DERESTRICTIN AGAIN
WULL
Guest
PostPosted: 13:43 - 26 Jul 2002    Post subject: DERESTRICTIN AGAIN Reply with quote
WHEN I TOOK OFF MY CARB INLET PIPE THERE WAS NO GOLD PLATE JUST A PLASTIC INSERT WITH REEDS ON IT DOES THIS GO BACK IN ,I SEE ON THE VIEW IN THE GUIDE IT DOESNT APPEAR TO BE REFITTED OR MENTIONED,ALSO CAN YOU SUGGEST A SUPPLIER FOR BIG BORE HEADS? Confused
Demonic69
The Pink Rhino
PostPosted: 13:58 - 26 Jul 2002    Post subject: Reply with quote
I'd recommend posting this in the general section. You'll get more help
Back on a Blade. Just feels so right.
Guest
PostPosted: 16:06 - 27 Jul 2002    Post subject: Reply with quote
Hey Demonic69
This is the General section
zaknafien
PostPosted: 16:33 - 27 Jul 2002    Post subject: Reply with quote
for smart arse above ^
it wasent originally posted in the general section.
it's been moved by kornel.
02 Firestorm.
Hunter
PostPosted: 19:58 - 27 Jul 2002    Post subject: Reply with quote
With a 92 NSR you should not have any restrictions in place.
What is the top speed of the bike? is the 6th gear effective i.e. can you continue to accelerate on the 6th?
The reed block (the piece of plastic with the reeds stuck on) must be replaced as it is necessary for the normal function of 2-stroke bikes!
Check the carb to see if the throttle slide has any restriction.. i.e. does the throttle valve open up completely when the accelerator is fully twisted?
Also check the exhaust flange (the bit that sticks on to the engine), and see if there is a 'ring' inserted (welded) on to make the hole smaller than it could be.
Thats about it. Smile
Demonic69
The Pink Rhino
PostPosted: 09:08 - 29 Jul 2002    Post subject: Reply with quote
Cheers Zak mate:)
Guest
PostPosted: 17:27 - 29 Jul 2002    Post subject: Reply with quote
Smart arse no . I do apologise demonic69
Typhoon XR70
PostPosted: 19:15 - 29 Jul 2002    Post subject: Reply with quote
PM Tuning do big bore kits. Visit www.pmtuning.co.uk and send them an E-Mail Smile
Demonic69
The Pink Rhino
PostPosted: 08:51 - 30 Jul 2002    Post subject: Reply with quote
NP:)
themaku
PostPosted: 09:18 - 30 Jul 2002    Post subject: heh Reply with quote
well ive got the same bike as you do(91nsr) and i hardly ever use 6-th speed because it has no strenght.. and it doesnt accelerate.. maybe because i should replace my front sprocket(right now it is 13, i should put 14 i think).. and i was wondering why was that o-ring between the cilinder and exhaust pipe.. well ill take it off.. well wee what happens!
keep up the good work!
greetings, maku!
Hunter
PostPosted: 20:04 - 30 Jul 2002    Post subject: Reply with quote
Yeah mine is 13 on the front sprocket too. The problem is putting 14 will make it accelerate slower, but give a better top-speed!! My 6th gear seems full power cause I've hit 90mph and still had more juice (i think i can hit about 100+mph). Check you rear sprockets too, these are equally important!
the o-ring is not in-between the exaust and cylinder, but welded onto the opening of the exhaust pipe (cylinder head end).
Good luck!!
Cool
themaku
PostPosted: 22:01 - 31 Jul 2002    Post subject: exhaust Reply with quote
i openen my silencer(nsr) and there was no muffler(dont know how its called in english). i thought it must be on every 2 stroke engine silencers, at least in motocross, i dont see any difference. and i noticed that one place where the silencer was weld is broken. should i buy a new one now or just repair it and put muffler in it?
greetings, maku!
Hunter
PostPosted: 18:12 - 01 Aug 2002    Post subject: Reply with quote
maybe you got a pair of race pipes on! Anyhow the weld being broken does not sound too good. I would suggest getting it shown to a professional!
Cool
The last post was made 23 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 69.79 Kb
