xj600 pre diversion starting fault
philholt10
PostPosted: 19:42 - 26 Nov 2006    Post subject: xj600 pre diversion starting fault Reply with quote
Please help
My 1992 xj600 has an odd problem it will not start when I press the start button the rev counter rises to about 6000rpm but the engine will not spin all the wiring checks out ok. could it be a blown cdi or have you any other suggestions.
Please help Crying or Very sad
PostPosted: 19:47 - 26 Nov 2006    Post subject: Reply with quote
If it is not cranking over then the first thing to check is the starter relay. This should have a trigger wire (which is triggered by the starter button) and 2 heavy duty wires, one to the starter motor and one to the battery.
Chances are that the trigger wire works by providing an earth when the starter button is pressed.
Ichy
PostPosted: 11:46 - 27 Nov 2006    Post subject: Reply with quote
Just to be clear,
Bikes in neutral and the kill switch is in the run position. Have you tried pulling the clutch in when pressing the starter button? Is the battery fully charged? Turn on the headlight and press the starter, does it go dim or stay the same? Checked all the fuses?
Does the starter relay click when you press the starter button? If your not sure where it is then try looking around the battery area, it should have a fairly thick wires attached with one going to the starter motor.
If its not clicking then you need to get a multimeter to check the continuity of the start button wire feeding into the top of the relay.
Does the starter motor spin? If you check the starter button and it ok but the motor isn't spinning then a quick check is to short out the two thick wires on the relay. Just make sure the bikes not in gear etc and use jump leads if you have them. If is not spinning now then either the battery is knackered, the starter motor isn't earthed properly, starter is seized or the brushes have gone.
If it does spin then either the relay, starter button switch or in some cases, kill switch are knackered.
Paddy Blake
PostPosted: 01:31 - 28 Nov 2006    Post subject: Reply with quote
I hope it is not the starter clutch as it is a big job.Is it a case of the starter
turning but not turning the engine.Or is the the starter not turning.
Paddy.
The last post was made 19 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.52 - MySQL Queries: 14 - Page Size: 40.42 Kb
