Rear shock hydraulic fluid
Rookie
PostPosted: 13:51 - 10 Nov 2006    Post subject: Rear shock hydraulic fluid Reply with quote
This is probably going to have been a nice big cockup on my part. Brick Wall
I needed to get the rear shock off my Cat frame as I've got a buyer. Whilst getting the rear shock loose was fine, I found the undertray and the frame stopped the cylinder from slipping out. After trying to get that blasted tray out for half an hour, I conceded defeat and split the shock at the banjo bolt. It promptly started pissing hydraulic fluid everywhere. Not too much of a problem, until I realised I don't have the faintest clue how to bleed and refill it, and neither does the buyer. Will it be a big headache on his part to sort it out? At the moment it looks exactly like a brake fluid line, with the banjo bolt and the one-use copper washer. Is it a tricky job to do? The cylinder is covered in warning signs so I'm a bit concerned. Confused
Cheers all. Thumbs Up
Rookie
PostPosted: 14:07 - 10 Nov 2006    Post subject: Reply with quote
Poo. Crying or Very sad £30 down the crapper.
0ddball
PostPosted: 14:16 - 10 Nov 2006    Post subject: Reply with quote
https://daverattigan.typepad.com/the_grace_pages/images/doh.gif
Rookie
PostPosted: 15:47 - 10 Nov 2006    Post subject: Reply with quote
Mr. Man at Dog Motorcycles tells me it's still saleable, if not to the nice chappy who wanted it in the first place. Sorry! Sad
S'pose I'll bosh it on eBay, see what they go for.
sickpup
Old Timer
PostPosted: 20:31 - 10 Nov 2006    Post subject: Reply with quote
As you have allowed the damping oil out of the shock if the nitrogen is held in a bladder you have probably ruptured this as well.
The bladder needs the pressure of the oil to stop it blowing out.
Mr Man doesn't know what he's talking about.
PostPosted: 20:34 - 10 Nov 2006    Post subject: Reply with quote
Sounds trashed. Rebuild would be £50~£100 I suspect, so for £30 it is not financially worthwhile to rebuild to sell.
The last post was made 19 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.2 - MySQL Queries: 14 - Page Size: 52.09 Kb
