| Author |
| SQL |
 SQL World Chat Champion
 Posted: 13:10 - 01 Oct 2013 Post subject: |
Head is a little battered but its the best condition 3MB head that has been on ebay for a while that has been cheap, its all getting sent off to be done rebore and tidying the head up too, it should run fine if worse comes to worse 2 metal head gaskets then the rubber one sorted.
The clearance shouldn't be an issue really. |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 13:17 - 01 Oct 2013 Post subject: |
Oh it wont cause it to run badly or anything like that, however if i was going to all the aggro of building the motor back up with the intention of keeping it & using it then i'd want everything specced up perfectly to get the absolute maximum i could out of the engine.
I think even if you get the squish 100% perfect on a race motor it barely accounts for 2% of peak performance. The fact that I know my H100 piston is scratched irritates me. The engine runs well, but I know it isn't perfect inside & this annoys me - I'd love an excuse to tear it all down & spec everything correctly  ____________________ Please be aware that the above post may be full of complete nonsense.
Riding: '07 KTM Duke II, Baotian BT49QT-20 Driving: '88 Volvo 340 |
| Back to top |
| SQL |
| Back to top |
| _Iain_ |
 _Iain_ Banned
| Back to top |
| SQL |
| Back to top |
| P. |
 P. Red Rocket
 Posted: 16:25 - 01 Oct 2013 Post subject: |
Erm... yeah don't remove the pump. If its for fun, just fill the tank and leave it. Not heard of many DT's going pop due to oil pump failure.  |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 16:33 - 01 Oct 2013 Post subject: |
Paddy said something about using engine braking on premix bikes usually ends in bang. If that's true then I wouldn't go premix if using the bike on the road - an autolube pump is extremely simple & would probbably be more effort to remove it and blank the hole off etc than to just spend 30 seconds priming it & adjusting the cable so the timing marks line up.
Plus - you've gotta carry a backpack with a bottle of two stroke & a measuring cup of some sort everywhere you go , then sit there working out precisely how many ML of two stroke you need for the amount topped up & mixing the fuel up on the forecourt. IDK, sounds like hassle - My little honda's done about half a bottle of two stroke over three tanks of fuel - perhaps consider fitting a smaller two stroke bottle if it's all about weight saving etc? I'm sure you'd get a few tankfuls from a 500ml bottle. ____________________ Please be aware that the above post may be full of complete nonsense.
| Back to top |
| evoboy |
 evoboy World Chat Champion
 Posted: 16:49 - 01 Oct 2013 Post subject: |
Running premix on the road is fine. But youll need to upjet slightly due to the oil weakening the mix slightly.
You can do damage by using the engine braking while running premix, but its not much different to using engine braking while running the pump. Both wont be feeding enough oil/fuel mix in at high rpm with no throttle input. On mine i normally give it blips of throttle with the clutch pulled in, or, roll with the clutch in instead.
Who uses engine braking on a 2stroke anyway?! ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Back to top |
| SQL |
 Posted: 17:52 - 01 Oct 2013 Post subject: |
As said just toying with idea based purely on weight saving. I may leave the pump on it but I have no idea if it even works yet as when I got the bike it had been seized but when i removed the 2 smoke tank it was half full so it don't add up. mainly why I said premix only as I have a 25 gallon tank that I can use for my premix  |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 18:20 - 01 Oct 2013 Post subject: |
As I said when you bought it, the bike was owned by a rich downie & daddy was going to buy him another bike at the end of it anyway, so it diddnt matter if it was bodged...he also killed a mito & another GPR the same year.
It was in our warehouse at delta in bits for over a year after my ex boss's son decided he'd bounce it off the limiter in the snow when it had trouble starting. He also diddnt put any anti freeze in it, hence no radiator. When it worked he would redline every single gear every day from cold and always ran it on either £3 a bottle carlube or his dads chainsaw oil because he'd spunked all his money on MDMA and anodised bar ends.
Thats why it siezed. I assisted in removing the cylinder at the time and found bits as much as an inch of piston ring in the expansion chamber.
Hence why I said to Paddy to consider the engine as an absolute write off, bin it and buy a second hand motor. Captain spacktastic also had a play around with the gearbox oil & changed the clutch himself, so I wouldnt trust that either. Look at the tyres - he had a 150 rear fitted "because its a superbike and they race them like that, makes it corner well good at 130mph or more. I've had 140 out of it down bluebell hill tho"
IMO having seen the guy ride & work on it I'd not be keeping it, just stuffing a new engine in it, MOT & sell, then buying a non monged DT with the profits - it'll turn into a real expensive ballache otherwise.  ____________________ Please be aware that the above post may be full of complete nonsense.
| Back to top |
| SQL |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 15:13 - 03 Oct 2013 Post subject: |
Whatever you do dont oversize the rear and not the front.
Every bike i've ever done that on cornered like a sack of shit, it's to do with the profile of the tyre - either the front or the back of the bike will end up dropping in faster  ____________________ Please be aware that the above post may be full of complete nonsense.
| Back to top |
| SQL |
 Posted: 21:39 - 15 Mar 2014 Post subject: |
Update time!!
Case has been split the crank is perfect so is the big end bearing, the stator side main bearing has a slight rumble but I have mains to go in it.
Gearbox looks good too
Tommorow goes back together and then pics  |
| Back to top |
| SQL |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 12:18 - 17 Mar 2014 Post subject: |
Did you use loctite when fitting those bits of selector mechanism behind the clutch? I promise you it will cause huge amounts of pain if you diddn't
Looking good. You need to get this done!!
Edit, have you used instant gasket to put the cases back together?  ____________________ Please be aware that the above post may be full of complete nonsense.
| Back to top |
| SQL |
| Back to top |
| SQL |
| Back to top |
| _Iain_ |
 _Iain_ Banned
| Back to top |
| SQL |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 20:08 - 17 Mar 2014 Post subject: |
Lolwut?
A piston kit comes with a little end, gudgeon pin, circlips, rings and usually a little end bearing.
No point buying pistons seperately or running used pistons, one leads to £££ buying the rest of the kit the other leads to engine faliure. ____________________ Please be aware that the above post may be full of complete nonsense.
| Back to top |
| SQL |
| Back to top |
| evoboy |
| Back to top |
| lukamon |
 lukamon World Chat Champion
| Back to top |
| SQL |
 Posted: 10:11 - 18 Mar 2014 Post subject: |
| Back to top |
| _Iain_ |
 _Iain_ Banned
| Back to top |
The last post was made 11 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
