Yamaha DT 125, 1988 model, HELP it wont start
jim
PostPosted: 21:23 - 08 Apr 2002    Post subject: Yamaha DT 125, 1988 model, HELP it wont start Reply with quote
Ok it has a good engine and produces a spark. It is not the ignition coil of the carb. Anybody got any ideass?? i would appreciate the feedback.IF you need to know more just ask me on this forum i will reply ASAP. Thanks alot, much appreciated.
Scooby
Scrappy Doo
PostPosted: 21:24 - 08 Apr 2002    Post subject: battery Reply with quote
What about your battery? Might have enough to create a spark but might not be fully charged so won't run the bike.
jimmy
Guest
PostPosted: 16:43 - 09 Apr 2002    Post subject: Reply with quote
battery is fine
McJamweasel
BCF Junkie
PostPosted: 17:06 - 09 Apr 2002    Post subject: Reply with quote
Check the fuel line/filter.
jim
PostPosted: 21:30 - 09 Apr 2002    Post subject: reluctant dt125 Reply with quote
fuel lione and filter ok no blockages, carb stripped and cleaned, jets clear, could it be the electronic igniton faulty?
PostPosted: 23:58 - 09 Apr 2002    Post subject: Reply with quote
Could be a cdi fault. Get an inductive timing light (ie, the type where the sensor just clips over the HT lead) and see what the timing is like while the bike is being kicked over. If the timing is wrong, but consistant then check that the rotor is in place correctly. Normally it is keyed in place, but the key can shear off allowing it to have moved a bit.
How fresh is the petrol? Are the reed valves sealing properly? Has it got decent compression (ie, piston and rings good)
Scooby
Scrappy Doo
PostPosted: 16:38 - 10 Apr 2002    Post subject: keith Reply with quote
What would we do without Keith hey.......... 8)
jim
PostPosted: 00:25 - 12 Apr 2002    Post subject: dt125 non start Reply with quote
keith, many thanks for your kind interest, the engine has been recon lately, all in good nick, i am going to admit defeat and take it to the local dealer, ouch,, a shame you dont live closer. anyway cheers again, all the best.......
PostPosted: 09:55 - 12 Apr 2002    Post subject: Reply with quote
Has it run properly since it was pulled apart? Years ago I spent ages trying to start a bike I had fitted a new piston to. Turned out I had snapped a piston ring when reassembling it. Quite easy to do.
zaknafien
PostPosted: 14:20 - 12 Apr 2002    Post subject: Reply with quote
Keith needs the name under his changed from "Scooby Slapper" to "The Fixer"
02 Firestorm.
McJamweasel
BCF Junkie
PostPosted: 15:49 - 12 Apr 2002    Post subject: Reply with quote
Or Jim.
As in 'l Fix It Laughing
jim
PostPosted: 20:28 - 13 Apr 2002    Post subject: dt125 non start Reply with quote
Yes it has run since rebuild but not for long, approx 30 minutes total, it was rebuilt because it burnt a hole in the piston crown, dont know why, no excess carbon build up or anything, possible faulty ignition timing?
PostPosted: 00:32 - 15 Apr 2002    Post subject: Reply with quote
I would be tempted to pull the top end off the engine to check, but not sure how difficult that is on the DT. Also worth checking the reed valves (old RDs used steel reeds, which could prove expensive if they broke).
I have known 3 bikes have problems with the ignitions. One was the Gilera which basically shorted out the electronic rev counter. The 2nd was the RS, which is an unknown problem (I will find out when I have some known good bits to swap around), and the other was on an MBX125, and that might have been from using the wrong plug (Autolite kart race plug, when very well but fouled up quickly round town). On the first 2 of these I kept on getting a healthy spark, and the bike would run, but the Gilera would die as soon as you gave it any throttle.
Burning a hole in a piston is normally down to pre ignition of some type. Possibly as you say due to carbon build up (which gets hot enough to ignite fuel, plus takes up volume so raises the compression). However this is normally due to ignition timing being out or too high compression. Ignition timing can normally (on a 2 squeak) go out due to a fault in the ignition, or maybe it the rotor manages to more. The rotor is normally keyed to the crank, but the key can shear off allowing the rotor to move on the crank
Ropehead
Guest
PostPosted: 23:00 - 15 Apr 2002    Post subject: Bla Bla Reply with quote
Jim i'v got some TZR. 1989 parts for sale as u probable know most parts are the same
All very tidy and in good working order:-
dtr 3db1 -88-89
tzr 2rk -87-89
- Wiring Loom.
- CDI unit.
- Generator & flywheel.
For a pic go to
https://www.findit.co.uk/motorbikes/parts/265429.htm
Ropehead@lycos.co.uk Wink
jim
PostPosted: 18:25 - 16 Apr 2002    Post subject: dt125 non start Reply with quote
cheers ropehead, but thanks to keiths advice i have now got it running, many thanks for your consideration.
The last post was made 24 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 80.42 Kb
