| Itchy |
 Itchy Super Spammer
 Posted: 19:21 - 11 Jun 2007 Post subject: Brake fade? |
Any way to prevent it or minimise it? ,its not a case of harsh over braking since I plan well in traffic and try to
keep moving at all times. my NTV seems to be suffering from it slightly recently , its not like Toby R brake fade
ie right up to the bar and its not doing anything, my discs are not warped and my pads in good condition , and
my brake fluid isn't cooking off either. I didn't notice it last year at all.
Or is it just a case of in summer its always been like that and you've only really realised it because you have a
shiney newer floating dual disc CBR sitting at home to compare it against which has very very sharp brakes. which
is possible since my GT550 felt a bit like that when I first got the NTV.
Any thoughts?
Ta ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Rookie |
 Rookie World Chat Champion
| mr jamez |
 mr jamez World Chat Champion
| Walloper |
 Walloper Super Spammer
 Posted: 20:50 - 11 Jun 2007 Post subject: |
Brake fade on discs brake systems is not as severe as drums.
This means the drum expands due to heat and moves away from the shoe so the lever moves to compensate for the loss.
Disc brake 'fade' is a different thing.
This is down to fric
Changing/Upgrading the pad material used is the quickest route as suggested.
Also consider braided hoses.
Liquids (brake fluid) transmit force equally in all directions This pushes the pads onto the disc but also expands the rubber in the hoses. Which absorbs some of the brake lever effect.
Braided hoses are rubber re-inforced with steel wire braid and will remove some of the sponge feel. But they can reduce the fine control during light braking. You get used to it though.
I hope you didn't know all that?
Tip:
Don't go so bloody fast and you wont need to stop as hard  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| curryfishball |
 curryfishball Nova Slayer
| timjim |
 timjim Trackday Trickster
| Syx |
 Syx World Chat Champion
 Posted: 22:25 - 11 Jun 2007 Post subject: |
Hygroscopic is right  |
| Kickstart |
 Kickstart The Oracle
 Posted: 22:39 - 11 Jun 2007 Post subject: |
Fade is due to heat. Sometimes from boiling the fluid, possible with basic DOT 3, but most likely only if you the fluid is old and has absorbed some water (which will boil at a far lower temperature).
Most likely from the pads getting way too hot.
Wavey disks might help, but not by much. You need to be using a pad with a suitable heat range for the use.
Surprised about the comment on the Thundercat brakes. They certainly shouldn't suffer from fade.
Braided hoses are unlikely to help much with fade, except for you changing the fluid at the same time. Sure there might be a tiny bit less expansion, but for that to have any real impact the brakes would need to be so bad that the lever was almost back to the bars.
| gmanxiii |
 gmanxiii World Chat Champion
| Kickstart |
| Rookie |
| timjim |
| Kickstart |
| Walloper |
| Walloper |
The last post was made 19 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
