Does petrol dissolve araldite?
Arfdog
PostPosted: 10:46 - 18 Feb 2007    Post subject: Does petrol dissolve araldite? Reply with quote
Or can I use a blob of araldite to fix my bloat on my fuel gauge mechanism?
I'm a lover, not a fighter.
finpos
PostPosted: 11:01 - 18 Feb 2007    Post subject: Reply with quote
I think you're ok as long as you steer away from any of the quick-setting domestic stuff. i.e. use the more butch engineering chemical metal types.
finpos.
PostPosted: 11:24 - 18 Feb 2007    Post subject: Reply with quote
What he said. Araldite is an epoxy resin and so is pretty much anything proof. Chemical metal would be better though. JB-weld is the best but others work well too. Araldite do their own version which is much nicer to work with than the adhesive and pretty strong (you can even drill and tap it), not as heat resistant as JB weld though.
The sediment bowl on my CB125 fuel tap consisted of around 50% araldite chemical metal (because the bottom screwed off it rather then the bowl itself unscrewing from the tap). Lasted over 2 years and never leaked, I eventually found one at the breakers and replaced it.
jimbothe
PostPosted: 11:29 - 18 Feb 2007    Post subject: Reply with quote
Im with stinkwheel.Chemical metal is far superior and roughly the same price.I havent found anything it doesnt work on yet Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Pete.
PostPosted: 13:50 - 18 Feb 2007    Post subject: Reply with quote
JB Weld is 100% fuel-proof once cured. It says so on their website.
Araldite does get affected by petroleum-based products afaik. Methanol affects it for sure.
a.k.a 'Geri'
bish777
PostPosted: 18:34 - 18 Feb 2007    Post subject: Reply with quote
the old 34mm carbs on my suzi were largely held together with chemical metal, till i replaced them with newer carbs.
GSXR1100J
beatnck
PostPosted: 19:30 - 18 Feb 2007    Post subject: Reply with quote
Another vote for chemical metal here Thumbs Up
owdamer
PostPosted: 21:11 - 18 Feb 2007    Post subject: Reply with quote
I used araldite to glue the datatag chip inside my fuel tank 12 years ago. Its still there now.
The last post was made 19 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 54.55 Kb
