electrics on a goose
ratboy
PostPosted: 22:21 - 25 May 2007    Post subject: electrics on a goose Reply with quote
anybody got any ideas about these (uses the 1991 dr350 engine)
no spark at the plug (changed numerous times and still no spark)
battery charged
cdi changed
good earth
wires have continuity
coil is tested
pickups seem okay
anything else to check or any ideas?
cheers
ratboy
Paddy Blake
PostPosted: 22:41 - 25 May 2007    Post subject: Reply with quote
Any history.
Did it just stop or was there work done on it.
Paddy.
garth
PostPosted: 12:05 - 26 May 2007    Post subject: Reply with quote
HT lead?
Hairy Ben
PostPosted: 11:03 - 27 May 2007    Post subject: Re: electrics on a goose Reply with quote
battery charged
cdi changed
good earth
coil is tested
pickups seem okay
cheers
ratboy
Sounds very similar to what happened to mine. Stopped to pick up a pizza one day, got back on the bike, no spark.
I did more or less everything you've done.
I eventually cured the problem by replacing the whole generator assembly iirc... Or the pick-ups, wiring and the copper wirey bit of the generator at least.
The hardest part was finding a Goose generator in a breakers yard. Took a couple of months. Sad However, this was maybe seven years ago so there were precious few Gooses around compared to today hence spares were few and far between.
*edit* Although as Garth said, HT lead might be worth a check if you haven't already done it, before you start pulling the poor things wiring out.
...and thus true enlightenment is achieved.
I think, therefore I am... I ride a BMW, therefore I smell of wee...
hmmmnz
PostPosted: 13:19 - 27 May 2007    Post subject: Reply with quote
heres a diagram ive done
it may be a llittle off with the wording as ive had to translate it from german
https://images6.theimagehosting.com/albums/25068/dr350-94on.th.JPG
hope that helps Very Happy
the humans are dead
I kick arse for the lord
ratboy
PostPosted: 13:27 - 27 May 2007    Post subject: goose Reply with quote
did previously break down, changed the casings with the pickups and it worked fine. thanks for the help, hopefully ill be able to have a fiddle and get it going again
The last post was made 19 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 14 - Page Size: 49.15 Kb
