sliding brake lever inside question
kawashima
PostPosted: 18:54 - 09 Apr 2007    Post subject: sliding brake lever inside question Reply with quote
After this question, I'm fond of covering lever with first 2 fingers. Now the problem is braking power. My bike is kwak W650 and it weighs 194kg but only single disk in front. I attached GPZ1100 pad / metal hose and still the braking power is not enough with only first 2 fingers.(I know it has enough power with 4 fingers but I don't like it) I want to increase brake power with 2 fingers, and I'm thinking of sliding brake lever unit a little bit inside so that I can pull the outer part of the lever with 2 fingers.
Do you think this custom is ok?
https://i21.photobucket.com/albums/b295/kawashima_/brakelever1.jpg https://i21.photobucket.com/albums/b295/kawashima_/brakelever2.jpg
own:2020 Serow 250
PostPosted: 19:01 - 09 Apr 2007    Post subject: Re: sliding brake lever inside question Reply with quote
That should be fine. Give it a go and see how it feels.
Make sure that it won't catch on anything when you are at full lock (bars turned to the left).
kawashima
PostPosted: 19:08 - 09 Apr 2007    Post subject: Re: sliding brake lever inside question Reply with quote
I'll be careful not to catch on anything at full lock, and try it. Thanks!
kawashima
PostPosted: 16:43 - 14 Apr 2007    Post subject: Reply with quote
I slided brake unit about 2cm inside(left). This improved braking power so much!!!! Very Happy Very Happy Very Happy
Very simple but Vvery effective. I should have tried this much more earlier thanks!!!
The last post was made 19 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.48 - MySQL Queries: 16 - Page Size: 40.7 Kb
