| MarJay |
 MarJay But it's British!
 Posted: 14:15 - 27 Jan 2007 Post subject: KE100 starts, but can't get the front fork apart! |
Hi Gentlemen,
I've managed to get the KE100 to start, I simply replaced the spark plug and all is good.
I still have no battery connected however.
My main concern has now moved to the fork legs however. I have been trying for a couple of days to part the stanchion from the fork leg lower. According to the Haynes manual, once the spring, top cap and oil are removed, you should just be able to pull the stanchion out from the lower. However, I have been frustrated so far.
G tried to pull the stanchion out too, and we even tried pulling it like a huge cracker. There is no bolt on the bottom of the leg, it just has the spindle hole welded on, as a piece of tube. There are no ways for it to come apart, as the end cap is also welded on.
So, I can surmise then that the Haynes manual is correct, and the damping consists of the spring floating in oil, but I can't get the stanchion out!
I need to change the fork seal as they are leaking heavily. I have also tried drilling a hole in the seal and pulling at it with a screwdriver and other tools. No luck.
Any thoughts on this?  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| finpos |
 finpos World Chat Champion
| MarJay |
 Posted: 14:57 - 27 Jan 2007 Post subject: |
| finpos wrote: | Have you looked down the now empty stanction to see if there is a bolt or something down there in the gloom?
finpos. |
Indeed I have. And there is a smooth bit of metal which looks like a crosshead screw. However the edges are smooth so I seriously doubt that any tool would get a purchase on it.
I have to say that the flash on my phone was very useful for looking at that.
In the Haynes manual it just shows an end cap, o ring, stanchion, bush, spring, and lower, not including the fork seal, the fork seal washer and the circlip.
There is no damper or damper rod, and the manual explains that you need to use the 'slide hammer action' of the stanchion against the fork seal to remove it. However I've had the leg in a vice and pulled as hard as I could and the damn thing wouldn't come apart, so I'll entertain any suggestions at this point! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Timmeh |
 Timmeh World Chat Champion
 Posted: 17:41 - 27 Jan 2007 Post subject: |
Bit of an aside, but it wouldn't be the first time a Haynes manual isn't quite correct. According to my manual, my '95 CBR should have one type of front fork; but it hasn't. I spoke to the people who work at Chiswick Honda and they say that type of suspension was only added to the '97 models and onwards.
Take what you say with a pinch of salt, and in my experience you should always back up your Haynes with a proper service manual for your exact make and model.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| MarJay |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 22:30 - 27 Jan 2007 Post subject: |
| Vin |
 Vin World Chat Champion
 Posted: 09:33 - 28 Jan 2007 Post subject: |
So when in use what holds the fork lower in place.
Am I being thick? Can anyone enlighten me? |
| Finglonga |
 Finglonga World Chat Champion
| G |
 G The Voice of Reason
| MarJay |
The last post was made 19 years, 117 days ago. Instead of replying here, would creating a new thread be more useful? |
