Project Old Barge - 1983 Suzuki GS850G
UnspeedySam
PostPosted: 14:32 - 13 Jan 2013    Post subject: Project Old Barge - 1983 Suzuki GS850G Reply with quote
So following on from this thread. I have just acquired a very large lump of Japanese steel for my mate who is new to biking.
I figured I should make a new thread as the other one is going to turn into the project thread otherwise.
The todo list currently looks like this:
  • Oil/Filter Change
  • Shaft Oil Change
  • Gear Box Oil Change - Turns out it's separate!
  • New Battery - Mine are too wide but the existing one is very very slowly taking a charge and does now crank over the engine properly so will do for now.
  • New coils or cover existing coils in silicone
  • Invest in some braided hoses - Brakes have just been bled and it made no difference so it looks like new lines time...or maybe a master cylinder?
  • Sort out the back right indicator - Done - Was just the bulb
  • Tap out a new thread for the right mirror...if I don't end up replacing the master cylinder - The existing one was stripped and poorly bodged with araldite and a split pin Laughing
Anyone care to comment on the brakes issue? Could it be the cylinder not the lines? They are rubber but don't look perished at all...
Photos:
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-prn1/553228_10151353783074921_741181605_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash3/543451_10151353782889921_369615698_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-snc7/486240_10151353783004921_285042955_n.jpg
Shaft
PostPosted: 14:43 - 13 Jan 2013    Post subject: Reply with quote
Ah, we've moved over here Smile
They aren't the best brakes, especially compared to modern bikes, it's often one of the trade offs of owning something old and interesting.
I wouldn't expect them to be so bad you have to pull back to the bars just to stop, but they aren't ever going to be in the same league as, say, your TRX.
If the system isn't obviously leaking, I would go with new fluid, decent pads and maybe steel lines, but don't ever expect them to be brilliant.
I would say my 1100 brakes are just about up to the job, which is probably true of most UJMs of the period.
UnspeedySam
PostPosted: 14:48 - 13 Jan 2013    Post subject: Reply with quote
Yeah I'm used to dodgy brakes. My ZZR ones weren't exactly brilliant before I bodged on Nissin 4 pot blade calipers. Oh...and I had an RXS100... Laughing
I've flushed these through with quite a lot of fluid using my one-way-valve bleeder and there was no improvement to the firmness of the lever. There was also very little air in the system.
The pistons and pads look fine and I love the little dust seals covering the piston and stopping them getting covered in crud...why don't we have that anymore!? So I think the best bet at this point is new lines...it's his first bike so he needs to be able to stop. Laughing
orac
PostPosted: 14:51 - 13 Jan 2013    Post subject: Reply with quote
hoses are meant to be changed every seven year any way (at least for the rubber ones) so do them as a start.
you can try trying the lever into the bar over night, if that improves it for a bit and then goes floppy again, it ever the master cylinder or they just crap brakes
UnspeedySam
PostPosted: 14:53 - 13 Jan 2013    Post subject: Reply with quote
I've tried pumping a LOT to improve firmness and it didn't so I'm thinking lines as a first thing to try. Thanks Thumbs Up
orac
PostPosted: 14:57 - 13 Jan 2013    Post subject: Reply with quote
yeh i read that, i have it in the past where pumping didnt work completely, leaving it tied into the bar seem to force any remaing air out into the resivoir. i nomrally pump it up as much pssoible and then tie it in for as long as possible 12 or more hours is fairly good if you can hold out that long, but as little as hour seem to work well to - may give you an early indicator (it only cost a couple of zip ties)
UnspeedySam
PostPosted: 15:02 - 13 Jan 2013    Post subject: Reply with quote
Ok. Sorry I thought you meant after trying the lines. Will lash it up now Smile
orac
PostPosted: 15:04 - 13 Jan 2013    Post subject: Reply with quote
no worries man, its just one of those little tricks that give an indicator of having to spend money or not, or most cases, spend the right money on the right thing instead of both things.
UnspeedySam
PostPosted: 15:11 - 13 Jan 2013    Post subject: Reply with quote
While I'm waiting for the tied down lever test. Is there any advantage at all of a 3 line brake line kit over a 2 line kit?
Seems odd that anyone would bother with a 3 line kit when you can just have 2 lines running from the master cylinder for 2/3rds of the price...
GrumpyGuts
PostPosted: 15:15 - 13 Jan 2013    Post subject: Reply with quote
You get that bike cleaned up nice and shiny then I think you have a fantastic machine there. Moar pics Thumbs Up
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
orac
PostPosted: 15:16 - 13 Jan 2013    Post subject: Reply with quote
i was going to go 2 piece on my bandit, but there wast space between the master cylinder and the tacho for the couble banjo, so jeck that clearance before you pull the trigger. also check the space that the line will run, if its a tight fit behind the head light then a single down to a splitter maybe the way to go
UnspeedySam
PostPosted: 15:22 - 13 Jan 2013    Post subject: Reply with quote
Ok cool. I figure if there are people selling kits then there must be room...but I will check. Thanks again for the advice. I'll let you know the outcome of the cable ties!
UnspeedySam
PostPosted: 15:23 - 13 Jan 2013    Post subject: Reply with quote
Yeah it is pretty filthy. Especially after the 80 wet motorway miles I did on it yesterday. Polishing will happen after I finish the dirty jobs that need doing. Thumbs Up
nowhere.elysium
The Pork Lord
PostPosted: 18:39 - 13 Jan 2013    Post subject: Reply with quote
Venhill lines were nice and easy to fit* on my GS, and really did make a significant difference. It felt incredibly marked, but that's largely down to the fact that it too had the 30-year-old rubber hoses, which were well outside of their projected lifespan.
Personally, I'd be tempted to just take the mirrors off altogether. If they're anything like the 650, they've not got the most useful field of reflection, and they'll just blur into complete incomprehensibility once you get above 2k anyway.
I didn't know it had a separate sump for the gearbox oil. Learn something new every day, I guess.
*The banjo screws into the line, as opposed to conventional lines which are completely pre-assembled. Sounds like a recipe for disaster, but actually works really well, if put together and tightened properly.
Shaft
PostPosted: 19:24 - 13 Jan 2013    Post subject: Reply with quote
Strictly speaking, it hasn't.
The gearbox and engine share the same oil, but there is a separate filler and level screw for the bevel gear at the engine end, which I've also seen referred to as the secondary gearbox.
The plug and screw are behind what would be the sprocket cover on a chain drive bike and you have to take the gear lever off to remove it.
nowhere.elysium
The Pork Lord
PostPosted: 19:25 - 13 Jan 2013    Post subject: Reply with quote
I'm slightly worried that I missed a significant job on my GS, now Laughing
Shaft
PostPosted: 19:37 - 13 Jan 2013    Post subject: Reply with quote
I don't know if yours is the same, I've just looked up the schematic on cmsnl and it's not very clear.
I only know about the 850 because I've done the job.
nowhere.elysium
The Pork Lord
PostPosted: 19:46 - 13 Jan 2013    Post subject: Reply with quote
It is a catastrophically poor diagram, isn't it? I had a quick look through the parts list, and it doesn't refer to any plugs in the kind of places they'd have to be in order to do what you suggested, so I think I'm OK on that one. Fingers crossed.
Shaft
PostPosted: 19:51 - 13 Jan 2013    Post subject: Reply with quote
Well, looky here!
https://www.thegsresources.com/_forum/showthread.php?t=118013&highlight=Secondary+Drive
In the first post is a link to a how to on changing the bevel oil on an 850 and, a bit further down, is a post from someone telling us the 650 isn't the same.
Birds, stone, killed Laughing
nowhere.elysium
The Pork Lord
PostPosted: 19:56 - 13 Jan 2013    Post subject: Reply with quote
Awesome sauce Very Happy
UnspeedySam
PostPosted: 20:10 - 13 Jan 2013    Post subject: Reply with quote
Yeah the filler says SAE 90 on it so it must be separate in some way. I assume this is separate from the shaft oil?
I feel like such a newb...
Edit: Read the link. Understand now Rolling Eyes
alexlawriewoo...
PostPosted: 00:59 - 14 Jan 2013    Post subject: Reply with quote
'Ello all. I'm the happy mate in question, good a time as any to make an appearance! Pretty chuffed, exactly the kind of bike I was looking for.
Shaft
PostPosted: 01:10 - 14 Jan 2013    Post subject: Reply with quote
Welcome along, there's a few of us here with a bit of a thing for these big 80s lumps, so you've got some company.
UnspeedySam
PostPosted: 10:16 - 14 Jan 2013    Post subject: Reply with quote
Left this overnight and cut off the cable ties this morning. It could well be a placebo effect but I'm sure it's a bit better. I certainly can't get the lever back to the bar now which I seem to remember doing yesterday.
I'll leave it free of cable ties until Alex pops over for a test ride tonight and see if it is still ok.
If it is still ok am I correct in thinking that the master cylinder is probably fine and the lines are my first port of call to improve things further?
alexlawriewoo...
PostPosted: 10:45 - 14 Jan 2013    Post subject: Reply with quote
Fingers crossed that's improved things. Although the service manual says to replace rubber hoses every two years, and I strongly suspect the current ones'll be a lot older.
This site describes a few common issues. Should help. Lot of fairly minor things, which is a good sign, I suppose!
Yamaha RXS100 [returned to mate], 1982 Honda CM125 [stolen], 1982 Suzuki GS850G
The last post was made 13 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 137.44 Kb
