelhousetyres.co.uk. ordered on the friday. Arrived on monday. They are Mitas H-05 3.25x16. came with tubes and rimtape all for £87.
Gutted to lose the old USSR tyres, but they were just a tad cracked and old. Sad
Heres a bit of the cracking
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3925.jpg
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3926.jpg
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3930.jpg
& a weird patched bit where the patch has fallen off
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3928.jpg
For posterity
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3922.jpg
The bike has had so few miles ridden on it the molding stud nipple things arent even worn down on the rear wheel
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3929.jpg
Fitting the new ones was pretty easy. I sanded down and prepped the wheels themselves and mounted the tyres on. Then left then deflated and masked over the sidewalls with tape. That way I could just paint them and inflate the tyre without the risk of damaging the paint when mounting the tyres on.
Even though both tyres are 3.25x16 the Ruskies must have had a different way of measuring their widths because the new tyres are a bit thinner. Maybe 3.50 would have been more similar, but its too late now. The tread isnt as cool, but its better than the Dunlop alternative.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3945.jpg
I don't know if this is unusual?, but the spokes have straight heads on them rather than a 90 degree angle. The hubs are specially designed for this, plus the spoke heads are hidden away from the elements.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3946.jpg
Halfway through painting
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3955.jpg
MT-03 | CX500B | Yamaha RS125 | Voskhod 2
moggie
PostPosted: 13:45 - 10 Jan 2013    Post subject: Reply with quote
By this point we've got almost everything ready for the rebuild, so we started off with the frame on a homemade trolley and put theengine back in:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3956.jpg
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3957.jpg
If you remember the engine had been lose in the frame and was missing a rear mount. This was the missing one. Im guessing they left it of because they couldn't be arsed to removed the engine cover and to get to the opening for putting the bolt back in
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3959.jpg
The kickstart rubber was missing so its got a new one now
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3960.jpg
Putting the sidestand back on isnt that easy. The cylindrical bit welded to the frame has got a spring and piston pressed inside it, so the only way to get the stand back in place is to press it back in with a clamp.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3961.jpg
With the rack and mudgaurd on its starting to look like a bike again
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3963.jpg
Used new bearings in the headstock. some of the old ones had split in two.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3967.jpg
Forks, fork covers and sideboxes back on
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3970.jpg
The batteries we had we going to be too big, so we are using this 12v 2.4ah backup battery instead. fits nicely. It'll get some padding to secure it in place later.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3971.jpg
The engine only has four wires. There'll be a lot more wiring on this thing than a Voskhod has ever had by the time its finished. The rectifier mounted on the frame is another piece of Yamaha RS125 being put to use.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3972.jpg
moggie
PostPosted: 13:26 - 17 Jan 2013    Post subject: Reply with quote
The tail light was missing from the bike, so thats yet another piece taken from the RS125. It has the right look, but wouldnt fit straight on because the bulb holder stuck out too far to fit with the curve of the mudgaurd. So I turned the lens around 180 degrees and fettled the back panel bit to allow this. Then since the reflector dish would no longer work for the numberplate light its got an outdoor led stuck to the bottom.
Fits nicely like this. Once mounted its level unlike in this photo:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3975.jpg
the led underneath:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3979.jpg
The indicators were a straight fit. Just needed an extra hole with a grommet in to make the wiring fit neatly.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3985.jpg
The speedo was missing its bulb + holder, so I cut up a piece from the broken Yamaha dash light holder and used that
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3987.jpg
and made a new speedo seal out of some old motorbike inner tube
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3989.jpg
The headlight had a big three pinned 6v 35w/35w bulb in it. I couldnt find a new one of these at all, not even a 6v one let alone a 12v. However a H4 fits the opening nicely, so with a rubber seal in there too its a solid fit and alot cheaper to replace.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3988.jpg
Now to look at the brakes!!!
Heres a demonstration as to why the brakes on these things are so pitiful. on the left is the FRONT drum from the Voskhod, Centre is the REAR from a Yamaha RS125 and the left is a REAR from a CX500. All bikes from roughly the same era.
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3993.jpg
It gets worse when you look at the widths side by side Laughing
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_3994.jpg
So with that in mind, here is a sneak peak at the plan b option for when the brakes arent enough and considering the horn in the lampbowl is purely cosmetic... Laughing Laughing
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4004.jpg
pepperami
PostPosted: 20:35 - 17 Jan 2013    Post subject: Reply with quote
Can you not get the brake shoes re-lined with a different/better material to improve braking?
moggie
PostPosted: 21:04 - 17 Jan 2013    Post subject: Reply with quote
Probably, Ive not looked into it. But we'll see what they are actually like first, I've not even ridden the bike anywhere yet. The back brake actually feels pretty good now and the front is much better (but still probably dreadful Wink )
blurredman
PostPosted: 20:24 - 09 Feb 2013    Post subject: Reply with quote
Any updates on this wonderful (ahem Laughing ) machine? Thumbs Up Thumbs Up
moggie
PostPosted: 14:00 - 07 Mar 2013    Post subject: Reply with quote
Here's the various bits I acquired for making new cables. The should be all fine, but it remains to be seen if the front brake cable will be good enough - might remake this one in thicker cable in the future
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4000.jpg
All the little end nipples are soldered onto the ends of the cables like this:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4001.jpg
Giving you something like this:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4002.jpg
and the finished cables:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4003.jpg
Heres the headlight back in place:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4009.jpg
and what the front end looks like with the indicators and rebuilt lamp:
https://i223.photobucket.com/albums/dd216/jascook/Voskhod/IMG_4007.jpg
We are actually way further ahead than this now, but I've not got the photos uploaded. The biggest problem currently is that once the front end wass all put back together we discovered one of the forks has got a hairline fracture to the welding at the axle end - so its leaking fork oil quite badly. We'll need to take it all apart again and reweld this up. Just haven't mustered the will to do this yet as Ive been distracted with other stuff.
Oh and the vespa ignition we ave used is crap! Evil or Very Mad it only switches off properly in the OFF position about half the time. So that's another thing which will need re-doing.
paddlesat16
PostPosted: 16:59 - 07 Mar 2013    Post subject: Reply with quote
Tis looking good Very Happy
Regards
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
pepperami
PostPosted: 20:00 - 07 Mar 2013    Post subject: Reply with quote
Thumbs Up Still watching Thumbs Up
VTRkemshell10...
PostPosted: 20:35 - 07 Mar 2013    Post subject: Reply with quote
Thumbs Up Thumbs Up Cool Cool
sweet thread - watching with interest
Past Rides: Sym Jet Euro X, Gilera DNA, Aprillia RS125 (Spains No1 Replica), 1991 Honda NSF, 2006 Honda CG125, 1992 Honda CB400 Super Four, 2000 VFR800 FY-I
Current Rides: 2001 VTR1000 FIRESTORM
Werny
PostPosted: 23:09 - 07 Mar 2013    Post subject: Reply with quote
A genuinely interesting rebuild project, really enjoying this thread!
Thanks for sharing Thumbs Up
map
Mr Calendar
PostPosted: 11:54 - 11 Mar 2013    Post subject: Reply with quote
Quick question.
With only a km/h speed dial do you expect any issues with MOT?
Or is there an age exception on things like this?
et1
PostPosted: 16:02 - 11 Mar 2013    Post subject: Reply with quote
Nice good quality work. Nice Thumbs Up
trevor saxe-coburg-gotha
PostPosted: 19:19 - 11 Mar 2013    Post subject: Reply with quote
blurredman
PostPosted: 19:44 - 11 Mar 2013    Post subject: Reply with quote
map wrote:
Quick question.
Speedometres aren't tested in MOT!
How many times? Laughing Laughing Laughing Thumbs Up
PostPosted: 20:08 - 11 Mar 2013    Post subject: Reply with quote
map wrote:
Quick question.
In theory not legal, but not an MOT point in GB. Loads of my bikes have kmh only speedos.
alexlawriewoo...
PostPosted: 12:11 - 12 Mar 2013    Post subject: Reply with quote
Really cool, watching with great interest!
Yamaha RXS100 [returned to mate], 1982 Honda CM125 [stolen], 1982 Suzuki GS850G
27cows
PostPosted: 14:20 - 20 Mar 2013    Post subject: Reply with quote
Dear God, I can't believe there's still one of these knocking about Laughing I had a 125 Cossack some time in the late 80s and can attest that it did indeed have the worst brakes ever devised. Made those on a Honda Camino seem decent.
Those indicators look suspiciously like RXS100 ones (83-86 model - the nice chrome ones before they stuck the horrible matt black ones on).
dialup_2001
PostPosted: 23:46 - 23 Mar 2013    Post subject: A REAL shock for you...... Reply with quote
...So there I am in my mates scrapyard and an old guy pushes in this old fucking wreck of a shit soviet era!!!
https://i413.photobucket.com/albums/pp211/dialup_2001/Canterbury-20110409-00353.jpg
He takes his £31 and walks out. I fall in love and take it home!!!!
alexlawriewoo...
PostPosted: 09:55 - 24 Mar 2013    Post subject: Reply with quote
I kind of fancy a downgrade, looking at these things.
Good buy.
f1fan111
PostPosted: 12:02 - 24 Mar 2013    Post subject: Re: A REAL shock for you...... Reply with quote
Very nice Very Happy looks earlier model from my research as rear is different do you know what year it is?
oh theres one on ebay at the moment if anyone is tempted Laughing
pepperami
PostPosted: 12:20 - 24 Mar 2013    Post subject: Reply with quote
I appluad you lot taking on these Soviet bikes, 10 out of 10 and much Karma .
I`m struggling with a Jawa Shocked , so how you lot manage to sort out these bikes out is a mystery?
However my Jawa has been put on the back burner at the moment while I sort out this Superdream I`ve picked up.
blurredman
PostPosted: 12:46 - 24 Mar 2013    Post subject: Re: A REAL shock for you...... Reply with quote
There were two.. The latter (a red one) went for just £250 or something.
There was an IZH Planetta on E-bay not too long ago (350 single), looked like fun, but alas, buy it now was way too high.
Interesting to note that the kickstart on the bike pictured, either is broken or the type that engages the engine on the release of the kickstart after pushing down rather than what is commonly the opposit.
pepperami
PostPosted: 20:43 - 24 Mar 2013    Post subject: Reply with quote
Is it my pc or have some of the pictures disappeared?
roadracejoe
PostPosted: 22:13 - 24 Mar 2013    Post subject: Reply with quote
Kickstart wrote:
map wrote:
Quick question.
All the best. here in NI speedos MUST have both MPH & KPH or its a fail Sad
The last post was made 13 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 4
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 146.54 Kb
