GSX 600
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3, 4  Next
sickpup
Old Timer
PostPosted: 02:59 - 30 Nov 2025    Post subject: Reply with quote
CrypticCrud wrote:
Why should it have been a giveaway?
Because you don't strip a tank and ultrasonic clean the cards unless there is a problem.
CrypticCrud
PostPosted: 22:01 - 30 Nov 2025    Post subject: Reply with quote
Is it not done as an annual maintenance thing?
Appreciate the replies btw!
CBT - Aug24, Theory - Jun25, Mod 1 - Jul25, Mod 2 - Sep25
Kawasaki Z125 > Honda Z125 > GSX-R600 Y
blurredman
PostPosted: 09:01 - 01 Dec 2025    Post subject: Reply with quote
I dunno. Some people have some wasteful views on maintenance.
CrypticCrud
PostPosted: 10:11 - 01 Dec 2025    Post subject: Reply with quote
The guy I got it from said he just rode them and had the bikes picked up to be serviced, that’s the reason I asked.
So maybe the guy was being milked by his guy. Who knows.
PostPosted: 10:30 - 02 Dec 2025    Post subject: Reply with quote
Seeing as I feel a bit sorry for OP here I thought I'd add a further 2p (despite his prior insults of my attempts to help him).
So, Suzukis seem to have this really annoying issue - Not related to rust in the tank, or carb problems or electrical problems.
They have this little filter that sits *inside* the fuel pump assembly which could well be described as a tea bag filter. I found this out to my cost when my GSX-S1000F decided it didn't want to go above 3000rpm. Turns out this pesky little filter just goes bad after time. Not blocked per se, not full of gunk but it shrinks, turns black and looks literally like a used teabag. I had to remove the tank on my GSX-S, which annoyingly needs the fairing off, some of the trim around the ignition switch and seat unit and a bunch of other gubbins. It's a massive pain in the backside. On the GSX-R it should be a lot easier. I then had to turn the tank upside down, remove the fuel pump assembly, dismantle it and replace the filter with a new filter. The effort was much more than the parts, as the part was twelve quid off of ebay.
No issue with injectors, no issue with the tank (although I did spot some spots of rust on the underside) and no issue with icing as it's injected.
Once the filter was replaced, the bike ran absolutely fine again.
CrypticCrud
PostPosted: 14:37 - 02 Dec 2025    Post subject: Reply with quote
Bloody lovely day here and was hoping it’d be ready but alas no, not yet!
CrypticCrud
PostPosted: 19:00 - 04 Dec 2025    Post subject: Reply with quote
It looks like the saga may be coming to an end.. but with my luck I doubt it.
Apparently the kit turned up and they’ve installed it.. and from what I can gather.. and don’t quote the shop on this..
they’ve used a mini light to check all the nooks and crannies and found dirt bunging up places that it shouldn’t. (Despite several sonic cleaning cycles)
Having been on the side stand for 18 years give or take 1000 miles without defuelling has furred up said nooks and crannies especially down the number 1 side (presumably that’s the side stand reference) which they have now cleaned. (Shouldn’t they have checked this the last time?)
Anyway.. I had quick listen (not that I know what to listen for) and it sounded a lot better, choked and idling. And they want to road test it from cold to see what’s what.
And now..
They’re waiting for the chainhugger and two tyres to turn up (road 4s thanks for the recommendation) then they’re going to wash it and stick everything on and then we should be good to go.
They’ve got £1800 on my account and they’ve said I can expect change but how much, I don’t know.
If you want to leave some guesses down below, it’ll be interesting to see if you experts (more experienced than me) can get anywhere close
Bear in mind, previous to all this, they’d had £167 out of me to tell me that I’d run out of juice.. so you can exclude that bit of the saga from the final total.
Their labour is £70 an hour.
Thermistors £12
Teabag filter £35.
Chain hugger £135
Fuel pump rebuild kit £128
2 Road 4s £387 fitted.
£95 pair of goretex gloves
£70 bike cover.
All the work / gloves / cover up to last week was just under £900.
Fire away!
CrypticCrud
PostPosted: 19:06 - 04 Dec 2025    Post subject: Reply with quote
Oh and if anyone wants to meet up and give it a listen to /blast when it’s all done.. I’m in the NG postcode area bordering on S44.
Hey I might even have a bike and be able to travel! Rolling Eyes
Kentol750
PostPosted: 21:22 - 04 Dec 2025    Post subject: Ouch. Reply with quote
Wow! I'd be expecting road 6 and a happy ending for that money. You can pick 4s up for around 200 a pair.
Some bikes.
CrypticCrud
PostPosted: 13:09 - 05 Dec 2025    Post subject: Re: Ouch. Reply with quote
Where from? They get their tyres from Cambrian (looking over the SD shoulder)
struan80
PostPosted: 17:03 - 05 Dec 2025    Post subject: Reply with quote
That's a lot of money.
Kentol750
PostPosted: 21:06 - 05 Dec 2025    Post subject: Reply with quote
My bad. 200 plus vat. But if you know where to look, you'd get a pair fitted for under 300. This time of year they're are plenty of deals around. Pro tyre are good and 6s are about 320 fitted. Bt32s are a lot cheaper and very similar.
Some bikes.
CrypticCrud
PostPosted: 17:28 - 09 Dec 2025    Post subject: Reply with quote
Picked the bike up today and it sounds better than it did. Will take it out for a spin tomorrow and see if I can make it further down the M1
See attached a picture of aforementioned teabag filter & other assorted knackered bits.
CrypticCrud
PostPosted: 13:30 - 10 Dec 2025    Post subject: Reply with quote
And it’s back in the shop!
I’d cry if I had any tears left!
to v or not to v
PostPosted: 20:04 - 10 Dec 2025    Post subject: Reply with quote
i feel for you.
at least you are getting the bike sorted in winter and not missing out on the nice riding weather.
Moto Guzzi V7.
CrypticCrud
PostPosted: 20:47 - 10 Dec 2025    Post subject: Reply with quote
to v or not to v wrote:
i feel for you.
I appreciate that!
Shop are retracing their steps to see if they’ve missed something or the fuel pump is faulty.
Classic or not, next time I’m buying new(er)!
PostPosted: 10:36 - 11 Dec 2025    Post subject: Reply with quote
i feel for you.
I appreciate that!
Newer is better, but so is a higher mileage bike that's been used. Without the fluids circulating and being changed regularly these kind of problems happen from just standing - at least the tank isn't rusted through. A bloke I know has had one of these SRADs in a container (worst posible storage place) for well over 15 years,I daren't think of the parlous state its in.
CrypticCrud
PostPosted: 00:29 - 12 Dec 2025    Post subject: Reply with quote
Been down today and they’re replacing the float valve needles?
Yup, even they admitted it’s something they should’ve tried before!
We shall see!
CrypticCrud
PostPosted: 20:51 - 12 Dec 2025    Post subject: Reply with quote
Got the bike back today and they think they’ve cracked it. It certainly feels like it… we shall see!
jeffyjeff
PostPosted: 15:30 - 13 Dec 2025    Post subject: Reply with quote
CrypticCrud wrote:
Been down today and they’re replacing the float valve needles? Yup, even they admitted it’s something they should’ve tried before!
Your tribulations prove the validity of the notion that machinery suffers neglect through non-use. Maybe your mechanic should have considered replacing all of the 35-year-old parts with ones that come in the rebuild kit. What a concept!
Your sad story casts doubt that your mechanic is an "expert" just because he/she accepted money for experimenting with your bike. I can only imagine your frustration. If this happens enough, maybe you will be moved to pick up some tools and do the work yourself. Better to fuck it up yourself and learn a lesson than to pay someone else to do it. Wink
CrypticCrud
PostPosted: 11:42 - 14 Dec 2025    Post subject: Reply with quote
Without a doubt! Definitely been an eye opener! And I never even considered that not draining the tank could be such a pain in the ass!
[\quote]
I’m not sure which bit you’re referring to… does a fuel pump rebuild kit include float valve needles? (I’m still learning so it might be a stupid question!)
But AFAIK, they had to order in a separate kit for that.
quote="jeffyjeff"]
Yeah I have felt frustrated but as you’ve pointed it’s not a new bike and older things are temperamental, I mean look at some of the members here Wink They’ve said I’ve been more patient than a lot of people would which I don’t believe.. I’ve been chomping at the bit to actually get to ride it and I’ve probably been asshole and they’re just too polite to say so.
As for doing it myself.. as much as I’d like to, I don’t have a covered space, or any space for that matter. And yeah I might be paying through the nose for the work but at least I know it’ll get done & I can take it back if it’s not completed. They still haven’t charged me for any work and won’t be doing so till I’m satisfied.
Having said that someone suggested another place, Melted Sliders I think it was called. Thing is the guys I use are just around the corner and there aren’t many repair shops round here & the few that are I wouldn’t take a toy car to! Maybe I should give them a try.
Everyday’s a school day. All your thoughts and comments (barbed or not) are much appreciated!
CrypticCrud
PostPosted: 23:24 - 20 Dec 2025    Post subject: Reply with quote
Final bill was £1908. £945 was labour.
Had a new battery on for good measure, so all in all it’s been about £2100 spent.
Took it for a spin yesterday / today and all seems well. (That was the kiss of death!)
Now for some fun!
PostPosted: 12:29 - 21 Dec 2025    Post subject: Reply with quote
Shocked
Does that price include lipstick so you could at least look pretty whilst they fucked you?
CrypticCrud
PostPosted: 19:23 - 21 Dec 2025    Post subject: Reply with quote
Ste wrote:
Shocked
I didn’t see it on the breakdown.. maybe there’s another bill due. Very Happy
sickpup
Old Timer
PostPosted: 10:37 - 23 Dec 2025    Post subject: Reply with quote
Welcome to old age Ste, nice to see you here.
Unfortunately Labour rates over the last two decades have gone through the roof. £60-80ph isn't unusual in non-dealerships and £100-140 in dealerships.
Page 3 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 134.66 Kb
