GOD DAMN-THEY SCREWED UP!!!!!-help
moonym20
PostPosted: 15:18 - 25 Jul 2002    Post subject: GOD DAMN-THEY SCREWED UP!!!!!-help Reply with quote
Heya all i NEED some advice quick!
took my NSR in for its first service (500 miles) got it back and after bike was doin over 40mph and i pulled the clutch in i notice a low groan/wine comming from rear tire.... when i let the bike decelerate (with/without) brakes at around 20 the noise gets a little louder and i can feel rough vibration through the footpeg....got home n noticed a piece of wire wedged into the sproket fittings (where its bolted to rear wheel) and pulled it free.....took bike 4 a spin n its still doin it.....it aint the chain i know that.the mechanic recons it's the 'clutch freewheeling' or it may be the engine but i sure as hell don't belive it.... fellas i need help Sad Sad Sad
cherz!
Joe
Ropehead
PostPosted: 16:21 - 25 Jul 2002    Post subject: Reply with quote
have u checked stuff like the wheel alingment, try jacking it up and spin the wheel see if u can locate it that way,
urm i'll have a think Smile
moonym20
PostPosted: 21:59 - 25 Jul 2002    Post subject: Reply with quote
yup looked at that....wheel spinds freely....chain tension is spot on.....not kinked areas.........its just as i hit 40 it becomes aparent and when i pull in the clutch (the engine noise fades) and you can hear it clearly then......when decelerating towards 20 it is quite loud and feels like somthing is rubbing or grinding........
y'know the sound that cars with big tires or landrovers make from time to time when there doing around 30? it kinda sounds like that.........but it just started when i got the bike back from its service.........i did notice that the mechanic tightned the rear axel nut with a normal wrench n not a torque wrench
cherz 4 ur reply
PostPosted: 22:44 - 25 Jul 2002    Post subject: Reply with quote
I virtually never use a torque wrench on the wheel spindle bolts. The main things I would think of would be a shot chain (and you have already checked that), or a knackered wheel bearing. Check for play. I have a set once go from no play to totally collapsed with the balls falling out in 15 miles. After that check the brakes are fine. Also, depending on whether it is a noise or a feeling, check the steering head bearings. If these are overtightened (esepcially it they are worn) they can cause an odd wobble, but I would not expect you to heat any noise from them
All thebest
Demonic69
The Pink Rhino
PostPosted: 09:27 - 26 Jul 2002    Post subject: Reply with quote
Keith, you pissed? Your english is normally really good but now you're all over the place Wink
zaknafien
PostPosted: 11:04 - 26 Jul 2002    Post subject: Reply with quote
i wonder what the missus was doing at that time............................
02 Firestorm.
PostPosted: 23:07 - 26 Jul 2002    Post subject: Reply with quote
Mmm, my English is c*&p, but then I am a computer programmer for a living. Get it wrong and the compiler tells me about it
About 50 miles away!
All thebest
zaknafien
PostPosted: 01:05 - 27 Jul 2002    Post subject: Reply with quote
when the cats away the mice will play eh?? *nudge* *nudge* *wink* *wink*
Very Happy Very Happy Very Happy Twisted Evil Twisted Evil Twisted Evil Very Happy Very Happy Very Happy
02 Firestorm.
moonym20
PostPosted: 22:36 - 03 Aug 2002    Post subject: Reply with quote
thanks for the feedback every1 (esp. keith) i've checked the chain and its moving freely and there is 32mm slack in the center...the rear wheel has no play.the sound is comming from the rear and i feel the vibration through the pegs.im pretty sure that it isn't the front end or steering and the mechanic is sure its nothing although it begun after i picked it up...im totally out of ideas Shocked
thanks again
PostPosted: 08:20 - 04 Aug 2002    Post subject: Reply with quote
Check the chain for any tight spots or links that are sticking. If that still comes up with nothing then take off the fairing around the front sprocket, take off the front sprocket cover and check that the sprocket is secure
The last post was made 23 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 65.78 Kb
