Gaskets
Hunter
PostPosted: 17:46 - 10 Jul 2002    Post subject: Gaskets Reply with quote
Hey Guys!
I have got access to some aftermarket gaskets for the NSR RK, I don't have access to genuine Honda stuff from Sri Lanka! Mad
So any ideas on how I could check if these are good quality, I mean is there anything i should look out for in good gaskets?
Cheers for the help! Smile
PostPosted: 18:02 - 10 Jul 2002    Post subject: Reply with quote
Who made then?
TO be honest, on a bike I have never had problems with non OE gaskets. Used them all the time on the MBX
Hunter
PostPosted: 16:26 - 11 Jul 2002    Post subject: Reply with quote
cheers keith!
I am restoring my RK piece by piece.. just gave the fairings in for a paint job, should get them back next week!! I wish I could paint them myself.. have done it before, but I want the colours matched perfectly Cool
I just gave my seat to a fibre specialist and gave a design for a single seat conversion! Should be interesting!!
I'm getting HRC, NGK & Ohlins stickers done for about 4 quid each!! Bargain? Anybody need stickers? Smile
I'm wondering if I should replace the piston and rings (I have a taiwanese set), the bike has done 10000 miles, is it normal to get them changed so soon?
Have to change fork seals too!
PostPosted: 18:02 - 11 Jul 2002    Post subject: Reply with quote
Check the condition of the rings (and check the ring end gap), but they may well be OK at that mileage. I am a bit dubious about using non OE pistons, mainly because on the MBX it was an achievement to get non Honda pistons to last long enough to be run in!
Hunter
PostPosted: 17:48 - 12 Jul 2002    Post subject: Reply with quote
Thanks Keith!
Also, any possiblity of using new rings with the old piston?
If I do replace piston with rings - do I have to run-in for a few 100 KMs? What are your recommendations?
If I do replace rings only- do I have to run-in the engine at all?
Cheers for the response mate!
Smile
Scooby
Scrappy Doo
PostPosted: 19:39 - 12 Jul 2002    Post subject: Reply with quote
You better replace the piston when you put new rings on!! Some cunt obviously siezed my bike before I had it, had either a new or replated the barrel, new rings, but kept the same crummy piston, and now it's ballsed!! So change the bastard Evil or Very Mad
PostPosted: 10:16 - 14 Jul 2002    Post subject: Reply with quote
If the piston is in OK condition then just replace the rings (check the gap in the piston that the rings sit in). If the piston is worn out or showing signs of having been seized then repace it . Be very dubious about mixing pattern rings with the original piston.
In either case run the bike in. I tend to work on 500km at half the red line max, and then up that by 1000rpm for every 100km, aiming to be thrashing the knackers off it at 1000km. That may be a bit excessive though
Demonic69
The Pink Rhino
PostPosted: 10:22 - 15 Jul 2002    Post subject: Reply with quote
Hunter, I'm in Dire need of stickers. Just need 2 big NSR, 2 Honda's, 2 Honda "Wings" and maybe 2 "supersport" or something. I keep trying ppl but had no real luck so far. Not looking at a full racing set or anything, just a few to ID the bike after I painted it
McJamweasel
BCF Junkie
PostPosted: 10:24 - 15 Jul 2002    Post subject: Reply with quote
www.morgandesigns.com for yer stickers. theyll do you just about anything.
Hunter
PostPosted: 17:48 - 15 Jul 2002    Post subject: Reply with quote
Hey Demonic.. do you have the RK?
cause if you do.. i can get the same set that I am getting.. how am I going to get it across to you though mate.. I'm in Sri Lanka..!! Laughing
The last post was made 22 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 62.83 Kb
