hard drive wont work?
dransy
PostPosted: 11:35 - 30 Apr 2007    Post subject: hard drive wont work? Reply with quote
Right ladies and gentlemen . i took everything outta my comp to clean it and sort it out.
Put it all back together and now one of my hd's wont work... it has power going to it , its set as slave , and ide cabels are plugged in but its not getting detected or anything..
Any ideas?
techierob
PostPosted: 12:07 - 30 Apr 2007    Post subject: Reply with quote
are there any other devices on the same chain? If so, are they jumpered correctly?
Is the cable plugged in the wrong way round at one end? Are all the connections bedded in properly? Are there any bent pins on the IDE slot on either the drive or motherboard?
daz|n00by
The Internet
PostPosted: 12:09 - 30 Apr 2007    Post subject: Reply with quote
Is it detected in the bios?
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
dransy
PostPosted: 13:05 - 30 Apr 2007    Post subject: Reply with quote
No its not detected in the bios , and as far as im away there ar no bent pins.
Could it be my ide cabel thats screwed? cos its twisted like crap and it is fairly old now ?
daz|n00by
The Internet
PostPosted: 13:35 - 30 Apr 2007    Post subject: Reply with quote
ok do the obvious first... check the power to the hdd.. change the ide lead... make sure its set to master or slave (which ever you need it as) make sure its plugged into the mo board correctly.
Go in to the bios and set it to auto detect and see if it shows.
GodzGift
PostPosted: 13:58 - 30 Apr 2007    Post subject: Reply with quote
probably knackered
dransy
PostPosted: 15:04 - 30 Apr 2007    Post subject: Reply with quote
cheers for that , turns out i had 2 bent pins on my mother board Thumbs Up
The last post was made 19 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.31 - MySQL Queries: 14 - Page Size: 51.54 Kb
