HELP HELP READ THIS PLZ I KNOW TO KNOW THIS!!!!!
bikerboy1
PostPosted: 12:28 - 24 Jul 2002    Post subject: HELP HELP READ THIS PLZ I KNOW TO KNOW THIS!!!!! Reply with quote
i don't know if it's the way they do it but when i am in 1st gear and
i stop and try and click it into N it don't move (the lever) but when
i roll the bike forward it clicks on to N!! is this right because
when i first got the bike it was ok stopping and clicking it on to N
but now i have to click into N before i stop or i need to roll it, as
long as it's moving it with click up to N!!!
whats wrong?????
or is this ok??
Demonic69
The Pink Rhino
PostPosted: 12:33 - 24 Jul 2002    Post subject: Reply with quote
Have you checked the transmission oil?
Guest
PostPosted: 12:50 - 24 Jul 2002    Post subject: Reply with quote
no i will then
andrew
Mister Road Rage
PostPosted: 12:51 - 24 Jul 2002    Post subject: Reply with quote
like he said check the gear box oil
you " KNOW TO KNOW THIS!!!!!" ???
Guest
PostPosted: 12:58 - 24 Jul 2002    Post subject: Reply with quote
i did but i just wanted some esle's to see they think
bikerboy1
PostPosted: 12:59 - 24 Jul 2002    Post subject: Reply with quote
that was me sorry didn't sign in
craigT19
Jolly Green Giant
PostPosted: 13:32 - 24 Jul 2002    Post subject: .... Reply with quote
is sit newish??? i had trouble with getting my nsr to go in to nuetral for aaagggeeessss but after a wile it was finr i just assumed the gearbox was all tight due to it being new??
Current bike : - 2016 MT-10
bikerboy1
PostPosted: 14:12 - 24 Jul 2002    Post subject: Reply with quote
no the bike has done about 10,000 miles and it was ok at the start now it is doing this
craigT19
Jolly Green Giant
PostPosted: 14:14 - 24 Jul 2002    Post subject: .... Reply with quote
how ofter u changed the tranny oil????? if you had very dirty oil in it for a long time you may off worn the gear sector or something??
best thing to do, get it in for a survice and ask um to have a look for ya
bikerboy1
PostPosted: 14:18 - 24 Jul 2002    Post subject: Reply with quote
k cheers mate
TJ NSR
PostPosted: 19:21 - 24 Jul 2002    Post subject: Reply with quote
transmission oil needs changing mate, its pretty easy on the rs if u need help ASK!
tj
curryhead
PostPosted: 23:35 - 24 Jul 2002    Post subject: Reply with quote
i may be wrong but i think its a safety feature the back wheel must be spinning round to force some bearings outward or something to enable you to change gear. my bike used to do that. or you could try letting the clutch out to the biting point then it should clunk. every one else seems to think its your oil so dont quote me on what ive just said
take it easy, watch out for blind car drivers!
bikerboy1
PostPosted: 00:04 - 25 Jul 2002    Post subject: Reply with quote
i will try what curryhead said if it don't work i will change the trans oil!!!
TJ you coming BH this sunday??? if so you could help with it
craigT19
Jolly Green Giant
PostPosted: 12:47 - 25 Jul 2002    Post subject: Reply with quote
i thought only zimma bogded i mean surviced his bike at bh lol
M1ke
Ped Boi
PostPosted: 14:56 - 25 Jul 2002    Post subject: Reply with quote
Could someone explain how you change the gear oil on an RS 1999 please? I think mines about due and i cant find ANY F.A.Q's on the net for it.
When i bought the bike i was breefly told which bits i should be undoing but i was too busy dreaming of the top speed Embarassed
Thanks for any help Smile
M1ke
Ped Boi
PostPosted: 14:57 - 25 Jul 2002    Post subject: Reply with quote
Also with my bike came a bottle of silkolene gear oil, is this ok to use? I have heard bad things about silkolene and RS125's or is that just the engine oil thats bad
Joe Camel
PostPosted: 16:49 - 25 Jul 2002    Post subject: Reply with quote
its oil mate.
however, I once used fully synthetic and it killed my clutch, semi skimmed is cool
***THE VOICES MADE ME DO IT***
***NOT STOCK & TWO SMOKIN BARRELS***
PostPosted: 20:22 - 25 Jul 2002    Post subject: Reply with quote
Take off the fairing lowers. Take out the oil filler cap (on top of the engine near the carb). Undo the level plug (on the clutch outer casing). Undo the drain bolt (under the gearbox, pointing to one side), with something under the engine to catch the oil.
Let the oil drain out (will take a while). Put the drain plug back in place. Fill the gearbox up, until the oil comes out of the oil level plug (with the bike upright, not on the stand). Keep the bike upright until the oil stops dripping out, put the level plug back in and the filler plug back on.
Put the fairing back on and go for a ride
All thebest
Dylan
PostPosted: 20:25 - 25 Jul 2002    Post subject: Reply with quote
NSR's dont have a level plug do they??? I filled mine up to when its just above the window. Is that OK????
Thanks
Dyl
PostPosted: 20:47 - 25 Jul 2002    Post subject: Reply with quote
The NSR has a little window to look at the level. It should be filled up to the upper part of the window
Dylan
PostPosted: 20:50 - 25 Jul 2002    Post subject: Reply with quote
Better let a bit out then !!!
Thanks
Dylan
Demonic69
The Pink Rhino
PostPosted: 09:25 - 26 Jul 2002    Post subject: Reply with quote
Mine's got a level valve:) But it's a 1990 so it's tha daddy:)
curryhead
PostPosted: 00:30 - 28 Jul 2002    Post subject: Reply with quote
make sure you dont over tighten the drain plug coz if you snap the bolt inside the crank case i hear it can be quite a bitch! Embarassed Embarassed Embarassed
M1ke
Ped Boi
PostPosted: 14:54 - 01 Aug 2002    Post subject: Reply with quote
Thanks for that keith but i have a few problems Embarassed
I cant find where the oil filler cap, level plug, or the drain bolt... Im sure im looking straight at them but i dont know what they look like!
Does anyone have a nice labled piccy Confused
I can see like two bolt looking things that look like they need to be turned with a coin, one is higher than the other are these something to do with it all?
PostPosted: 19:47 - 01 Aug 2002    Post subject: Reply with quote
Those 2 plugs are undone with either a coin or a large screw driver. The one in the middle is there so you can access the clutch adjuster, the one towards the edge so you can check you have adjusted the clutch correctly
A bit further down on the same casing you should see a solitary allen key bolt (on the earlier ones it had something like "oil level" cast into the metal beside it). This is the oil level hole. With the bike verticle you fill the oil up until it comes out of this hole.
The drain plug should be visable from the other side of the engine (on the Rotax 123 engine, presume the 122 is the same). The is a large bolt, close to the centre line of the engine.
All thebest
The last post was made 23 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.32 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 118.83 Kb
