| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| bazza |
 bazza World Chat Champion
 Posted: 15:24 - 06 Jan 2007 Post subject: |
It's a long shot, but it might just work...
https://www.physorg.com/newman/gfx/news/logo-Google.gif
 ____________________ "That's it. You people have stood in my way long enough. I'm going to clown college."
'98 Ducati 750SS, '08 Suzuki GSX650F ©2004-2014, Bazza's Harmless Banter |
| gavin |
 gavin World Chat Champion
 Posted: 15:26 - 06 Jan 2007 Post subject: |
gears multiply torque. the lower the gearing, the more torque, or rather thrust, you will have at the rear wheel. accereration will be higher, top speed will be lower ( though this isnt always the case - see below)
overall gear reduction is three parts:
primary reduction ( crank shaft to gearbox) is usually quoted as driven (gearbox) over drive (crank) this might be 68/19 or 3.587
gear ratios are usually quotes as driven gear over drive gear, first might be 39/12 or 3.250, sixth might be 24/26 or 0.923 etc
final drive ( chain and sprockets) is also quoted as driven over drive, this might be 48/14 or 3.428
you can usually only alter the final drive, smaller at the front and/or bigger at the back lowers gearing, and vice verca.
this is one of my bikes on standard gearing
https://homepage.ntlworld.com/gavin.prior/dynabike/lomas/through%20gears.jpg
and this is it on lower gearing
https://homepage.ntlworld.com/gavin.prior/dynabike/lomas-opt/through%20gears.jpg
note that in this case the top two gears are redundant on standard gearing ( brown line is as fast as it can go due to drag) but lowering the gearing increases the thrust in 5th and 6th and allows it to pull slightly higher top speed, as well as accelerate better through the gears. ____________________ 1988 TZR125 : 1990 RD350YPVS/ RGV250 HYBRID : 1982 RD80LC : 1983 RD80LC : 1994 RGV250 : 1991 TZR125 / CR500R HYBRID : 1976 BENELLI 500 QUATTRO : 2006 TRIUMPH 675 |
| 5v3d3b0 |
| gavin |
The last post was made 19 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
