rvf400 33hp restrictor?
mike
Guest
PostPosted: 18:42 - 24 Apr 2002    Post subject: rvf400 33hp restrictor? Reply with quote
i want to take out my 33hp restrictors on my rvf400, where abouts are the restricters in the cars are they deep inside or not etc?
mike
Guest
PostPosted: 18:45 - 24 Apr 2002    Post subject: Reply with quote
thats carbs not cars!!
craigT19
Jolly Green Giant
PostPosted: 20:53 - 24 Apr 2002    Post subject: ... Reply with quote
i think there in the carbs but carbs are complicated so best bet is to get a garage to do it:)
Current bike : - 2016 MT-10
Korn
Admin
PostPosted: 21:32 - 24 Apr 2002    Post subject: Reply with quote
It's pretty simply to remove the 33bhp kit from the RVF, but it's a very fiddly job...
  • Remove the two side mid panels
  • Remove the lower fairings and all the assorted rubbers / foam pads
  • Remove the seat, and unbolt the tank
  • Remove the two "air funnels" which lead into the tank
  • Lift the rear of the tank up somewhat, and turn the fuel tap to off
  • Pull off the big hose on the left (overflow)
  • Pull off the small hose on the left (vacum connector)
  • Pull off the small hose on the right (breather)
  • Now you should be free to lift the tank clear
  • Remove the airbox covers, nothing which way around the air tube to the secondary air filter is fitted
  • Pull out the air filter and unscrew the bottom airbox bolts to free it
  • Remove the whole dealie so that you're left with the carb bellmouths
  • Free the idle adjuster and choke cable from the left of the bike
  • This is the really fiddly bit: use a long crewdriver to loosen the clamps holding the carbs to the intake manifolds
  • Remove the fuel hoses from the carbs
  • Tug and pull to free them, they are quite stiff to pull out because of the V shape they're stuck into
  • Now you should be left with the intake manifolds visible, remove the restrictor plates
  • Re-assemble the whole lot
Et'voila! Twice the power... By far the hardest bit is getting access to the clamp screws on the intake rubbers - the rest is easy but drawn out, but good golly miss molly is it worth doing Exclamation Exclamation Exclamation
retrofly
PostPosted: 09:16 - 25 Apr 2002    Post subject: Reply with quote
mike whats a restricted 400 like, eg top speed, acceleration handeling ect. Thanx
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Korn
Admin
PostPosted: 09:28 - 25 Apr 2002    Post subject: Reply with quote
The power is quite good, even when restricted to 33bhp you still have the torque so it's really only the top half of the rev range that isn't as psychotic as it's meant to be. 0 to 60 was around 5 seconds on my bike when it was 33bhp'd.
Speed? Well I had 120mph out of my 33bhp RVF, given a downhill stretch they'll go all the way to the top speed of 145mph.
Handling and braking is unaffected by the restriction so you can still outrun the lardy litre bikes without a problem.
retrofly
PostPosted: 09:32 - 25 Apr 2002    Post subject: Reply with quote
Does that go for all 400's
+ So would i be able to keep up with my mates de-restricted VFR. Could i be able to pull wheelies Razz
Luke
Scooby
Scrappy Doo
PostPosted: 10:07 - 25 Apr 2002    Post subject: Reply with quote
Course you'll be able to pull wheelies!! You can pull wheelies on an NSR!! So it ain't gonna be rocket science n an RVF or similar is it??? Just ask Zimma if his ZXR wheelies..........hehe Very Happy
Zimma
Wheelie Junkie
PostPosted: 10:30 - 25 Apr 2002    Post subject: noooo... Reply with quote
my zxr doesnt wheelie, that would be illegal Exclamation Exclamation Twisted Evil Very Happy
-Zimma
PostPosted: 11:39 - 25 Apr 2002    Post subject: Re: noooo... Reply with quote
Well the illegal bit is 'not being in proper control'... and I allways thought wheelies showed good throttle control Smile
Ropehead
Guest
PostPosted: 12:16 - 25 Apr 2002    Post subject: bla bla Reply with quote
i'm looking at getting a zxr400 a.s.a.p cos it not an import, but i really like the vfr and fzr but i'm put off cos its hard to get parts is this true???
and zimma can u post a pic of your bike!
Ropehead Razz
retrofly
PostPosted: 13:20 - 25 Apr 2002    Post subject: Reply with quote
Zimma is ure bike restricted then?
Luke
Mole
PostPosted: 13:29 - 25 Apr 2002    Post subject: Reply with quote
Hi Guy's
G, Ctyson, Zimma and all
Ive been in contact wiv Dobles and they are saving the VFR400 (NC30)
for me!
It's in Nottingham at the moment aving a NEW! Rossi paint Job !
They rekon about 3 weeks, so will keep U all informed!
Mole
V4's R Us!!!
Mole, the oldest 18year old on the block !
retrofly
PostPosted: 13:36 - 25 Apr 2002    Post subject: Reply with quote
Good 4 u Moley what reg it the bike.
Thats a bit far away innit
Luke
Zimma
Wheelie Junkie
PostPosted: 13:51 - 25 Apr 2002    Post subject: .. Reply with quote
erm... yes occifer its restricted to 33bhp, look heres my certificate to proove it, no mr occifer the restrictors didnt fall out at the same time i put my blueflame can on Laughing
https://www.bikepics.com/pics/kaw-zx4r-02-bikepics-24169.jpg
thats my baby Smile
-Zimma
Korn
Admin
PostPosted: 14:54 - 25 Apr 2002    Post subject: Re: bla bla Reply with quote
Parts for the vfr are pretty plentiful and fairly cheap (mainly because they're 'real world' prices and not the manufacturer's figures). The rvf is a bit more difficult to find bits for but they're still fairly cheap. I scored a mint rear subframe for £60 - beat that Razz
There's a thread a while back discussing the kwak zxr versus the honda vee-fours, you should be able to find it using the search.
Guest
PostPosted: 15:19 - 25 Apr 2002    Post subject: Reply with quote
Luke,
I fink it's "M" Reg, it was on the Dobles website for a while in
it's origional black and red colours, the bike looked good but
the colour put me off! I thought the red wheels wus over the top.
They say it's a minter wiv 10,000kms on the clock, so will have
to have a good look when it's done. The good fing about buying
from a Honda main dealer is the Warantee!
Good Luck
Mole
Scooby
Scrappy Doo
PostPosted: 21:41 - 25 Apr 2002    Post subject: Reply with quote
hehe Zimma I love your bike I want one now!!
What year is it??? I am guessing here at about '92???
Scooby
Scrappy Doo
PostPosted: 21:42 - 25 Apr 2002    Post subject: Reply with quote
No actually, it gotta be newer than that. Having a closer look I would say '97ish??? God knows why I said '92...
PostPosted: 21:58 - 25 Apr 2002    Post subject: Reply with quote
If I remember he got it new pretty recently, they haven't changed the design much in a while.
There's not *that* much you can do to make 400s faster/lighter weight with out making significant compromises so they haven't changed/made new designs recently. (And the jap power laws were relaxed)
mike
Guest
PostPosted: 09:42 - 26 Apr 2002    Post subject: thanx Reply with quote
thanx for the info kornel,ive got a workshop manual so i will read that before going in head first so i dont knacker something in the carbs.
Zimma
Wheelie Junkie
PostPosted: 10:19 - 26 Apr 2002    Post subject: 92 ya biatch!! :o) Reply with quote
feckin 92 grumble groan feckin shit bollox! Laughing
nah its an ZX400L9 according to kwaks website, which means its a 99 model, altho i bought it in 2002. basically they havent changed the design of the bike since 99, so technically i coulda got a second hand 99-2002 model and had the same bike, but u no... i like debt, so i got a brand new one 8)
G, u can make em faster... 444cc Wink Very Happy
-Zimma
PostPosted: 12:40 - 26 Apr 2002    Post subject: Re: 92 ya biatch!! :o) Reply with quote
Zimma wrote:
G, u can make em faster... 444cc :wink: :D
Yeh, but I did say 'to make 400s faster/lighter weight'... though admittadley Kawazaki has completley abandoned this kinda thinking in the 600s.
When are you getting it done btw?
The last post was made 23 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.86 - MySQL Queries: 13 - Page Size: 113.95 Kb
