| Author |
| Adam.I |
 Adam.I World Chat Champion
 Posted: 08:58 - 11 Jun 2007 Post subject: Bandit S Fuel Tap |
Hello all. I was fiddling around with the bike yesterday and after much struggling, I managed to get the fuel tap to turn to all three points, so now it turns freely. However, upon closer inspection, I have noticed that when it points to the up position, it says 'RES', which I assume is reserve, when it points to the right position, it says 'PRI' - perhaps primary? And when it points down, it says 'ON'. On my YBR, it says RES pointing to the top, OFF in the middle and ON at the bottom - easy, you know what they all mean, but not too sure about the Bandit, any ideas? ____________________ Veni Vidi Vici |
| Back to top |
| Jamie S |
 Jamie S World Chat Champion
 Posted: 09:09 - 11 Jun 2007 Post subject: |
| Back to top |
| Adam.I |
| Back to top |
| Jamie S |
| Back to top |
| Adam.I |
| Back to top |
| Jamie S |
| Back to top |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Back to top |
| Kris |
 Kris World Chat Champion
 Posted: 15:14 - 11 Jun 2007 Post subject: |
As others have said, for normal day to day riding the tap should be in the 'ON' position. If you get low on fuel then turn the tap to 'RES' (reserve) and it'll allow you to use the remainder in the bottom of the tank (~30 miles max.)
PRI is prime. I've only used this once after draining the carb floats. Basically it allows fuel to pour out of the tank petrol hoses and begin filling the carbs without the engine running.
If you ever have to take the tank off the bike, make sure the tap is in the 'ON' position. This way the fuel stays in the tank and doesn't pour out all over you and the garage floor  ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Back to top |
| JonB |
 JonB Afraid of Mileage
 Posted: 10:11 - 12 Jun 2007 Post subject: |
I only ever used the Prime once and that was when I had dismantled the carbs from the airbox and fuel tank to take my restrictors out. The bike was not starting at all, so I left it on Prime for 20 seconds and it started well.
I would not leave it on Prime whilst the engine is on. If you need additional fuel when starting normally, just use the choke.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Back to top |
The last post was made 19 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
