| Strapstah |
 Strapstah Nova Slayer
 Posted: 15:10 - 19 Dec 2006 Post subject: My Aprilia Mx50 prooblem |
| finpos |
 finpos World Chat Champion
 Posted: 15:34 - 19 Dec 2006 Post subject: |
I just ripped one of those of my mates bike, stomped on it and threw it in the bin. hope you don't want to see where you are going in the dark.
Apart from that, and the fact that roger the bodger has already been at your bike, it should be pretty easy.
You'll have to make or buy enough brackets to actually physically mount the thing. the one I took off was mounted to two standard brackets clamped onto the forks.
Connect all the green wires together, and connect them to an earth on your bike. That would be the same place the two green wires on your existing setup go. use a proper crimp tool. alternately, twist the wires together and cover the joint in non-waterproof insulating tape.
Then all you have to do is track down the hi and lo beam wires (connected to that bell wire, i suspect) and connect those to the white and blue wires on the new thing. don't worry about which way around because it makes f**k all difference to the actual light output
Repeat for the two indicator feeds (red on the new thing, can't see on the old thing).
finpos. |
| Strapstah |
| finpos |
 Posted: 15:41 - 19 Dec 2006 Post subject: |
The bloke with the bell wire and the insulating tape
finpos. |
| Strapstah |
| Marci |
 Marci Brolly Dolly
 Posted: 16:19 - 19 Dec 2006 Post subject: |
Bullet Connectors, Spade Connectors, or solder & heatshrink.
All available from Maplins, Halfords, and any decent automotive store. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
The last post was made 19 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
