Aprilia AF1 125 Replica - Full Rebuild - Updated 6-11-18
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
Phil_B
PostPosted: 23:37 - 13 Mar 2017    Post subject: Reply with quote
Hi,
Will make sure I turn that round when the cable comes. As for the flywheel, it is the original one that came with the bike so I'm guessing the starter gear matches as I had no issues with it.
This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3
PostPosted: 23:47 - 13 Mar 2017    Post subject: Reply with quote
Hiya
When you attach the cable you poke the cable through the end of the housing, then push the end out through the window, push the blade in place with the hole for the nipple in line with the window, hook the nipple into place and then rotate the blade 180 degrees within the housing. Then the nipple on the cable is held in place by the housing.
Can you take a better piccy of the flywheel? So I can see the holes. On the 123 flywheel the holes are blanked off.
Note that VERY early 123 engines had the same ignition as the 127, but think these early ones were only fitted to the Red Rose custom thing
Katy
Phil_B
PostPosted: 00:00 - 14 Mar 2017    Post subject: Reply with quote
From what you've said it seems to be the 127 flywheel, but with the 123 ignition.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Mobile%20Uploads/image_zps7jdg2ooc.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Mobile%20Uploads/image_zpsmlatgvjr.jpg
Yamaha R3
PostPosted: 00:10 - 14 Mar 2017    Post subject: Reply with quote
Yep, that looks like a 127 flywheel. On the 127 ignition (which has a black coil rather than the blue coil) there is a set of timing marks embossed on the stator. Hence you can check the timing with a strobe light through the cutouts (as the 123 ignition advances with rpm, this isn't really worthwhile on a 123).
The flywheels are hard to find for sensible money so people tend to stick on whatever they can find.
I am toying with having a batch of flywheels made up, just drilled to take the existing starter gear (place has made SEM flywheels before but only for non electric start models, and they are not interested in making the electric start ring gear).
Katy
Phil_B
PostPosted: 00:20 - 14 Mar 2017    Post subject: Reply with quote
When I took the flywheel off I did wonder, as there didn't seem any point to the arrow. As I've owned the bike from new, this is how it's come out of the factory, I haven't changed any of the ignition parts. I just hope it all works now as if I have to change the flywheel I might need a new starter gear too!!
Yamaha R3
PostPosted: 00:35 - 14 Mar 2017    Post subject: Reply with quote
Strange, as yours is a late Sintesi, nowhere near the cutover from the 127 to the 123. Could a dealer have changed it when servicing it?
Katy
Phil_B
PostPosted: 08:54 - 14 Mar 2017    Post subject: Reply with quote
I guess it is possible it's been changed, although I never had any issues with it starting so can't really see why it would have been. Just one of those things, I've learnt a little bit more, you are a wealth of knowledge Smile
Yamaha R3
Phil_B
PostPosted: 10:39 - 14 Mar 2017    Post subject: Reply with quote
The engine is almost complete, it's come a long way from the corroded mess that smelt of cat piss!!
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/57-Engine2_zps23ad4602.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/image_zpsdoqpoyeu.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/38s-ClutchCover_zpse19c2c8d.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/image_zpsv1ez0dn2.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/image_zpslovnf3ik.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/image_zpsk87jx5z7.jpg
Yamaha R3
NutsyUk
PostPosted: 15:42 - 14 Mar 2017    Post subject: Reply with quote
At what point does a bike restoration become a scratch build? :p
I bow to your bravery and skill... Amazing work done so far.
Ill be honest. I really really doubt i would ever have taken the challenge.
Lexmoto XTR S 125 Sold!
Phil_B
PostPosted: 16:50 - 14 Mar 2017    Post subject: Reply with quote
That's a good question, being honest I think I'm somewhere I between. I've kept as much as I could and replaced what I had to.
Bravery? Or stupidity? There are many reasons I started this, hopefully they'll end up being worth it...we'll see when/if I get her running again!
I've learnt a lot, done things I've never done before, and emptied my wallet many times over. Would I do it again? Definitely not with something as bad as what I started with this time.
Yamaha R3
PostPosted: 17:48 - 14 Mar 2017    Post subject: Reply with quote
It's really bugging me you are using that mankey manifold and plastic covers on that lovely clean engine. Laughing
Phil_B
PostPosted: 18:05 - 14 Mar 2017    Post subject: Reply with quote
It's bugging me too! Once up and running I'm thinking about putting the 34mm carb on which will require a new manifold so that'll be sorted. The plastic covers do need something doing with them, but I'm not sure what yet, I guess a spray to match the engine is the best option.
Yamaha R3
PostPosted: 18:51 - 14 Mar 2017    Post subject: Reply with quote
You'll struggle to get it bob on, it might be worth thinking about a complementary colour instead Thumbs Up
There is a gap of 1 year, 195 days between these two posts...
BenR
PostPosted: 22:56 - 25 Sep 2018    Post subject: Reply with quote
Did this ever get finished?
Phil_B
PostPosted: 00:42 - 11 Oct 2018    Post subject: Reply with quote
As embarrassing as it is....not yet!
It's still ongoing, I've done a few bits here and there as and when I've had chance, but it's still a work in progress...
I haven't given up on it yet...one day! haha Smile
Yamaha R3
BenR
PostPosted: 19:49 - 11 Oct 2018    Post subject: Reply with quote
At least you've still got it. Laughing Do projects ever get finished. Will look forward to updates. Thumbs Up
Phil_B
PostPosted: 20:40 - 15 Oct 2018    Post subject: Reply with quote
I've been getting some stick off my work colleagues with it dragging on...I got told to get my lad on it as he's got his hand in with some lego technic, might get finished then! haha
Hoping to have something to show soon...then again... Wink
Yamaha R3
stevo as b4
PostPosted: 22:05 - 15 Oct 2018    Post subject: Reply with quote
I wouldn't worry about it, it'll be a damn awesome 125 when it's done that's for sure!
It's taken me since July to sort my clutch, re-build my powervalve governor and paint my engine casings. Oh and I've modified the rear carrier rack and fitted some stickers. The bike only needed a top end re-build and my new ignition fitting neither of which I've done yet.
Phil_B
PostPosted: 22:31 - 15 Oct 2018    Post subject: Reply with quote
Life just keeps getting in the way, although I am getting tired of moving boxes around in the house! I've got some spare holidays from work booked so hope to get a rolling chassis back together soon. Worst thing is, a few days graft will see most of it back together.
There is some more painting of small bits to do, but most of it is ready to go...just need to get my lazy ass in gear and get it done!!
It will be nice to see it all back together...even if it doesn't start when I'm done haha
Yamaha R3
BenR
PostPosted: 23:10 - 15 Oct 2018    Post subject: Reply with quote
That's the spirit. Wink make sure you've got the key still I've gone & lost the one for mine. Rolling Eyes Embarassed
Phil_B
PostPosted: 21:33 - 06 Nov 2018    Post subject: Aprilia AF1 125 Replica - Full Rebuild - Updated 6-11-18 Reply with quote
So, after a very long break in the project, with several false starts, I've finally got going on the rebuild. With all the bits that I have replaced, I'm not sure
if the project is a restoration or a rebuild, realistically a hybrid of both. This project has been many things for me, but the end product of being able to ride the
motorbike that I bought in 1991 is all that counts.
When I started off taking photos, I wanted to make sure that everything went back to where it came from, but it's evolved into a full-on geek account of what I've been up to!
For those that have followed the project, I hope you'll enjoy seeing the bike returning to how it should be, piece by piece. As I go along I'll try to remember what I've
replaced, and what I've done, so you can see the full picture of what this has taken. Unfortunately I seem to have lost the file with all the costs involved, but it's
been way more than the bike is worth now, and what I paid for it to start with...it's only money, and you can't take it with you at the end!!
Front wheel
Powdercoated original wheel. New bearings, wheel spacer, disc bolts, brake disc.
1 - Fit first bearing
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/1DSCF1010_zpsxwvnpekw.jpg
2 - Insert spacer
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/2DSCF1011_zpsxijat1nq.jpg
3 - Fit second bearing
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/3DSCF1012_zpsuprkptpk.jpg
4 - Loctite disc to wheel
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/1%20-%20Front%20Wheel/4DSCF1023_zpsdtwyxob4.jpg
Frame & yokes
Powdercoated original frame and top yoke. New top bearing
1 - Fit top bearing
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/5DSCF1028_zpshuvjrbqn.jpg
2 - Fit bearing cup
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/6DSCF1027_zpsmoiq4tlf.jpg
3 - Grease bearing and fit stem into frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/7DSCF1031_zpspmnfipcr.jpg
4 - Place cover over stem, top bearing and frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/8DSCF1039_zps64gwb6a6.jpg
5 - Fit stem nut and tighten
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/9DSCF1041_zpsa1cxzrml.jpg
6 - Place top yoke over stem
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/10DSCF1071_zpshxc93ijj.jpg
7 - Fit nut into stem and tighten
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/11DSCF1045_zpsmnhvg0gi.jpg
8 - Frame up onto paddock stands
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/2%20-%20Frame%20and%20Yokes/12DSCF1047_zpsmqedovhj.jpg
Yamaha R3
Phil_B
PostPosted: 21:39 - 06 Nov 2018    Post subject: Reply with quote
Forks
I've fitted a spare pair of forks until I've painted and rebuilt the good set I have, so they aren't pretty to look at and only temporary!
1 - Slide left fork through yokes until level with the top
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/3%20-%20Forks/13DSCF1140_zpseaexsxst.jpg
2 - Tighten top yoke bolt
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/3%20-%20Forks/14DSCF1141_zpskuwqg8yb.jpg
3 - Tighten bottom yoke bolts
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/3%20-%20Forks/15DSCF1144_zpsly1ut1xd.jpg
4 - Slide right fork through yokes until level with the top
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/3%20-%20Forks/16DSCF1145_zpsyyqenkgp.jpg
5 - Tighten top yoke bolt
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/3%20-%20Forks/17DSCF1147_zpsfzctzgxy.jpg
6 - Tighten bottom yoke bolts
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/3%20-%20Forks/18DSCF1149_zpsq6dcfnuw.jpg
Fitting the front wheel
New speedo drive. Need to tidy up the spindle and paint the spacer.
1 - Fit speedo drive, slide tab into slot in wheel
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/4%20-%20Front%20Wheel/19DSCF1150_zpsnrtxqnmf.jpg
2 - From the left side, slide spindle through fork, speedo drive and wheel
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/4%20-%20Front%20Wheel/20DSCF1155_zpsureg9wdh.jpg
3 - Slide spindle through spacer and fork
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/4%20-%20Front%20Wheel/21DSCF1157_zpsbgflxhta.jpg
4 - Fit bolt into spindle and tighten
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/4%20-%20Front%20Wheel/22DSCF1160_zpsjbehwl8q.jpg
5 - Tighten left side pinch bolts
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/4%20-%20Front%20Wheel/23DSCF1162_zpsujj0kpas.jpg
6 - Tighten right side pinch bolts
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/4%20-%20Front%20Wheel/24DSCF1164_zpsmtljk9zm.jpg
Yamaha R3
Phil_B
PostPosted: 21:43 - 06 Nov 2018    Post subject: Reply with quote
Rear suspension
Second hand shock and linkages.
1 - Fit bushes into frame for lower linkage
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/25DSCF1055_zpsj0oxipav.jpg
2 - Fit lower linkage
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/26DSCF1057_zpscugx560b.jpg
3 - Fit bushes into frame for rear shock absorber
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/27DSCF1061_zpsbueuzbz3.jpg
4 - Fit rear shock absorber
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/28DSCF1063_zpsnw8gmlne.jpg
5 - Grease up middle linkage in 3 positions
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/29DSCF1065_zpspnj4cg3q.jpg
6 - Fit middle linkage to bottom of shock absorber
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/30DSCF1066_zpsk3rrkuyo.jpg
7 - Fit middle linkage to lower linkage
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/5%20-%20Rear%20Suspension/31DSCF1068_zpsgh5blqqf.jpg
Swing arm
Powdercoated second hand swing arm. New bearings, locking nut.
1 - Screw in adjuster to right side of frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/33DSCF1078_zpskxn6ssjv.jpg
2 - Fit bush into left side of frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/32DSCF1077_zpsbra7f1pc.jpg
3 - Fit plastic washers to left and right sides of swing arm
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/34DSCF1080_zpsggumjceq.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/35DSCF1082_zpszvoza7n8.jpg
4 - Position swing arm in frame and slide bolt through
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/36DSCF1083_zpsanheri29.jpg
5 - Screw adjuster onto bolt. Once the engine is in the correct spacing and tension will be achieved.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/37DSCF1084_zpsudjqu1q5.jpg
6 - Fasten locking nut onto adjuster
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/38DSCF1085_zpseyeljdyb.jpg
7 - Fasten swing arm to middle linkage
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/6%20-%20Swing%20Arm/39DSCF1092_zpsjezgyae5.jpg
Yamaha R3
Phil_B
PostPosted: 21:45 - 06 Nov 2018    Post subject: Reply with quote
Rear wheel hub
Powdercoated original sprocket carrier and wheel. New bearings, bolts, sprocket, disc
1 - Fit bearing to eccentric hub (external groove side)
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/40DSCF1094_zpsnxixz6qn.jpg
2 - Fit spacer, bearing and circlip on opposite side
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/41DSCF1096_zpsaw3dljor.jpg
3 - Slide eccentric hub into swing arm, positioning recessed side against tab (shown in photo)
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/42DSCF1097_zpsy8wgrbeg.jpg
4 - Bolt hub into swing arm
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/43DSCF1100_zpsjj70px0a.jpg
5 - Fit brake carrier over external circlip side of hub
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/44DSCF1107_zpsldey4aqi.jpg
6 - Fit external circlip
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/45DSCF1115_zpsmkbrd7wc.jpg
7 - Fit brake carrier positioning plate
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/46DSCF1116_zpszvg4rea3.jpg
8 - Fit cush drive onto sprocket
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/47DSCF1119_zpss3efojnh.jpg
9 - Fit cush drive and sprocket into sprocket carrier
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/48DSCF1121_zpsivcq2ikd.jpg
10 - Fit circlip to back side of sprocket and carrier
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/49DSCF1192_zpspwjicltt.jpg
11 - Loctite brake disc to carrier and spindle
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/50DSCF1123_zps4cayur3q.jpg
12 - Slide spindle through hub from left side
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/51DSCF1126_zpsuvk6gl3h.jpg
13 - Slide sprocket carrier onto spindle splines
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/52DSCF1127_zpsflemvyvs.jpg
14 - Fit washer and nut onto spindle (split pin to be added)
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/53DSCF1129_zpshbtga6n2.jpg
15 - Fit sprocket guard to swing arm
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/54DSCF1134_zpslec5sqjl.jpg
16 - Bolt wheel to spindle lining up hole in wheel with semi-circular recess on spindle
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/7%20-%20Rear%20Wheel%20Hub/55DSCF1138_zpsux1kd60l.jpg
Side stand
Powdercoated original bracket. New bolts, stand, bush for rubber foot, spring
1 - Stand parts
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/56DSCF1166_zpspblpjmiu.jpg
2 - Fit bush into rubber foot
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/57DSCF1170_zpsyembknbh.jpg
3 - Fit rubber foot into stand and bolt on
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/58DSCF1171_zps2bgt2xmu.jpg
4 - Grease up and fit bushes into bracket
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/59DSCF1173_zps17r4rmh4.jpg
5 - Bolt stand to bracket
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/60DSCF1181_zpsfikvwp6n.jpg
6 - Fit spring to bracket and stand
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/61DSCF1186_zpsflfs1xaq.jpg
7 - Fit stand to frame
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Full%20Rebuild/8%20-%20Side%20Stand/62DSCF1187_zpsvwsjs4ij.jpg
Yamaha R3
Sister Sledge
PostPosted: 07:12 - 07 Nov 2018    Post subject: Reply with quote
I know how much hassle it is to keep these build threads going but we appreciate it.
Powder coating: What happens with parts surfaces and threaded areas? Looking at the wheel in particular - do you mask it before sending off or is it a case of re-tapping things and removing overspread?
CCM 404 DS
The last post was made 7 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Page 4 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 159.61 Kb
