Aprilia SR 125 (Scooter, I know)
Stainmaster
PostPosted: 12:16 - 08 Jan 2007    Post subject: Aprilia SR 125 (Scooter, I know) Reply with quote
Hello all, I bought this (bad boy) to fix up I've fitted an exhaust at the manifold as the pipe was bad and the gasket away. I replaced the gasket. The scooter only passed MOT in November, I can't understand how, but is quite rough as its been dropped a few times by the look of it.
My problem is the mixture going into the engine is almost only 2-smoke oil. As the engine will run at idle speed up to about 1/4 throttle but when i rev it it smokes like a 30's Hollywood heroine and then cuts out. I remove the plug and it is thick in oil. I have a set of manuals, thanks to this site, they are just the owners manual and don't show how to adjust the mixture. I understand this is done electronically somehow but don't know how to change the settings and make the mixture a bit more lean.
I would be very grateful if someone could help me out here, either tell me how its done, or perhaps point me in the direction of some procedures in the way of manuals with pictures.
Stainmaster
PostPosted: 23:19 - 10 Jan 2007    Post subject: Reply with quote
Laughing does no one know? I am having real difficulty here. Please help.
J.K.R
PostPosted: 02:09 - 11 Jan 2007    Post subject: Reply with quote
Right i think you should look at the auto choke first (Big black bit on the carb with wires coming off it) Remove it and turn the ignition on, It should move. If it doesnt, replace it.
I've got a few standard carbs laying about and one has the mixture screw, The others a sort of triangle shaped bit (i assume it'll use a special tool for it) I really doubt the mixture will be managed by the electronics, Maybe if it was a ditech 50! Laughing
The only other thing i can really think of it the oil cable adjuster. Look on the left hand side of the engine and there'll be a plastic cover on it saying aprilia, Remove this (by taking off the airbox cover) You'll now be left with the metal transmission cover.
At the front of this will be a rubber circle, Push it in a bit to dislodge it then pull it out... Peep through the hole and youll be looking at the oil pump. It will probably need a clean, You'll then see a mark on the moving part (twist the throttle, You'll see what im on about) and there will be a mark on the oil pump housing, these should line up.
If they dont, You'll see the cable going into the casing on the left, Undo the nut and turn the adjuster until the marks are sitting inline (remember and do that while the throttles shut!)
Obviously refit all the bits and bobs, You might want to replace the air filter while your there.
Anything else PM me or something! Thumbs Up
www.oldskoolsuzuki.info
Stainmaster
PostPosted: 12:13 - 11 Jan 2007    Post subject: Reply with quote
Thank you very helpful, I will not be able to do this until next week but that is very good and clear instructions. I shall pm if i get stuck.
Stainmaster
PostPosted: 14:10 - 26 Jan 2007    Post subject: Reply with quote
Hey J.K.R thanks for the help it was the cable for the oil pump it was to tight slackened it off a bit and its running fine now, thanks for all the help
The last post was made 19 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.34 - MySQL Queries: 14 - Page Size: 43.21 Kb
