zxr4 sum help plz
tanner18
PostPosted: 15:24 - 07 Aug 2002    Post subject: zxr4 sum help plz Reply with quote
how zxr400
its restricted for the time being i was wondering what the best way to accelerate fast is either go to 8-10 grand on the rev counter or change gear at lower revs what is your advice
should i be changing at lower revs
HHHEEELLLPPP
inline 4's rule
McJamweasel
BCF Junkie
PostPosted: 15:26 - 07 Aug 2002    Post subject: Reply with quote
Take it up to the redline in each gear, your power will be up at the top of the scale.
tanner18
PostPosted: 15:33 - 07 Aug 2002    Post subject: Reply with quote
it seems to pull more low down it is restricted remember still loads faster than me nsr 110 sat up no problemsive not even tried to tuck in yet ive only had it a day i think it will do 115 tucked in
inline 4's rule
Zimma
Wheelie Junkie
PostPosted: 16:00 - 07 Aug 2002    Post subject: ... Reply with quote
my advice is to rip the restrictors out Smile
not exactly a hard job to do, and makes the bike 10 times better Smile
(or just buy a firestorm Wink Laughing )
-Zimma
PostPosted: 17:30 - 07 Aug 2002    Post subject: Re: ... Reply with quote
I'm not sure about resticted bikes... but on my zx6 I find the fastest way to accelerate is to hold the clutch half way in untill you're pretty much in the powerband.... also usually it's best to change up around 1000rpm before the redline as the power starts to trail off near it.
This can get the maximum power down without lifting the front, with a bit of practice.
Only use this regularly if you *really* don't mind regularly getting new clutchs!
WildGoose
White Van Man
PostPosted: 17:54 - 07 Aug 2002    Post subject: Reply with quote
if you get pulled with no restrictor in a bike that you are sposed to have restricted you are in trouble
Scooby
Scrappy Doo
PostPosted: 18:14 - 07 Aug 2002    Post subject: Reply with quote
There's no way they can check at the side of the road... they can give you a date to take it to a test centre for a run on the dyno... which gives you time to put the restrictor's back in, like Zim said, it ain't rocket science to put 'em back in.
Ropehead
PostPosted: 18:20 - 07 Aug 2002    Post subject: Reply with quote
Its if you CRASH and kill some one, they toe your bike away for inspection then ya Fooked.....insurance is void 2
Scooby
Scrappy Doo
PostPosted: 18:22 - 07 Aug 2002    Post subject: Reply with quote
If you kill someone you're normally fucked neway, and if speed was not an issue they shouldn't have any reason to check for restrictors, do bear in mind that a restricted bike will still do 110mph+, so it isn't as if you can't lose your licence on a restricted bike.
Phoenix
Twisted Firestarter
PostPosted: 21:32 - 07 Aug 2002    Post subject: Reply with quote
Just because you weren't speeding when u crashed, it doesn't automatically mean your bike won't be examined for restrictors, you're a youth on a sports bike and it will most likely be checked.
Redlining the bike in every gear is most certainly not the best way to get top acceleration as the most power isn't at the redline, it's also the best way to prematurely knacker your bike.
Take the restrictors out if you wish, you should think about why your taking them out though, if it's so you can go faster then you obviously speed a lot and have a greater chance of being caught. Be sensible.
Scooby
Scrappy Doo
PostPosted: 23:05 - 07 Aug 2002    Post subject: Reply with quote
Erm.... are there any other reasons that you'd take 'em out??? Very Happy
tanner18
PostPosted: 14:17 - 09 Aug 2002    Post subject: Reply with quote
yeah to go faster ofcoarse
inline 4's rule
Robby
Dirty Old Man
PostPosted: 23:41 - 09 Aug 2002    Post subject: Reply with quote
shitloads more accel as well scoob - all they are is a plate in the carb that cuts the amount of petrol that can get in.
The last post was made 23 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 74.1 Kb
